[petsc-users] problem with nested logging
Junchao Zhang junchao.zhang at gmail.com
Fri Jul 4 20:02:55 CDT 2025
How many MPI processes did you use?  When they hang, maybe you can check
their call stack to see if there are mismatches.
--Junchao Zhang
On Fri, Jul 4, 2025 at 5:56 AM Klaij, Christiaan via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> (yes, valgrind was attempted but did not show any obvious
> problems.)
> However, we are making some progress. The random segmentation
> faults are observed with intelmpi 2012.13 and openmpi
> 4.1.5. However, with openmpi 5.0.6, the randomness is gone and we
> get systematic hanging of the code during PetscLogView. In fact,
> we can now make the code hang by adding a single collective
> PetscLogEvent. Next step is to replicate this behaviour in a
> standalone example for you to investigate.
> Chris
> dr. ir.  Christiaan  Klaij  |  senior researcher
> Research & Development  |  CFD Development
> T +31 317 49 33 44 <+31%20317%2049%2033%2044>  |  https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!fjdaq68iKfZuqDCR2RkfATKmWU1OQqwgHSTHbXpz2Ad-Mu6uSQZvA-e4Fbx0lzh1j3ztmfJPNcOCveUUHXgjZzTK7bFU$
> <https://urldefense.us/v3/__https://www.marin.nl/__;!!G_uCfscf7eWS!fGUcwKtvcNmBqtHO64KSPpOhRicJBWa4sUVUEshLDH1m6jh1mEO97VnoUwQPxTYSSqRNNC-zDhw8Qm8Rc2pxj_Q$>
> [image: Facebook]
> <https://urldefense.us/v3/__https://www.facebook.com/marin.wageningen__;!!G_uCfscf7eWS!fGUcwKtvcNmBqtHO64KSPpOhRicJBWa4sUVUEshLDH1m6jh1mEO97VnoUwQPxTYSSqRNNC-zDhw8Qm8Rjciuaks$>
> [image: LinkedIn]
> <https://urldefense.us/v3/__https://www.linkedin.com/company/marin__;!!G_uCfscf7eWS!fGUcwKtvcNmBqtHO64KSPpOhRicJBWa4sUVUEshLDH1m6jh1mEO97VnoUwQPxTYSSqRNNC-zDhw8Qm8RJIGnkrE$>
> [image: YouTube]
> <https://urldefense.us/v3/__https://www.youtube.com/marinmultimedia__;!!G_uCfscf7eWS!fGUcwKtvcNmBqtHO64KSPpOhRicJBWa4sUVUEshLDH1m6jh1mEO97VnoUwQPxTYSSqRNNC-zDhw8Qm8Rmk1saOQ$>
> From: Barry Smith <bsmith at petsc.dev>
> Sent: Tuesday, July 1, 2025 4:54 PM
> To: Klaij, Christiaan
> Cc: PETSc users list
> Subject: Re: [petsc-users] problem with nested logging
> It's probably already been done, but if not, you should run under
> Valgrind. "Random" crashes are usually an indication of memory corruption.
> > On Jul 1, 2025, at 4:16 AM, Klaij, Christiaan via petsc-users <
> > It's been a while, in the meantime we did upgrade the OS and the
> > compilers but the problem still persists.
> > Can it be that one must call the PetscLogEventRegister and the
> > PetscLogEventBegin/End on all procs? Currently we don't do so,
> > think of some small system being build and solved. This event is
> > registered on all procs, but may take place on a single proc or
> > subset with the begin/end only on that proc or subset.
> > Chris
> > From: Klaij, Christiaan <C.Klaij at marin.nl>
> > Sent: Thursday, May 1, 2025 3:06 PM
> > To: Stefano Zampini
> > Cc: Randall Mackie; PETSc users list; Isaac, Toby
> > If I deactivate all the calls to PetscLogEventBegin/End in the
> > simulation code, the error does not show-up.
> > But since there are more than 2500 events, it's impossible to do
> > them one-by-one, especially since the error shows-up at random
> > and requires a number of cases and repetitions.
> > Unfortunately, I'm running out of time and budget. I will retry
> > once we get Rocky Linux 9 and the latest Intel compilers.
