[petsc-users] When to perform PETSc.Vec assembly with petsc4py
Jose E. Roman
jroman at dsic.upv.es
Tue Jul 15 08:36:30 CDT 2025
It is better if you can provide a full python script that we can run to reproduce the problem.
Jose
> El 15 jul 2025, a las 14:49, SCOTTO Alexandre <alexandre.scotto at irt-saintexupery.com> escribió:
> Ok I get it, Vec.assemble() is mandatory whenever MPI communications are required to get the values to appropriate processes.
> To provide more information, I am in a situation where I perform a A.multTranspose(x, y), where y is a vector that has been filled in with values earlier in the process. At this stage, I no longer care of these values and I expect the multTranspose() to override the values. But what I get is:
> · if I do y.assemble() before the transpose multiplication, then y is filled-in with the correct result.
> · if I do not perform y.assemble() before the transpose multiplication, I actually get y = y + A^T(x), i.e. a result rather of the form multTransposeAdd().
> · If I do A.multTranspose(x, y) twice, then I get the correct result y = A^T(x).
> This makes me think that I am misusing something at some points, but it is not clear what. If someone has a hint to explain this behaviour that would help me better understand how to properly use PETSc!
> Regards,
> Alexandre.
> De : Matthew Knepley <knepley at gmail.com>
> Envoyé : mardi 15 juillet 2025 14:18
> À : SCOTTO Alexandre <alexandre.scotto at irt-saintexupery.com>
> Cc : Jose E. Roman <jroman at dsic.upv.es>; petsc-users at mcs.anl.gov
> Objet : Re: [petsc-users] When to perform PETSc.Vec assembly with petsc4py
> On Tue, Jul 15, 2025 at 8:13 AM SCOTTO Alexandre via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hello Jose,
> Thanks for your answer. Then it seems that I have under the hood usages of setValues() in my code since I do not explicitly make use of it but still has problems when not assembling my vector. Do I need to assemble vectors after Mat.mult or Scatter.scatter?
> No. The purpose of VecAsseblyBegin/End() is to move values from processes that do not own them to the processes that do. PETSc does this automatically for MatMult() and VecScatter routines because we know exactly where values are headed. However, when users call VecSetValues(), they may set locations that are owned by other processes. We could communicate these immediately, but that might be expensive for a series of VecSetValues() calls, so we wait until you call VecAssembly().
> Note that direct assignment to the array can only set local values. This is equivalent to VecGetArray().
> Thanks,
> Matt
> By the way, I did not know that PETSc.Vec objects supported direct assignments like x[i] = ..., so I rather use assignments of the form x.array = ...
> From what I understand from the GitHub page (https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/blob/main/src/binding/petsc4py/src/petsc4py/PETSc/Vec.pyx__;!!G_uCfscf7eWS!f3M5SmfhSqew4tgfvFDjdLnd3q3kT_KzcCitJTJC0HRl1YvbSNBr5Uuzv6OWP1pVQBgbi_WJlekerylpGcBHQ9vsbzL1suFBQHkoPIwhdw$ ) it seems, that doing so, we only access the local portion of the array which should not require any assemble() am I right?
> Best regards,
> Alexandre.
> -----Message d'origine-----
> De : Jose E. Roman <jroman at dsic.upv.es>
> Envoyé : mardi 15 juillet 2025 12:21
> Cc : petsc-users at mcs.anl.gov
> Assembly is needed after a call to x.setValues() or any of its variants.
> https://urldefense.us/v3/__https://petsc.org/main/petsc4py/reference/petsc4py.PETSc.Vec.html*petsc4py.PETSc.Vec.setValue__;Iw!!G_uCfscf7eWS!f3M5SmfhSqew4tgfvFDjdLnd3q3kT_KzcCitJTJC0HRl1YvbSNBr5Uuzv6OWP1pVQBgbi_WJlekerylpGcBHQ9vsbzL1suFBQHlKEPOyQg$
> Take into account that in python the notation x[i] = ... with call x.setValues() under the hood.
> Jose
> > El 15 jul 2025, a las 12:02, SCOTTO Alexandre via petsc-users <petsc-users at mcs.anl.gov> escribió:
> > Dear PETSc community,
> > As a beginner in the MPI world and with the PETSc library, I come with a possibly very naive question.
> > I know from the documentation that assembling vectors must be done, but it is not clear to me when to perform this operation.
> > Is there a simple way to know when a vector need be assembled and when it is not?
> > Thanks in advance.
> > Regards,
> > Alexandre.
> -- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!YFFHiG3QxKfiKPBItZkVA5OnOBphUS5CGiNZWrgNYm4FLOjEzBMqLKlVQRdN3EZC9ueeIg6pWPdVOwt58c2GO5z3$
