[petsc-users] Copy dense matrix into half part of another dense matrix
medane.tchakorom at univ-fcomte.fr
Tue Jan 28 03:50:09 CST 2025
Re:
Thank you Pierre, I really appreciate. I’am testing it right now to access the improvements.
BR,
Medane
> On 27 Jan 2025, at 20:19, Pierre Jolivet <pierre at joliv.et> wrote:
> Please always keep the list in copy.
> The way you create A is not correct, I’ve attached a fixed code.
> If you want to keep your own distribution for A (and not the one associated to R_part), you’ll need to first call https://urldefense.us/v3/__https://petsc.org/main/manualpages/Mat/MatCreateSubMatrix/__;!!G_uCfscf7eWS!Ye7A4fqD5xLobOPjgvYkh9cj1-JExIqX_EJIHFm-NHw5rEk2PU5kvs3GfKlJd2TZPorWhvb0Jh7eTcKii9t7Z7tgYSIoeSHTchrF1snH$ to redistribute A and then do a MatCopy() of the resulting Mat into R_part
> Thanks,
> Pierre
> $ /Volumes/Data/repositories/petsc/arch-darwin-c-debug-real/bin/mpirun -n 4 ./ex1234
> Mat Object: 4 MPI processes
> type: mpidense
> 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00
> type: mpidense
> 2.6219599187040323e+00 1.9661197867318445e+00 1.5218640363910978e+00
> 3.5202261875977947e+00 3.6311893358251384e+00 2.2279492868785069e+00
> 2.7505403755038014e+00 3.1546072728892756e+00 1.8416294994524489e+00
> 2.4676055638467314e+00 2.3185625557889602e+00 2.0401666986599833e+00
> <ex1234.c>
>> On 27 Jan 2025, at 6:53 PM, medane.tchakorom at univ-fcomte.fr wrote:
>> Re:
>> This is a small reproductible example using MatDenseGetSubMatrix
>> Command: petscmpiexec -n 4 ./example
>> PetscInt nlines = 8; // lines
>> PetscInt ncolumns = 3; // columns
>> PetscInt random_size = 12;
>> PetscInt rank;
>> PetscInt size;
>> // Initialize PETSc
>> PetscInitialize(&argc, &args, NULL, NULL);
>> MPI_Comm_rank(MPI_COMM_WORLD, &rank);
>> MPI_Comm_size(MPI_COMM_WORLD, &size);
>> // R_full with all values to zero
>> Mat R_full;
>> MatCreateDense(PETSC_COMM_WORLD, PETSC_DECIDE, PETSC_DECIDE, nlines, ncolumns, NULL, &R_full);
>> MatZeroEntries(R_full);
>> MatView(R_full, PETSC_VIEWER_STDOUT_WORLD);
>> // Creating and setting A and S to rand values
>> Mat A, S;
>> MatCreateDense(PETSC_COMM_WORLD, PETSC_DECIDE, PETSC_DECIDE, nlines / 2, random_size, NULL, &A);
>> MatCreateDense(PETSC_COMM_WORLD, PETSC_DECIDE, PETSC_DECIDE, random_size, ncolumns, NULL, &S);
>> MatSetRandom(A, NULL);
>> MatSetRandom(S, NULL);
>> // Computing R_part
>> Mat R_part;
>> MatDenseGetSubMatrix(R_full, PETSC_DECIDE, nlines / 2, PETSC_DECIDE, PETSC_DECIDE, &R_part);
>> MatMatMult(A, S, MAT_REUSE_MATRIX, PETSC_DECIDE, &R_part);
>> // Visualizing R_full
>> MatDenseRestoreSubMatrix(R_full, &R_part);
>> // Destroying matrices
>> MatDestroy(&R_part);
>> MatDestroy(&R_full);
>> PetscFinalize();
>> return 0;
>> Part of the error output contains….:
>> "Cannot change/reset row sizes to 1 local 4 global after previously setting them to 2 local 4 global ….”
>> PetscInt rank;
>> PetscInt size;
>> // Initialize PETSc
>> Mat R_full;
>> Mat A, S;
>> // Computing R_part
>> Mat R_part;
>> MatMatMult(A, S, MAT_INITIAL_MATRIX, PETSC_DECIDE, &R_part);
>> MatView(R_part, PETSC_VIEWER_STDOUT_WORLD);
>> Mat R_sub;
>> MatDenseGetSubMatrix(R_full, PETSC_DECIDE, nlines / 2, PETSC_DECIDE, PETSC_DECIDE, &R_sub);
>> PetscScalar *storage = NULL;
>> MatDenseGetArray(R_part, &storage);
>> PetscScalar *storage_sub = NULL;
>> MatDenseGetArray(R_sub, &storage_sub);
>> PetscArraycpy(storage_sub, storage, (nlines / 2) * ncolumns);
>> MatDenseRestoreArray(R_part, &storage);
>> MatDenseRestoreArray(R_sub, &storage_sub);
>> MatDenseRestoreSubMatrix(R_full, &R_sub);
>> PetscFinalize();
>> return 0;
>> Now Using MatDenseGetArray
>> Please let me know if I need to clarify something.