> > Chris
> > From: Stefano Zampini <stefano.zampini at gmail.com>
> > Sent: Thursday, May 1, 2025 10:57 AM
> > Il giorno gio 1 mag 2025 alle ore 11:38 Klaij, Christiaan <
> C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>> ha scritto:
> > The checks seem to be in place: I do get a PETSC ERROR when I add a log
> event on rank 0 as you suggested.
> > Ok, the broken logic may be in LogView then. You can try deactivating
> some logging by classes and see how the error evolves, maybe using
> PetscLogClassSetActiveAll. Or, if feasible, commenting out some part of the
> simulation code
> > Another thought: in between the log events pairs, I also have calls to
> PetscLogFlops, perhaps that plays a role somehow.
> > It shouldn't
> > Chris
> > From: Klaij, Christiaan <C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>>
> > Sent: Thursday, May 1, 2025 10:23 AM
> > To: Stefano Zampini
> > Was the rewritting by Toby done somewhere between petsc 3.19.4 (no
> problem) and 3.23.4 (problem)?
> > Chris
> > From: Stefano Zampini <stefano.zampini at gmail.com<mailto:
> stefano.zampini at gmail.com>>
> > Sent: Thursday, May 1, 2025 9:12 AM
> > If I look at the code for PetscLogHandlerEventBegin_Default, there are
> checks in place to see if the event is collectively called (see below)
> > Can you make sure the Nested logging system has the same checks?
> > It should, but double check since the code has been largely rewritten by
> Toby some time ago; to check it should be as easy as writing a code that
> calls a collective event on a single process and a debug version of petsc
> should complain
> > if (rank ==0)
> > LogEventBegin() <-this should call MPIU_Allreduce, but other processes
> will not, thus hang
> > If it does not complain, then the error must come from how the logic in
> LogView works, and from how it traverses the various events (my guess:
> processed in a different order from different processes). Without a
> reproducer, it is hard to understand what's going on
> > static PetscErrorCode PetscLogHandlerEventBegin_Default(PetscLogHandler
> h, PetscLogEvent event, PetscObject o1, PetscObject o2, PetscObject o3,
> PetscObject o4)
> > PetscLogHandler_Default def = (PetscLogHandler_Default)h->data;
> > PetscEventPerfInfo *event_perf_info = NULL;
> > PetscLogEventInfo event_info;
> > PetscLogDouble time;
> > PetscLogState state;
> > PetscLogStage stage;
> > PetscFunctionBegin;
> > PetscCall(PetscLogHandlerGetState(h, &state));
> > if (PetscDefined(USE_DEBUG)) {
> > PetscCall(PetscLogStateEventGetInfo(state, event, &event_info));
> > if (PetscUnlikely(o1)) PetscValidHeader(o1, 3);
> > if (PetscUnlikely(o2)) PetscValidHeader(o2, 4);
> > if (PetscUnlikely(o3)) PetscValidHeader(o3, 5);
> > if (PetscUnlikely(o4)) PetscValidHeader(o4, 6);
> > if (event_info.collective && o1) {
> > PetscInt64 b1[2], b2[2];
> > b1[0] = -o1->cidx;
> > b1[1] = o1->cidx;
> > PetscCallMPI(MPIU_Allreduce(b1, b2, 2, MPIU_INT64, MPI_MAX,
> PetscObjectComm(o1)));
> > PetscCheck(-b2[0] == b2[1], PETSC_COMM_SELF, PETSC_ERR_PLIB, "Collective
> event %s not called collectively %" PetscInt64_FMT " != %" PetscInt64_FMT,
> event_info.name<
> https://urldefense.us/v3/__http://event_info.name__;!!G_uCfscf7eWS!faEur1uGDdy2EYiXEYLCVq_UbMO1KiXKQa0vvY2nxKctWQDpgzsX7k9qTLBuMuQ6VNzwRHRHYc8jUopR10nyRr4$
> >, -b2[0], b2[1]);
> > /* Synchronization */
> > PetscCall(PetscLogHandlerEventSync_Default(h, event,
> > Il giorno gio 1 mag 2025 alle ore 09:56 Klaij, Christiaan <
> C.Klaij at marin.nl<mailto:C.Klaij at marin.nl><mailto:C.Klaij at marin.nl<mailto:
> C.Klaij at marin.nl>>> ha scritto:
> > I've tried with -log_sync, no complaints whatsoever, but the error is
> still there...
