[petsc-users] problem with nested logging, standalone example
Junchao Zhang junchao.zhang at gmail.com
Tue Jul 8 15:58:49 CDT 2025
Hi, Chris,
  First, I had to fix an error in your test by adding "
PetscCallA(MatSetFromOptions(AA,ierr))" at line 254.
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Object is in wrong state
[0]PETSC ERROR: Mat object's type is not set: Argument # 1
[0]PETSC ERROR: #1 MatSetValues() at
/scratch/jczhang/petsc/src/mat/interface/matrix.c:1503
[0]PETSC ERROR: #2 ex2f.F90:258
Then I could ran the test without problems
mpirun  -n 2 ./ex2f -pc_type jacobi -ksp_monitor_short
-ksp_gmres_cgs_refinement_type refine_always
  0 KSP Residual norm 1.11803
  1 KSP Residual norm 0.591608
  2 KSP Residual norm 0.316228
  3 KSP Residual norm < 1.e-11
  0 KSP Residual norm 0.707107
  1 KSP Residual norm 0.408248
  2 KSP Residual norm < 1.e-11
Norm of error < 1.e-12 iterations     3
I used petsc-3.22.4, gcc-11.3, openmpi-5.0.6 and configured with
./configure --with-cc=gcc --with-cxx=g++ --with-fc=gfortran
--download-openmpi --with-ssl=0 --with-shared-libraries=1
CFLAGS="-std=gnu11 -Wall -funroll-all-loops  -O3 -DNDEBUG"
CXXFLAGS="-std=gnu++14 -Wall -funroll-all-loops  -O3 -DNDEBUG "
COPTFLAGS="-std=gnu11 -Wall -funroll-all-loops  -O3 -DNDEBUG"
CXXOPTFLAGS="-std=gnu++14 -Wall -funroll-all-loops  -O3 -DNDEBUG "
FCFLAGS="-Wall -funroll-all-loops -ffree-line-length-0
-Wno-maybe-uninitialized -Wno-target-lifetime -Wno-unused-function -O3
-DNDEBUG" F90FLAGS="-Wall -funroll-all-loops -ffree-line-length-0
-DNDEBUG" FOPTFLAGS="-Wall -funroll-all-loops -ffree-line-length-0
-DNDEBUG"
Could you fix the error and retry?
--Junchao Zhang
On Sun, Jul 6, 2025 at 12:57 PM Klaij, Christiaan via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Attached is a standalone example of the issue described in the
> earlier thread "problem with nested logging". The issue appeared
> somewhere between petsc 3.19.4 and 3.23.4.
> The example is a variation of ../ksp/tutorials/ex2f.F90, where
> I've added the nested log viewer with one event as well as the
> solution of a small system on rank zero.
> When running on mulitple procs the example hangs during
> PetscLogView with the backtrace below. The configure.log is also
> attached in the hope that you can replicate the issue.
