[petsc-users] Update DMDA attached to DMSWARM
Tue Jan 28 10:24:24 CST 2025
No problem. Sorry I did not think of it sooner.
   Matt
On Tue, Jan 28, 2025 at 10:45 AM MIGUEL MOLINOS PEREZ <mmolinos at us.es>
wrote:
> It works! Thank you again Matt.
> Miguel
> On 24 Jan 2025, at 17:07, MIGUEL MOLINOS PEREZ <mmolinos at us.es> wrote:
> Ohh, I wasn't aware of this function. Thank you Matt, I’ll see if that
> solves the problem.
> Miguel
> On 24 Jan 2025, at 17:00, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Jan 24, 2025 at 10:56 AM MIGUEL MOLINOS PEREZ <mmolinos at us.es>
> wrote:
>> Sorry I wasn’t clear enough. By “the box is updated” I mean: I run
>> DMGetBoundingBox and the resulting coordinates are updated according to the
>> deformation gradient “F".
> Oh, if you change the periodic extent, which you are, you have to recall
> DMSetPeriodicity(), which is what DMGetBoundaingBox() consults for the
> periodic extent (because the coordinates cannot be trusted).
>   Thanks,
>      Matt
>> Thanks,
>> Miguel
>> On 24 Jan 2025, at 16:50, Matthew Knepley <knepley at gmail.com> wrote:
>> On Fri, Jan 24, 2025 at 10:36 AM MIGUEL MOLINOS PEREZ <mmolinos at us.es>
>> wrote:
>>> Thanks Matt, I tried that too, and the problem remains. The box is
>>> updated only if I set no periodic bcc.
>> What do you mean by "The box is updated"? I am trying to understand how
>> you test things. Clearly the coordinates are updated,
>> even in the periodic case. Thus, I need to understand the test. Once we
>> do that, we can work backwards to the first broken thing.
>>   Thanks,
>>       Matt
>>> Miguel
>>> On 24 Jan 2025, at 14:20, Matthew Knepley <knepley at gmail.com> wrote:
>>> On Fri, Jan 24, 2025 at 4:41 AM MIGUEL MOLINOS PEREZ <mmolinos at us.es>
>>> wrote:
>>>> Dear Matt, the error was in the implementation of the volume expansion
>>>> function. I updated it, and it works finte under finite domains. However,
>>>> if I include periodic boundary conditions the volume of the cell does not
>>>> accommodate the volume expansion of the particles. The deformation gradient
>>>> is not the identity… I guess I am missing the fine detail on how periodic
>>>> bcc are implemented in DMDA mesh, I’m right?
>>> DMDA identifies vertices using a VecScatter to implement periodic BC.
>>> This should be insensitive to coordinates. However, I don't think the
>>> algorithm below is correct for local coordinates. You use GlobalToLocal(),
>>> which means that some global coordinate "wins" for each local cell, so
>>> cells on the periodic boundary can be wrong. I would set the local
>>> coordinates by hand as well.
>>>   Thanks,
>>>      Matt
>>>> Thanks,
>>>> Miguel
>>>> static PetscErrorCode Volumetric_Expansion_DMDA(DM * da,
>>>> const Eigen::Matrix3d& F) {
>>>> PetscInt i, j, mstart, m, nstart, n, pstart, p, k;
>>>> Vec local, global;
>>>> DMDACoor3d ***coors, ***coorslocal;
>>>> DM cda;
>>>> PetscFunctionBeginUser;
>>>> PetscCall(DMGetCoordinateDM(*da, &cda));
>>>> PetscCall(DMGetCoordinates(*da, &global));
>>>> PetscCall(DMGetCoordinatesLocal(*da, &local));
>>>> PetscCall(DMDAVecGetArray(cda, global, &coors));
>>>> PetscCall(DMDAVecGetArrayRead(cda, local, &coorslocal));
>>>> PetscCall(DMDAGetCorners(cda, &mstart, &nstart, &pstart, &m, &n, &p));
>>>> for (i = mstart; i < mstart + m; i++) {
>>>> for (j = nstart; j < nstart + n; j++) {
>>>> for (k = pstart; k < pstart + p; k++) {
>>>> coors[k][j][i].x = coorslocal[k][j][i].x * F(0, 0);
>>>> coors[k][j][i].y = coorslocal[k][j][i].y * F(1, 1);
>>>> coors[k][j][i].z = coorslocal[k][j][i].z * F(2, 2);
>>>> PetscCall(DMDAVecRestoreArray(cda, global, &coors));
>>>> PetscCall(DMDAVecRestoreArrayRead(cda, local, &coorslocal));
>>>> PetscCall(DMGlobalToLocalBegin(cda, global, INSERT_VALUES, local));
>>>> PetscCall(DMGlobalToLocalEnd(cda, global, INSERT_VALUES, local));
>>>> PetscFunctionReturn(PETSC_SUCCESS);
>>>> On 17 Jan 2025, at 18:01, MIGUEL MOLINOS PEREZ <mmolinos at us.es> wrote:
>>>> You are right!! Thank you again!