> > Chris
> stefano.zampini at gmail.com><mailto:stefano.zampini at gmail.com<mailto:
> stefano.zampini at gmail.com>>>
> > Sent: Tuesday, April 29, 2025 6:12 PM
> > To: Randall Mackie
> > Cc: Klaij, Christiaan; PETSc users list; Isaac, Toby
> > Can you try using -log_sync ? This should check every entry/exit points
> of logged Events and complain if something is not collectively called
> > Stefano
> > On Tue, Apr 29, 2025, 18:21 Randall Mackie <rlmackie862 at gmail.com
> <mailto:rlmackie862 at gmail.com><mailto:rlmackie862 at gmail.com<mailto:
> rlmackie862 at gmail.com>><mailto:rlmackie862 at gmail.com<mailto:
> rlmackie862 at gmail.com>>>> wrote:
> > ah okay, I missed that this was found using openmpi.
> > then it’s probably not the same issue we had.
> > I can’t remember in which version it was fixed (I’m away from my work
> computer)….I do know in our case openmpi and the latest Intel One API work
> fine.
> > Randy
> > On Apr 29, 2025, at 8:58 AM, Klaij, Christiaan <C.Klaij at marin.nl<mailto:
> C.Klaij at marin.nl><mailto:C.Klaij at marin.nl<mailto:C.Klaij at marin.nl
> >><mailto:C.Klaij at marin.nl<mailto:C.Klaij at marin.nl><mailto:
> C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>>>> wrote:
> > Well, the error below only shows-up thanks to openmpi and gnu compilers.
> > With the intel mpi and compilers it just hangs (tried oneapi 2023.1.0).
> In which version was that bug fixed?
> > Chris
> > <image374583.png>
> > | senior researcher | Research & Development | CFD Development
> > T +31 317 49 33 44<tel:+31%20317%2049%2033%2044> | C.Klaij at marin.nl
> <mailto:C.Klaij at marin.nl><mailto:C.Klaij at marin.nl<mailto:C.Klaij at marin.nl
> C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>>> |
> https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!faEur1uGDdy2EYiXEYLCVq_UbMO1KiXKQa0vvY2nxKctWQDpgzsX7k9qTLBuMuQ6VNzwRHRHYc8jUopRLSBIKfE$
> https://urldefense.us/v3/__https://www.marin.nl/__;!!G_uCfscf7eWS!bW2X4VgowGOLrAASgbFOR_Mh6HW4HtWqrdtpsvpnpiFrIwki34JOGyih-h-1bvgb-Bh4EdWRUoVqQW7s6Cx-ci9iNg$
> > <image322757.png><
> https://urldefense.us/v3/__https://www.facebook.com/marin.wageningen__;!!G_uCfscf7eWS!bW2X4VgowGOLrAASgbFOR_Mh6HW4HtWqrdtpsvpnpiFrIwki34JOGyih-h-1bvgb-Bh4EdWRUoVqQW7s6Cxl-rBbfA$
> > <image512282.png><
> https://urldefense.us/v3/__https://www.linkedin.com/company/marin__;!!G_uCfscf7eWS!bW2X4VgowGOLrAASgbFOR_Mh6HW4HtWqrdtpsvpnpiFrIwki34JOGyih-h-1bvgb-Bh4EdWRUoVqQW7s6Cw7FNelIQ$
> > <image090879.png><
> https://urldefense.us/v3/__https://www.youtube.com/marinmultimedia__;!!G_uCfscf7eWS!bW2X4VgowGOLrAASgbFOR_Mh6HW4HtWqrdtpsvpnpiFrIwki34JOGyih-h-1bvgb-Bh4EdWRUoVqQW7s6CwmfHQRog$
> > From: Randall Mackie <rlmackie862 at gmail.com<mailto:rlmackie862 at gmail.com
> ><mailto:rlmackie862 at gmail.com<mailto:rlmackie862 at gmail.com>><mailto:
> rlmackie862 at gmail.com<mailto:rlmackie862 at gmail.com><mailto:
> rlmackie862 at gmail.com<mailto:rlmackie862 at gmail.com>>>>
> > Sent: Tuesday, April 29, 2025 3:33 PM
> > Cc: Matthew Knepley; petsc-users at mcs.anl.gov<mailto:
> petsc-users at mcs.anl.gov><mailto:petsc-users at mcs.anl.gov<mailto:
