[petsc-users] Matrix-Free J*v in PETSc
Jed Brown jed at jedbrown.org
Tue Jul 8 00:54:08 CDT 2025
Using MatShell is the standard method. Note that MatShell allows exposing other "matrix operations", such as producing a diagonal or other preconditioning ingredients.
Art <mac3bar at gmail.com> writes:
> Hi all,
> I am integrating a stiff system of ODEs/PDEs using PETSc TS (typically with
> BDF or other implicit time-stepping schemes), and I would like to exploit
> the fact that I can efficiently compute the action of the Jacobian on a
> vector (Jv) without assembling the full Jacobian matrix. Since for a large
> system it becomes expensive to assemble the Jacobian in each iteration.  In
> scikits.odes (SUNDIALS/CVODE), there is a native API for passing only a J*v
> routine to the time integrator. In my experience, when I use only a
> Jacobian-vector product routine (without assembling the full matrix), the
> performance improves significantly for large systems. However, in PETSc TS,
> the workflow seems more matrix-centric, and I have only found the
> possibility to use MatShell for the Jacobian
> Is there a way to do something similar in PETSc TS (for BDF or other
> implicit schemes)?
> Currently, I use the matrix-free Newton-Krylov method to approximate the
> Jacobian and have adjusted the tolerances to achieve convergence, as
> recommended by Barry. In that case, I obtain similar integration times
> with scikits.odes CVODE without using the Jacobian times vector.
> Best regards,
> Art