>>>> Miguel
>>>> On Jan 17, 2025, at 5:18 PM, Matthew Knepley <knepley at gmail.com> wrote:
>>>> On Fri, Jan 17, 2025 at 10:49 AM MIGUEL MOLINOS PEREZ <mmolinos at us.es>
>>>> wrote:
>>>>> Now the error is in the call to DMSwarmMigrate
>>>> You have almost certainly overwritten memory somewhere. Can you use
>>>> vlagrind or Address Sanitizer?
>>>>    Thanks,
>>>>       Matt
>>>>> Miguel
>>>>> [0]PETSC ERROR:
>>>>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
>>>>> probably memory access out of range
>>>>> [0]PETSC ERROR: Try option -start_in_debugger or
>>>>> -on_error_attach_debugger
>>>>> [0]PETSC ERROR: or see https://urldefense.us/v3/__https://petsc.org/release/faq/*valgrind__;Iw!!G_uCfscf7eWS!ee2AOndSc3M8PXEGVjufaWIa3rs_TPHCCbPc7Y2s8ri6DAQ5tamfRac_Wqy3I_kP85xjohwRbXcUxxZ4fooO$  and
>>>>> https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!ee2AOndSc3M8PXEGVjufaWIa3rs_TPHCCbPc7Y2s8ri6DAQ5tamfRac_Wqy3I_kP85xjohwRbXcUx15Kn1xQ$
>>>>> [0]PETSC ERROR: ---------------------  Stack Frames
>>>>> [0]PETSC ERROR: The line numbers in the error traceback are not always
>>>>> exact.
>>>>> [0]PETSC ERROR: #1 DMSwarmDataBucketGetSizes() at
>>>>> /Users/migmolper/petsc/src/dm/impls/swarm/data_bucket.c:297
>>>>> [0]PETSC ERROR: #2 DMSwarmMigrate_CellDMScatter() at
>>>>> /Users/migmolper/petsc/src/dm/impls/swarm/swarm_migrate.c:201
>>>>> [0]PETSC ERROR: #3 DMSwarmMigrate() at
>>>>> /Users/migmolper/petsc/src/dm/impls/swarm/swarm.c:1349
>>>>> [0]PETSC ERROR: #4 main() at
>>>>> /Users/migmolper/DMD/driver-tasting-SOLERA.cpp:41
>>>>> application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
>>>>> On Jan 17, 2025, at 4:22 PM, Matthew Knepley <knepley at gmail.com>
>>>>> wrote:
>>>>> On Fri, Jan 17, 2025 at 10:08 AM MIGUEL MOLINOS PEREZ <mmolinos at us.es>
>>>>> wrote:
>>>>>> Thank you Matt, this the piece of code I use to change the
>>>>>> coordinates of the DM obtained using:
>>>>> You do not need the call to DMSetCoordinates(). What happens when you
>>>>> remove it?