> petsc-users at mcs.anl.gov>><mailto:petsc-users at mcs.anl.gov<mailto:
> petsc-users at mcs.anl.gov>>>; Isaac, Toby
> > You don't often get email from rlmackie862 at gmail.com<mailto:
> rlmackie862 at gmail.com>>>. Learn why this is important<
> https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!faEur1uGDdy2EYiXEYLCVq_UbMO1KiXKQa0vvY2nxKctWQDpgzsX7k9qTLBuMuQ6VNzwRHRHYc8jUopRRPgiIXk$
> https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!bW2X4VgowGOLrAASgbFOR_Mh6HW4HtWqrdtpsvpnpiFrIwki34JOGyih-h-1bvgb-Bh4EdWRUoVqQW7s6CwgJDUS5w$
> > We had a similar issue last year that we eventually tracked down to a
> bug in Intel MPI AllReduce, which was around the same version you are using.
> > Can you try a different MPI or the latest Intel One API and see if your
> error clears?
> > Randy
> > On Tue, Apr 29, 2025 at 8:17 AM Klaij, Christiaan via petsc-users <
> petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov><mailto:
> petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>><mailto:
> petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>><mailto:
> petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>>>> wrote:
> > I don't think so, we have tracing in place to detect mismatches. But as
> soon as I switch the tracing on, the error disappears... Same if I add a
> counter or print statements before and after EventBegin/End. Looks like a
> memory corruption problem, maybe nothing to do with petsc despite the error
> message.
> > Chris
> > From: Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com
> ><mailto:knepley at gmail.com<mailto:knepley at gmail.com>><mailto:
> knepley at gmail.com<mailto:knepley at gmail.com><mailto:knepley at gmail.com
> <mailto:knepley at gmail.com>>><mailto:knepley at gmail.com<mailto:
> knepley at gmail.com><mailto:knepley at gmail.com<mailto:knepley at gmail.com
> >><mailto:knepley at gmail.com<mailto:knepley at gmail.com><mailto:
> knepley at gmail.com<mailto:knepley at gmail.com>>>>>
> > Sent: Tuesday, April 29, 2025 1:50 PM
> > Cc: Junchao Zhang; petsc-users at mcs.anl.gov<mailto:
> petsc-users at mcs.anl.gov>>><mailto:petsc-users at mcs.anl.gov<mailto:
> petsc-users at mcs.anl.gov>>>>; Isaac, Toby
> > On Tue, Apr 29, 2025 at 6:50 AM Klaij, Christiaan <C.Klaij at marin.nl
> C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>>><mailto:C.Klaij at marin.nl
> C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>>>><mailto:C.Klaij at marin.nl
> C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>>>>>> wrote:
> > Here's a slightly better error message, obtained --with-debugging=1
> > Is it possible that you have a mismatched EventBegin()/EventEnd() in
> your code? That could be why we cannot reproduce it here.
> > Thanks,
> > Matt
> > [0]PETSC ERROR: --------------------- Error Message
> > [0]PETSC ERROR: Petsc has generated inconsistent data
> > [0]PETSC ERROR: MPIU_Allreduce() called in different locations (code
> lines) on different processors
> > [0]PETSC ERROR: See
> https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjggvQAzPU$
> for trouble shooting.