> Chris
> #0 0x000015554c84ea9e in mca_pml_ucx_recv (buf=0x7fffffff9e30, count=1,
> datatype=0x15554c9ef900 <ompi_mpi_2dblprec>, src=1, tag=-12,
> comm=0x7f1e30, mpi_status=0x0) at pml_ucx.c:700
> #1 0x000015554c65baff in ompi_coll_base_allreduce_intra_recursivedoubling (
> sbuf=0x7fffffff9e20, rbuf=0x7fffffff9e30, count=1,
> dtype=0x15554c9ef900 <ompi_mpi_2dblprec>,
> op=0x15554ca28980 <ompi_mpi_op_maxloc>, comm=0x7f1e30, module=0xaec630)
> at base/coll_base_allreduce.c:247
> #2 0x000015554c6a7e40 in ompi_coll_tuned_allreduce_intra_do_this (
> op=0x15554ca28980 <ompi_mpi_op_maxloc>, comm=0x7f1e30, module=0xaec630,
> algorithm=3, faninout=0, segsize=0) at coll_tuned_allreduce_decision.c:142
> #3 0x000015554c6a054f in ompi_coll_tuned_allreduce_intra_dec_fixed (
> at coll_tuned_decision_fixed.c:216
> #4 0x000015554c68e160 in mca_coll_hcoll_allreduce (sbuf=0x7fffffff9e20,
> rbuf=0x7fffffff9e30, count=1, dtype=0x15554c9ef900 <ompi_mpi_2dblprec>,
> op=0x15554ca28980 <ompi_mpi_op_maxloc>, comm=0x7f1e30, module=0xaecb80)
> at coll_hcoll_ops.c:217
> #5 0x000015554c59811a in PMPI_Allreduce (sendbuf=0x7fffffff9e20,
> recvbuf=0x7fffffff9e30, count=1, datatype=0x15554c9ef900
> <ompi_mpi_2dblprec>, op=0x15554ca28980 <ompi_mpi_op_maxloc>, comm=0x7f1e30)
> at allreduce.c:123
> #6 0x0000155553eabede in MPIU_Allreduce_Private () from
> /home/cklaij/ReFRESCO/trunk/install/extLibs/lib/libpetsc.so.3.22
> #7 0x0000155553e50d08 in PetscPrintXMLNestedLinePerfResults () from
> #8 0x0000155553e5123e in PetscLogNestedTreePrintLine () from
> #9 0x0000155553e51f3a in PetscLogNestedTreePrint () from
> #10 0x0000155553e51e96 in PetscLogNestedTreePrint () from
> #11 0x0000155553e51e96 in PetscLogNestedTreePrint () from
> #12 0x0000155553e52142 in PetscLogNestedTreePrintTop () from
> #13 0x0000155553e5257b in PetscLogHandlerView_Nested_XML () from
> #14 0x0000155553e4e5a0 in PetscLogHandlerView_Nested () from
> #15 0x0000155553e56232 in PetscLogHandlerView () from
> #16 0x0000155553e588c3 in PetscLogView () from
> #17 0x0000155553e40eb5 in petsclogview_ () from
> #18 0x0000000000402c8b in MAIN__ ()
> #19 0x00000000004023df in main ()
> dr. ir.  Christiaan  Klaij  |  senior researcher
> Research & Development  |  CFD Development
> T +31 317 49 33 44 <+31%20317%2049%2033%2044>  |  https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!ZHsZOjVtZW563bLFZCYkP0mARgO90Fn8zT_BWJ4h6gc-X9izzpyCqZ13ci6S6dNQXmutKi_6BIx2wmwGEBYl5mDNm02m$
> <https://urldefense.us/v3/__https://www.marin.nl/__;!!G_uCfscf7eWS!dAFNrWR8FzE9RrQXQAlok1iR_fA-rZdm9JAi-dlnKTnbdNTOTCViw0Nc-jjU4g72I-mhE1x1MZaf8imk4ivm_tE$>
> [image: Facebook]
> <https://urldefense.us/v3/__https://www.facebook.com/marin.wageningen__;!!G_uCfscf7eWS!dAFNrWR8FzE9RrQXQAlok1iR_fA-rZdm9JAi-dlnKTnbdNTOTCViw0Nc-jjU4g72I-mhE1x1MZaf8imkLNCvsiI$>
> [image: LinkedIn]
> <https://urldefense.us/v3/__https://www.linkedin.com/company/marin__;!!G_uCfscf7eWS!dAFNrWR8FzE9RrQXQAlok1iR_fA-rZdm9JAi-dlnKTnbdNTOTCViw0Nc-jjU4g72I-mhE1x1MZaf8imkrb79Ay4$>
> [image: YouTube]
> <https://urldefense.us/v3/__https://www.youtube.com/marinmultimedia__;!!G_uCfscf7eWS!dAFNrWR8FzE9RrQXQAlok1iR_fA-rZdm9JAi-dlnKTnbdNTOTCViw0Nc-jjU4g72I-mhE1x1MZaf8imkJiCoeLw$>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250708/21e4e18d/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250708/21e4e18d/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250708/21e4e18d/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250708/21e4e18d/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250708/21e4e18d/attachment-0007.png>