>>>>>   Thanks,
>>>>>     Matt
>>>>>> DMSwarmGetCellDM(Simulation.atomistic_data, &bounding_cell);
>>>>>> DMGetApplicationContext(bounding_cell, &background_mesh);
>>>>>> Thanks,
>>>>>> Miguel
>>>>>> PetscErrorCode Volumetric_Expansion(DM dm, const Eigen::Matrix3d& F)
>>>>>> PetscErrorCode ierr;
>>>>>> Vec coordinates;
>>>>>> PetscScalar* coordArray;
>>>>>> PetscInt xs, ys, zs, xm, ym, zm, i, j, k;
>>>>>> PetscInt dim, M, N, P;
>>>>>> PetscFunctionBegin;
>>>>>> // Get DMDA information
>>>>>> ierr = DMDAGetInfo(dm, &dim, &M, &N, &P, NULL, NULL, NULL, NULL, NULL,
>>>>>> NULL,
>>>>>> NULL, NULL, NULL);
>>>>>> CHKERRQ(ierr);
>>>>>> ierr = DMDAGetCorners(dm, &xs, &ys, &zs, &xm, &ym, &zm);
>>>>>> CHKERRQ(ierr);
>>>>>> // Get the coordinates vector
>>>>>> ierr = DMGetCoordinates(dm, &coordinates);
>>>>>> CHKERRQ(ierr);
>>>>>> ierr = VecGetArray(coordinates, &coordArray);
>>>>>> CHKERRQ(ierr);
>>>>>> // Update the coordinates based on the desired transformation
>>>>>> for (k = zs; k < zs + zm; k++) {
>>>>>> for (j = ys; j < ys + ym; j++) {
>>>>>> for (i = xs; i < xs + xm; i++) {
>>>>>> PetscInt idx =
>>>>>> ((k * N + j) * M + i) * dim; // Index for the i, j, k point
>>>>>> coordArray[idx] = coordArray[idx] * F(0,0); // Update x-coordinate
>>>>>> coordArray[idx + 1] = coordArray[idx + 1] * F(1,1); // Update
>>>>>> y-coordinate
>>>>>> coordArray[idx + 2] = coordArray[idx + 2] * F(2,2); // Update
>>>>>> z-coordinate
>>>>>> // Restore the coordinates vector
>>>>>> ierr = VecRestoreArray(coordinates, &coordArray);
>>>>>> CHKERRQ(ierr);
>>>>>> // Set the updated coordinates back to the DMDA
>>>>>> ierr = DMSetCoordinates(dm, coordinates);
>>>>>> CHKERRQ(ierr);
>>>>>> PetscFunctionReturn(0);
>>>>>> On 17 Jan 2025, at 16:00, Matthew Knepley <knepley at gmail.com> wrote:
>>>>>> On Fri, Jan 17, 2025 at 9:45 AM MIGUEL MOLINOS PEREZ <mmolinos at us.es>
>>>>>> wrote:
>>>>>>> I tried what you suggested, but still I got this error message.
>>>>>>> Maybe I should use main release?
>>>>>> No. I suspect something is wrong with the way you are setting
>>>>>> coordinates. Can you share the code?
>>>>>>   Thanks,
>>>>>>      Matt
>>>>>>> Miguel
>>>>>>> [4]PETSC ERROR:
>>>>>>> [4]PETSC ERROR: Caught signal number 11 SEGV: Segmentation
>>>>>>> Violation, probably memory access out of range
>>>>>>> [4]PETSC ERROR: Try option -start_in_debugger or
>>>>>>> [4]PETSC ERROR: or see https://urldefense.us/v3/__https://petsc.org/release/faq/*valgrind__;Iw!!G_uCfscf7eWS!ee2AOndSc3M8PXEGVjufaWIa3rs_TPHCCbPc7Y2s8ri6DAQ5tamfRac_Wqy3I_kP85xjohwRbXcUxxZ4fooO$  and
>>>>>>> [4]PETSC ERROR: ---------------------  Stack Frames
>>>>>>> [4]PETSC ERROR: The line numbers in the error traceback are not
>>>>>>> always exact.
>>>>>>> [4]PETSC ERROR: #1 Pack_PetscReal_1_0() at
>>>>>>> /Users/migmolper/petsc/src/vec/is/sf/impls/basic/sfpack.c:373
>>>>>>> [4]PETSC ERROR: #2 PetscSFLinkPackRootData_Private() at
>>>>>>> /Users/migmolper/petsc/src/vec/is/sf/impls/basic/sfpack.c:932
>>>>>>> [4]PETSC ERROR: #3 PetscSFLinkPackRootData() at
>>>>>>> /Users/migmolper/petsc/src/vec/is/sf/impls/basic/sfpack.c:966
>>>>>>> [4]PETSC ERROR: #4 PetscSFBcastBegin_Basic() at
>>>>>>> /Users/migmolper/petsc/src/vec/is/sf/impls/basic/sfbasic.c:357
>>>>>>> [4]PETSC ERROR: #5 PetscSFBcastWithMemTypeBegin() at
>>>>>>> /Users/migmolper/petsc/src/vec/is/sf/interface/sf.c:1513
>>>>>>> [4]PETSC ERROR: #6 VecScatterBegin_Internal() at
>>>>>>> /Users/migmolper/petsc/src/vec/is/sf/interface/vscat.c:70
>>>>>>> [4]PETSC ERROR: #7 VecScatterBegin() at