> > [0]PETSC ERROR: Petsc Release Version 3.22.4, Mar 01, 2025
> > [0]PETSC ERROR: ./refresco with 2 MPI process(es) and PETSC_ARCH on
> marclus3login2 by cklaij Tue Apr 29 12:43:54 2025
> > [0]PETSC ERROR: Configure options:
> --prefix=/home/cklaij/ReFRESCO/trunk/install/extLibs
> --with-mpi-dir=/cm/shared/apps/openmpi/gcc/4.0.2 --with-x=0 --with-mpe=0
> --with-debugging=1 --download-superlu_dist=
> https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/superlu_dist-8.1.2.tar.gz__;!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjgVgVAJPM$
> --with-blaslapack-dir=/cm/shared/apps/intel/oneapi/mkl/2021.4.0
> --download-parmetis=
> https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/parmetis-4.0.3-p9.tar.gz__;!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjgo2JWTO4$
> --download-metis=
> https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/metis-5.1.0-p11.tar.gz__;!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjgX9ZMYJA$
> --with-packages-build-dir=/home/cklaij/ReFRESCO/trunk/build-libs/superbuild
> --with-ssl=0 --with-shared-libraries=1
> > [0]PETSC ERROR: #1 PetscLogNestedTreePrintLine() at
> /home/cklaij/ReFRESCO/trunk/build-libs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:289
> > [0]PETSC ERROR: #2 PetscLogNestedTreePrint() at
> /home/cklaij/ReFRESCO/trunk/build-libs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:379
> > [0]PETSC ERROR: #3 PetscLogNestedTreePrint() at
> /home/cklaij/ReFRESCO/trunk/build-libs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:384
> > [0]PETSC ERROR: #4 PetscLogNestedTreePrint() at
> > [0]PETSC ERROR: #5 PetscLogNestedTreePrintTop() at
> /home/cklaij/ReFRESCO/trunk/build-libs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:420
> > [0]PETSC ERROR: #6 PetscLogHandlerView_Nested_XML() at
> /home/cklaij/ReFRESCO/trunk/build-libs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:443
> > [0]PETSC ERROR: #7 PetscLogHandlerView_Nested() at
> /home/cklaij/ReFRESCO/trunk/build-libs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/lognested.c:405
> > [0]PETSC ERROR: #8 PetscLogHandlerView() at
> /home/cklaij/ReFRESCO/trunk/build-libs/superbuild/petsc/src/src/sys/logging/handler/interface/loghandler.c:342
> > [0]PETSC ERROR: #9 PetscLogView() at
> /home/cklaij/ReFRESCO/trunk/build-libs/superbuild/petsc/src/src/sys/logging/plog.c:2040
> > [0]PETSC ERROR: #10
> /home/cklaij/ReFRESCO/trunk/Code/src/petsc_include_impl.F90:130
> > [cid:ii_19681617e7812ff9cfc1]
> C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>>>>> |
> https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjgJooxJhg$
> https://urldefense.us/v3/__https://www.marin.nl/__;!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjgpOXjQSM$
> > [Facebook]<
> https://urldefense.us/v3/__https://www.facebook.com/marin.wageningen__;!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjg_3Zt0Pw$
> > [LinkedIn]<
> https://urldefense.us/v3/__https://www.linkedin.com/company/marin__;!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjgcpgQdSE$
> > [YouTube]<
> https://urldefense.us/v3/__https://www.youtube.com/marinmultimedia__;!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjgn8qP6_I$
> ><mailto:C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>><mailto:
> C.Klaij at marin.nl>>><mailto:C.Klaij at marin.nl<mailto:C.Klaij at marin.nl
> C.Klaij at marin.nl>>>><mailto:C.Klaij at marin.nl<mailto:C.Klaij at marin.nl
> > Sent: Monday, April 28, 2025 3:53 PM
> > To: Matthew Knepley
> petsc-users at mcs.anl.gov>>>><mailto:petsc-users at mcs.anl.gov<mailto:
> petsc-users at mcs.anl.gov>>>>>; Isaac, Toby
> > Bisecting would be quite hard, it's not just the petsc version that
> changed, also other libs, compilers, even os components.