>> Thanks
>> Medane
>>> On 27 Jan 2025, at 16:26, Pierre Jolivet <pierre at joliv.et> wrote:
>>>> On 27 Jan 2025, at 3:52 PM, Matthew Knepley <knepley at gmail.com> wrote:
>>>> On Mon, Jan 27, 2025 at 9:23 AM medane.tchakorom at univ-fcomte.fr <mailto:medane.tchakorom at univ-fcomte.fr> <medane.tchakorom at univ-fcomte.fr <mailto:medane.tchakorom at univ-fcomte.fr>> wrote:
>>>>> Re:
>>>>> MatDenseGetSubMatrix in fact could be the best alternative (cleaner code), but as mentioned earlier, I would like to use the smaller matrix R_part to get the result of a MatMatMult operation.
>>>>> When trying to use MAT_REUSE_MATRIX, this gave an error (expected error I think). On the other side, I mentionned on MatDenseGetSubMatrix page, "The output matrix is not redistributed by PETSc”. So will R_part be a valid output matrix for MatMatMult?
>>>> I believe it is, but I am not the expert.
>>>> Pierre, can the SubMatrix be used as the output of a MatMatMult()?
>>> It should be, but there may be some limitations due to leading dimensions and what not.
>>> By looking at just the single line of code we got from you, I can see at least one issue: it should be MAT_REUSE_MATRIX, not MAT_INITIAL_MATRIX (assuming you got R_part from MatDenseGetSubMatrix).
>>> Feel free to share a (minimal) reproducer.
>>> Thanks,
>>> Pierre
>>>> Thanks,
>>>> Matt
>>>>> Thanks
>>>>>> On 27 Jan 2025, at 14:52, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>>>>> On Mon, Jan 27, 2025 at 8:42 AM Pierre Jolivet <pierre at joliv.et <mailto:pierre at joliv.et>> wrote:
>>>>>>> > On 27 Jan 2025, at 2:23 PM, medane.tchakorom at univ-fcomte.fr <mailto:medane.tchakorom at univ-fcomte.fr> wrote:
>>>>>>> > Dear PETSc users,
>>>>>>> > I hope this message finds you well. I don’t know If my question is relevant, but I’am currently working with DENSE type matrix, and would like to copy one matrix R_part [ n/2 x m] (resulted from a MatMatMult operation) into another dense matrix R_full [n x m].
>>>>>>> > Both matrices being on the same communicator, I would like to efficiently copy R_part in the first half of R_full.
>>>>>>> > I have being using MatSetValues, but for large matrices, the subsequent assembling operation is costly.
>>>>>>> Could you please share the output of -log_view as well as a single file that will be generated with -info dump (e.g., dump.0, the file associated to process #0)?
>>>>>>> This shouldn’t be that costly, so there may be an option missing, like MAT_NO_OFF_PROC_ENTRIES.
>>>>>>> Anyway, if you want to optimize this, the fastest way would be to call MatDenseGetArray[Read,Write]() and then do the necessary PetscArraycpy().
>>>>>> The other alternative (which I think makes cleaner code) is to use
>>>>>> https://urldefense.us/v3/__https://petsc.org/main/manualpages/Mat/MatDenseGetSubMatrix/__;!!G_uCfscf7eWS!Ye7A4fqD5xLobOPjgvYkh9cj1-JExIqX_EJIHFm-NHw5rEk2PU5kvs3GfKlJd2TZPorWhvb0Jh7eTcKii9t7Z7tgYSIoeSHTchex8FLh$
>>>>>> to create your R_part matrix. Then you are directly acting on the memory you want when assemble the smaller matrix.
>>>>>> THanks,
>>>>>> Matt
>>>>>>> Thanks,
>>>>>>> Pierre
>>>>>>> > Please could you suggest me some strategies or functions to do this efficiently.
>>>>>>> > Thank you for your time and assistance.
>>>>>>> > Best regards,
>>>>>>> > Tchakorom Medane
>>>>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!Ye7A4fqD5xLobOPjgvYkh9cj1-JExIqX_EJIHFm-NHw5rEk2PU5kvs3GfKlJd2TZPorWhvb0Jh7eTcKii9t7Z7tgYSIoeSHTcquicPKi$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!Ye7A4fqD5xLobOPjgvYkh9cj1-JExIqX_EJIHFm-NHw5rEk2PU5kvs3GfKlJd2TZPorWhvb0Jh7eTcKii9t7Z7tgYSIoeSHTcjygY4TU$ >
>>>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250128/8be1c893/attachment-0001.html>
