[petsc-users] fortran TYPE IS statement vs petsc index set IS
Barry Smith
bsmith at petsc.dev
Sun Jan 26 19:11:43 CST 2025
Or, simpler, you can just use is() in lower case for the Fortran is.
Barry
> On Jan 26, 2025, at 7:11 PM, Barry Smith <bsmith at petsc.dev> wrote:
> Sorry for the delay in responding.
> The easiest way is to simply skip the #include "petsc/finclude/petscksp.h" and use type(tIS) instead of IS.
> Explanation: the #include "petsc/finclude/petscksp.h" defines a few macros to make the current PETSc Fortran API look like the old PETSc API. For example
> #define IS type(tIS)
> Barry
>> On Jan 23, 2025, at 3:16 AM, Klaij, Christiaan via petsc-users <petsc-users at mcs.anl.gov> wrote:
>> In fortran I'm using the following structure to check the type of
>> an incoming variable:
>> SELECT TYPE (myvar)
>> TYPE IS (mytype)
>> END SELECT
>> Here IS is a fortan intrinsic, so far so good. However, when I
>> add a petsc index set as follows
>> use petscksp, only: tIS
>> IS :: myIS
>> the compiler gets confused and thinks that the intrinsic fortran
>> IS is the petsc index set IS, and errors-out on the SELECT
>> TYPE:
>> error #8245: SELECT TYPE statement must be immediately followed by CLASS IS, TYPE IS, CLASS DEFAULT or END SELECT statement.
>> SELECT TYPE (myvar)
>> error #6410: This name has not been declared as an array or a function. [TYPE]
>> TYPE type(tIS) (mytype)
>> compilation aborted
>> What would be the right way to deal with this problem?
>> <image870949.png>
>> dr. ir.
>> Christiaan
>> Klaij
>> Senior Researcher
>> Research & Development
>> T +31 317 49 33 44 <tel:+31%20317%2049%2033%2044>
>> C.Klaij at marin.nl <mailto:C.Klaij at marin.nl>
>> | https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!dPFI3QMmP_EuU0rMN41EuTIWIgbY1PFACvkhrCPOh9oKU26ve6P1d3thlPG95YAu9kEYXP5WACupHiH-gOAafpQ$ <https://urldefense.us/v3/__https://www.marin.nl/__;!!G_uCfscf7eWS!ci7RiI8WEqh81becsu6CMRqmK1It91JWMStWzWcFLARdy0n8d2WiqmINXWd-0992Ex6wcTfqupvy9nnMVdrITEk$>
>> <image753651.png> <https://urldefense.us/v3/__https://www.facebook.com/marin.wageningen__;!!G_uCfscf7eWS!ci7RiI8WEqh81becsu6CMRqmK1It91JWMStWzWcFLARdy0n8d2WiqmINXWd-0992Ex6wcTfqupvy9nnMJEayozg$>
>> <image316694.png> <https://urldefense.us/v3/__https://www.linkedin.com/company/marin__;!!G_uCfscf7eWS!ci7RiI8WEqh81becsu6CMRqmK1It91JWMStWzWcFLARdy0n8d2WiqmINXWd-0992Ex6wcTfqupvy9nnMHWYJziY$>
>> <image966725.png> <https://urldefense.us/v3/__https://www.youtube.com/marinmultimedia__;!!G_uCfscf7eWS!ci7RiI8WEqh81becsu6CMRqmK1It91JWMStWzWcFLARdy0n8d2WiqmINXWd-0992Ex6wcTfqupvy9nnMGp7QgsM$>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250126/b58ef71a/attachment-0002.html>