> > Chris
> knepley at gmail.com<mailto:knepley at gmail.com>>>><mailto:knepley at gmail.com
> <mailto:knepley at gmail.com><mailto:knepley at gmail.com<mailto:
> knepley at gmail.com>><mailto:knepley at gmail.com<mailto:knepley at gmail.com
> ><mailto:knepley at gmail.com<mailto:knepley at gmail.com>>><mailto:
> <mailto:knepley at gmail.com>><mailto:knepley at gmail.com<mailto:
> knepley at gmail.com><mailto:knepley at gmail.com<mailto:knepley at gmail.com>>>>>>
> > Sent: Monday, April 28, 2025 3:06 PM
> > You don't often get email from knepley at gmail.com<mailto:
> knepley at gmail.com<mailto:knepley at gmail.com>>><mailto:knepley at gmail.com
> ><mailto:knepley at gmail.com<mailto:knepley at gmail.com>>>><mailto:
> knepley at gmail.com<mailto:knepley at gmail.com>><mailto:knepley at gmail.com
> knepley at gmail.com>>>>>. Learn why this is important<
> https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjgcKEJXRA$
> > On Mon, Apr 28, 2025 at 8:45 AM Klaij, Christiaan via petsc-users <
> petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>>><mailto:
> petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>>>><mailto:
> petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>>>>>> wrote:
> > I've tried adding a nested log viewer to src/snes/tutorials/ex70.c,
> > but it does not replicate the problem and works fine.
> > Perhaps it is related to fortran, since the manualpage of
> > PetscLogNestedBegin says "No fortran support" (why? we've been
> > using it in fortran ever since).
> > Therefore I've tried adding it to src/snes/ex5f90.F90 and that
> > also works fine. It seems I cannot replicate the problem in a
> > small example, unfortunately.
> > We cannot replicate it here. Is there a chance you could bisect to see
> what change is responsible?
> > Thanks,
> > Matt
> > Chris
> > From: Junchao Zhang <junchao.zhang at gmail.com<mailto:
> junchao.zhang at gmail.com><mailto:junchao.zhang at gmail.com<mailto:
> junchao.zhang at gmail.com>><mailto:junchao.zhang at gmail.com<mailto:
> junchao.zhang at gmail.com>>><mailto:junchao.zhang at gmail.com<mailto:
> junchao.zhang at gmail.com>>>><mailto:junchao.zhang at gmail.com<mailto:
> junchao.zhang at gmail.com>>>>><mailto:junchao.zhang at gmail.com<mailto:
> junchao.zhang at gmail.com>>>>>>>
> > Sent: Saturday, April 26, 2025 3:51 PM
> > Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov><mailto:
> petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>>>>>; Isaac, Toby
> > You don't often get email from junchao.zhang at gmail.com<mailto:
> junchao.zhang at gmail.com>>>>>>. Learn why this is important<
> https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!cmLENZvO_Uydoa8ciUmsyX-F-QiJt9a2ZfQRUvQnRibGm7VE6PED7S_BDsUgjOzvPZIJyiIoJ8bLJk6gVgt1dmE$
> > Toby (Cc'ed) might know it. Or could you provide an example?
> > --Junchao Zhang
> > On Fri, Apr 25, 2025 at 3:31 AM Klaij, Christiaan via petsc-users <
> petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>>>>><mailto:
> petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>>>>>>> wrote:
> > We recently upgraded from 3.19.4 to 3.22.4 but face the problem below
> with the nested logging. Any ideas?
> > Chris
> > [1]PETSC ERROR: --------------------- Error Message
> > [1]PETSC ERROR: General MPI error
> > [1]PETSC ERROR: MPI error 1 MPI_ERR_BUFFER: invalid buffer pointer
> > [1]PETSC ERROR: See
> https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!cmLENZvO_Uydoa8ciUmsyX-F-QiJt9a2ZfQRUvQnRibGm7VE6PED7S_BDsUgjOzvPZIJyiIoJ8bLJk6gIT68pbk$
> https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGM3UaqHzc$>
> > [1]PETSC ERROR: Petsc Release Version 3.22.4, Mar 01, 2025
> > [1]PETSC ERROR: refresco with 2 MPI process(es) and PETSC_ARCH on
> marclus3login2 by jwindt Fri Apr 25 08:52:30 2025
> > [1]PETSC ERROR: Configure options:
> --prefix=/home/jwindt/cmake_builds/refresco/install-libs-gnu
> --with-debugging=0 --download-superlu_dist=
> https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/superlu_dist-8.1.2.tar.gz__;!!G_uCfscf7eWS!cmLENZvO_Uydoa8ciUmsyX-F-QiJt9a2ZfQRUvQnRibGm7VE6PED7S_BDsUgjOzvPZIJyiIoJ8bLJk6grH5BbeU$
> https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/superlu_dist-8.1.2.tar.gz__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGM21-2D-o$>
