[petsc-users] [External] Re: Segfaults when calling some PETSc functions in Fortran with variables initialized to PETSC_NULL_XX
Robert Hager
rhager at pppl.gov
Mon Jul 21 08:38:23 CDT 2025
Thanks, all! That makes sense (and the code worked without the
initializations in question).
BTW, my original email to the PETSc mailing list was held up for review by
a moderator yesterday. So that's probably why you haven't seen it there yet.
Best,
Robert
On Mon, Jul 21, 2025 at 9:10 AM Barry Smith <bsmith at petsc.dev> wrote:
> One passes PETSC_NULL_XXX as an argument that one does not want to get
> filled up, an optional argument. Similarly in PETSc C one passes NULL as an
> optional argument.
> You should not be setting variables to PETSC_NULL_XXX. When they are
> declared in your code they are automatically correctly initialized to an
> appropriate default value (which is not PETSC_NULL_XXX).
> You can use code such as
> if (PetscObjectIsNull(vec)) then
> to check if a PetscObject is currently validly set. Do not use
> if (vec == PETSC_NULL_VEC) then
> So, for example,
> VecCreate(..., vec,ierr)
> VecDestroy(vec,ierr)
> print*, 'vector was appropriately freed')
> endif
> Any further questions, please ask on petsc-maint or petsc-users
> Barry
> On Jul 21, 2025, at 8:49 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Jul 21, 2025 at 7:49 AM Mark Adams <mfadams at lbl.gov> wrote:
>> Hi Robert, [I don't see this message to PETSc users in my email so cc'ing
>> manually]
>> This is odd, something is messed up.
>> These NULL things are certainly 0 and the initial value of these objects
>> is not defined by the compiler, and they could be 0 in some cases.
> Hi Robert,
> I am not the Fortran expert, but I believe that passing PETSC_NULL_XXX to
> a creation routine is not correct. Here is my logic.
> In the wrapper, PETSC_NULL_XXX is converted to a NULL pointer (_not_ a
> pointer whose value is NULL). Thus KSPCreate would try to set a NULL
> pointer and you get the SEGV. I think it may have worked before because
> this was not automated, so these routines did not check for PETSC_NULL_XXX
> since it is not a case handled by the C function.
> Could you try without initializing? Barry would have to tell you what they
> should be initialized to.
> Thanks,
> Matt
>> Others are more up on the new Fortran stuff, but I would do a clean build
>> of PETSc (rm -fr arch...), and turn debugging on.
>> You will get a stack trace and it might find something and give a useful
>> error message, or "fix" the problem mysteriously.
>> You could put a print statement in before these are initialized to see
>> what *was* in it that you are clobbering.
>> Mark
>> On Sun, Jul 20, 2025 at 10:33 AM Robert Hager <rhager at pppl.gov> wrote:
>>> FYI
>>> ---------- Forwarded message ---------
>>> From: Robert Hager <rhager at pppl.gov>
>>> Date: Sun, Jul 20, 2025 at 10:32 AM
>>> Subject: Segfaults when calling some PETSc functions in Fortran with
>>> To: <petsc-users at mcs.anl.gov>
>>> Hello,
>>> I am in the process of updating my code to use PETSc versions >=3.22. (I
>>> am using v3.22.3 compiled with GCC on Perlmutter-CPU at NERSC for debugging
>>> at this time.) After updating all the Fortran function calls that have
>>> changed from v3.21 to v3.22 I am now getting segfaults in some PETSc
>>> routines. In the two instances I was able to identify, the problem seems to
>>> be calling the PETSc function with a PETSc variable that has been
>>> initialized to PETSC_NULL_XX:
>>> solver%rhs2_mat = PETSC_NULL_MAT
>>> *call* MatDuplicate(solver%Amat,MAT_DO_NOT_COPY_VALUES,solver%rhs2
>>> _mat,ierr)
>>> --> Segfault
>>> solver%ksp = PETSC_NULL_KSP
>>> *call* KSPCreate(solver%comm,solver%ksp,ierr)
>>> --> Segfault
>>> When I comment out the assignments to PETSC_NULL_XX in the above
>>> examples, the code works just fine.
>>> Is this the intended behavior or a bug that you might have fixed by now?
>>> Best,
>>> Robert
> experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ff1QrxkF_3zJXayYxscsHslgcC5yaFfwPYqgEvYwhn9Zc_NC9pomafs9Ry0gaVyQwhFIk2ddjV3fAIFTeqS2zg$
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!Ylz6mzmFkBJe1SAiy6sraNQ79TbZP3WWJtJY0kJSoeydhbohH8fH8uPd-f_ig_mjlKa2S7MME6rnPWQlLV-_$>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250721/cd232c63/attachment.html>