>>>>>>> /Users/migmolper/petsc/src/vec/is/sf/interface/vscat.c:1316
>>>>>>> [4]PETSC ERROR: #8 DMGlobalToLocalBegin_DA() at
>>>>>>> /Users/migmolper/petsc/src/dm/impls/da/dagtol.c:15
>>>>>>> [4]PETSC ERROR: #9 DMGlobalToLocalBegin() at
>>>>>>> /Users/migmolper/petsc/src/dm/interface/dm.c:2844
>>>>>>> [4]PETSC ERROR: #10 DMGetCoordinatesLocalSetUp() at
>>>>>>> /Users/migmolper/petsc/src/dm/interface/dmcoordinates.c:565
>>>>>>> [4]PETSC ERROR: #11 DMGetCoordinatesLocal() at
>>>>>>> /Users/migmolper/petsc/src/dm/interface/dmcoordinates.c:599
>>>>>>> [4]PETSC ERROR: #12 _DMLocatePoints_DMDARegular_IS() at
>>>>>>> /Users/migmolper/DMD/SOLERA/Atoms/Atom.cpp:531
>>>>>>> [4]PETSC ERROR: #13 DMLocatePoints_DMDARegular() at
>>>>>>> /Users/migmolper/DMD/SOLERA/Atoms/Atom.cpp:586
>>>>>>> [4]PETSC ERROR: #14 DMLocatePoints() at
>>>>>>> /Users/migmolper/petsc/src/dm/interface/dmcoordinates.c:1194
>>>>>>> [4]PETSC ERROR: #15 DMSwarmMigrate_CellDMScatter() at
>>>>>>> /Users/migmolper/petsc/src/dm/impls/swarm/swarm_migrate.c:219
>>>>>>> [4]PETSC ERROR: #16 DMSwarmMigrate() at
>>>>>>> [4]PETSC ERROR: #17 main() at
>>>>>>> On Jan 15, 2025, at 4:56 PM, MIGUEL MOLINOS PEREZ <mmolinos at us.es>
>>>>>>> wrote:
>>>>>>> Thank you Matt for the useful info. I’ll try your idea.
>>>>>>> Miguel
>>>>>>> On 15 Jan 2025, at 16:48, Matthew Knepley <knepley at gmail.com> wrote:
>>>>>>> On Wed, Jan 15, 2025 at 10:41 AM MIGUEL MOLINOS PEREZ <
>>>>>>>> Thank you Matt.
>>>>>>>> Yes, I am getting the "CellDM" from the DMSwarm.
>>>>>>>> 1. I have recently overhauled this functionality because it was not
>>>>>>>> flexible enough for the plasma simulation we do. Thus main and release work
>>>>>>>> differently.
>>>>>>>> Nice to hear that. Should I move to main?
>>>>>>> The changes allow you to have several cell DMs. I want to bin
>>>>>>> particles in space, but also in velocity, and then in the tensor product of
>>>>>>> space and velocity. Moreover, sometimes I want to use different Swarm
>>>>>>> fields as the DM field for the solver. You can do all that with main now.
>>>>>>> If you just need a single DM with the same DM fields, release is fine.
>>>>>>>> 2. I assume you are using release
>>>>>>>> You are correct.
>>>>>>>> 3. In both main and release, if you change the coordinates of your
>>>>>>>> CellDM mesh, you need to rebin the particles. The easiest way to do this is
>>>>>>>> to call DMSwarmMigrate(sw, PETSC_FALSE).
>>>>>>>> What do you mean by rebin?
>>>>>>> When you provide the cell DM, Swrm makes a "sort context" that bins
>>>>>>> the particles into DM cells. If you change the coordinates, this binning
>>>>>>> will change, so you need it to "rebin" or recreate the sort context.
>>>>>>>   Thanks,
>>>>>>>     Matt
>>>>>>>> Miguel
>>>>>>>>   Thanks,
>>>>>>>>      Matt
>>>>>>>>> Best,
>>>>>>>>> Miguel
>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>>>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ee2AOndSc3M8PXEGVjufaWIa3rs_TPHCCbPc7Y2s8ri6DAQ5tamfRac_Wqy3I_kP85xjohwRbXcUx5LqFJcU$
>>>>>>>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ee2AOndSc3M8PXEGVjufaWIa3rs_TPHCCbPc7Y2s8ri6DAQ5tamfRac_Wqy3I_kP85xjohwRbXcUx06JLsWL$ >
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ee2AOndSc3M8PXEGVjufaWIa3rs_TPHCCbPc7Y2s8ri6DAQ5tamfRac_Wqy3I_kP85xjohwRbXcUx5LqFJcU$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!ee2AOndSc3M8PXEGVjufaWIa3rs_TPHCCbPc7Y2s8ri6DAQ5tamfRac_Wqy3I_kP85xjohwRbXcUx06JLsWL$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250128/0edebc12/attachment-0001.html>