> https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/parmetis-4.0.3-p9.tar.gz__;!!G_uCfscf7eWS!cmLENZvO_Uydoa8ciUmsyX-F-QiJt9a2ZfQRUvQnRibGm7VE6PED7S_BDsUgjOzvPZIJyiIoJ8bLJk6gw4-tEtY$
> https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/parmetis-4.0.3-p9.tar.gz__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGMW0lYHko$>
> --download-metis=
> https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/metis-5.1.0-p11.tar.gz__;!!G_uCfscf7eWS!cmLENZvO_Uydoa8ciUmsyX-F-QiJt9a2ZfQRUvQnRibGm7VE6PED7S_BDsUgjOzvPZIJyiIoJ8bLJk6gHq4uYiY$
> https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/metis-5.1.0-p11.tar.gz__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGMbSrIiUg$>
> --with-packages-build-dir=/home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild
> --with-ssl=0 --with-shared-libraries=1 CFLAGS="-std=gnu11 -Wall
> -funroll-all-loops -O3 -DNDEBUG" CXXFLAGS="-std=gnu++14 -Wall
> -funroll-all-loops -O3 -DNDEBUG " COPTFLAGS="-std=gnu11 -Wall
> -funroll-all-loops -O3 -DNDEBUG" CXXOPTFLAGS="-std=gnu++14 -Wall
> -funroll-all-loops -O3 -DNDEBUG " FCFLAGS="-Wall -funroll-all-loops
> -ffree-line-length-0 -Wno-maybe-uninitialized -Wno-target-lifetime
> -Wno-unused-function -O3 -DNDEBUG" F90FLAGS="-Wall -funroll-all-loops
> -Wno-unused-function -O3 -DNDEBUG" FOPTFLAGS="-Wall -funroll-all-loops
> > [1]PETSC ERROR: #1 PetscLogNestedTreePrint() at
> /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:330
> > [1]PETSC ERROR: #2 PetscLogNestedTreePrint() at
> /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:384
> > [1]PETSC ERROR: #3 PetscLogNestedTreePrint() at
> > [1]PETSC ERROR: #4 PetscLogNestedTreePrintTop() at
> /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:420
> > [1]PETSC ERROR: #5 PetscLogHandlerView_Nested_XML() at
> /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:443
> > [1]PETSC ERROR: #6 PetscLogHandlerView_Nested() at
> /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/impls/nested/lognested.c:405
> > [1]PETSC ERROR: #7 PetscLogHandlerView() at
> /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/interface/loghandler.c:342
> > [1]PETSC ERROR: #8 PetscLogView() at
> /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/plog.c:2040
> > MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
> > with errorcode 98.
> > NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> > You may or may not see output from other processes, depending on
> > exactly when Open MPI kills them.
> > [cid:ii_196725d1e2a809852191]
> C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>>>>><mailto:C.Klaij at marin.nl
> C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>>>>>><mailto:C.Klaij at marin.nl
> C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>>>>>>> |
> https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!cmLENZvO_Uydoa8ciUmsyX-F-QiJt9a2ZfQRUvQnRibGm7VE6PED7S_BDsUgjOzvPZIJyiIoJ8bLJk6g8TwMMcw$
> https://urldefense.us/v3/__https://www.marin.nl/__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGM8tSNH1g$
> > [Facebook]<
> https://urldefense.us/v3/__https://www.facebook.com/marin.wageningen__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGMcVCZ9hk$
> > [LinkedIn]<
> https://urldefense.us/v3/__https://www.linkedin.com/company/marin__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGMIDBZW7k$
> > [YouTube]<
> https://urldefense.us/v3/__https://www.youtube.com/marinmultimedia__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGMVKWos24$
> > What most experimenters take for granted before they begin their
> experiments lead.
> > -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjg539kFLg$
> https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjgMsu6hhA$
> experiments lead.
> > -- Norbert Wiener
> > Stefano
> > Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250704/49a6d7de/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250704/49a6d7de/attachment-0004.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250704/49a6d7de/attachment-0005.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250704/49a6d7de/attachment-0006.png>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250704/49a6d7de/attachment-0007.png>
