[petsc-users] Petsc/Jax no copy interfacing issues
Alberto Cattaneo
bubu.cattaneo at gmail.com
Mon Jul 7 08:40:07 CDT 2025
Greetings.
I hope this email reaches you well. I’m trying to get JAX and PETSc to work
together in a no-copy system using the DLPack tools in both. Unfortunately
I can’t seem to get it to work right. Ideally, I’d like to create a PETSc
vec object using petsc4py, pass it to to a JAX object without copying, make
a change to it in a JAX jitted function and have that change reflected in
the PETSc object. All of this without copying.
Of note: When I try to do this I get an error that the alignment is wrong
and a copy must be made when I call the from-dlpack function but changing
the alignment in the PETSc ./config stage to 32 causes the error message to
disappear, even so it still doesn’t function correctly. I’ve tried looking
through the documentation, but I’m getting a little turned around.
I’ve included a code snippet below:
*from petsc4py import PETSc as PETSc*
*import jax*
*from functools import partial*
*import jax.numpy as jnp*
*@partial(jax.jit, donate_argnums=(0,))*
*def set_in_place(x):*
* return x.at <https://urldefense.us/v3/__http://x.at__;!!G_uCfscf7eWS!cqxG3TobpS7WZAgzxjrlWaxhAiiwWk4i9-WKReIWrc04LoXg4Y8zCkEDYGm_l5GilInGXbyzJWrD3BPRaTPlZHhIdz33$ >[:].set(3.0)*
*print('\nTesting jax from_dlpack given a PETSc vector that was allocated
by PETSc')*
*x = jnp.ones((1000,1))*
*y_petsc = PETSc.Vec().createSeq(x.shape[0])*
*y_petsc.set(0.0)*
*print(hex(y_petsc.handle))*
*y2_petsc = PETSc.Vec().createWithDLPack(y_petsc.toDLPack('rw'))*
*y2_petsc.set(-1.0)*
*assert y_petsc.getValue(0) == y2_petsc.getValue(0)*
*print('After creating a second PETSc vector via a DLPack of the first,
modifying the memory of one affects the other.')*
*#y = jnp.from_dlpack(y_petsc.toDLPack('rw'), copy=False)*
*y = jnp.from_dlpack(y_petsc, copy=False)*
*orig_ptr = y.unsafe_buffer_pointer()*
*print(f'before: ptr at {hex(orig_ptr)}')*
*y = set_in_place(y)*
*print(f'after: ptr at {hex(y.unsafe_buffer_pointer())}')*
*assert orig_ptr == y.unsafe_buffer_pointer()*
*#assert y_petsc.getValue(0) == y[0], f'The PETSc value
{y_petsc.getValue(0)} did not match the JAX value {y[0]}, so modifying the
JAX memory did not affect the PETSc memory.'*
I’d like the bottom two asserts to pass, but I can only get one of them. If
somebody is familiar with this issue I’d greatly appreciate the assistance.
Respectfully:
Alberto
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250707/98750b11/attachment.html>
