[petsc-users] Vector 'Vec_0x84000002_0' (argument #1) was locked for read-only access
Zou, Ling
lzou at anl.gov
Mon Jan 20 12:02:04 CST 2025
I figure that it is most likely related to using VecGetArrayRead/VecRestoreArrayRead in one of the places.
I will update later.
-Ling
From: petsc-users <petsc-users-bounces at mcs.anl.gov> on behalf of Zou, Ling via petsc-users <petsc-users at mcs.anl.gov>
Date: Monday, January 20, 2025 at 9:27 AM
To: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: [petsc-users] Vector 'Vec_0x84000002_0' (argument #1) was locked for read-only access
Hi all,
I updated PETSc to 3.22.1, and now my code run with the following error message.
Any idea this may happen?
In the entire code, VecGetArray() are used in the following places:
void
PETScApp::setupPETScIC()
PetscScalar *uu;
VecGetArray(u, &uu);
_sim->setupPETScIC(uu);
VecRestoreArray(u, &uu);
PetscErrorCode
snesFormFunction(SNES /*snes*/, Vec u, Vec f, void * appCtx)
PETScApp * petscApp = (PETScApp *)appCtx;
// zero out residuals
VecZeroEntries(petscApp->res_tran);
VecZeroEntries(petscApp->res_spatial);
// get vectors
PetscScalar *uu, *res_tran, *res_spatial;
VecGetArray(petscApp->res_tran, &res_tran);
VecGetArray(petscApp->res_spatial, &res_spatial);
// use the most updated solution vector to update solution, to compute RHS and transient residuals
petscApp->_sim->updateSolutions(uu);
petscApp->_sim->updateAuxVariables();
petscApp->_sim->computeTranRes(res_tran);
petscApp->_sim->computeSpatialRes(res_spatial);
// restore vectors
VecRestoreArray(petscApp->res_tran, &res_tran);
VecRestoreArray(petscApp->res_spatial, &res_spatial);
// assemble final residuals: f = transient + spatial
VecWAXPY(f, 1.0, petscApp->res_tran, petscApp->res_spatial);
PetscFunctionReturn(PETSC_SUCCESS);
PS: PETSc is available provided by moose env.
-Ling
Time Step 1, time = 0.1, dt = 0.1
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Object is in wrong state
[0]PETSC ERROR: Vector 'Vec_0x84000002_0' (argument #1) was locked for read-only access in unknown_function() at unknown file:0 (line numbers only accurate to function begin)
[0]PETSC ERROR: WARNING! There are unused option(s) set! Could be the program crashed before usage or a spelling mistake, etc!
[0]PETSC ERROR: Option left: name:-i value: tests/hc1d.i source: command line
[0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!bjh67AIY-WYl8pcVpuVi-UdwrQxTomz89NwYOxn0UDPGEvYcI6GtB_u6hcnYtFefPp2i1egt6PykZOxvSZo$ <https://urldefense.us/v3/__https:/petsc.org/release/faq/__;!!G_uCfscf7eWS!afeyp9qigjd3lpaTTPGFhRudAAw-yvYL974yeq5bR6xXsoGjkjeuvOHT8IxSXBtbGT-ULg-27kGV3D9K5Mo$> for trouble shooting.
[0]PETSC ERROR: Petsc Development GIT revision: unknown GIT Date: unknown
[0]PETSC ERROR: ./open_phase-opt with 1 MPI process(es) and PETSC_ARCH on CSI365324.local by lingzou Mon Jan 20 09:20:20 2025
[0]PETSC ERROR: Configure options: --with-64-bit-indices --with-cxx-dialect=C++17 --with-debugging=no --with-fortran-bindings=0 --with-mpi=1 --with-openmp=1 --with-strict-petscerrorcode=1 --with-shared-libraries=1 --with-sowing=0 --download-fblaslapack=1 --download-hpddm=1 --download-hypre=1 --download-metis=1 --download-mumps=1 --download-ptscotch=1 --download-parmetis=1 --download-scalapack=1 --download-slepc=1 --download-strumpack=1 --download-superlu_dist=1 --with-hdf5-dir=/Users/lingzou/miniforge/envs/moose --with-make-np=8 --COPTFLAGS=-O3 --CXXOPTFLAGS=-O3 --FOPTFLAGS=-O3 --with-x=0 --with-ssl=0 --with-mpi-dir=/Users/lingzou/miniforge/envs/moose AR=arm64-apple-darwin20.0.0-ar RANLIB=arm64-apple-darwin20.0.0-ranlib CFLAGS="-ftree-vectorize -fPIC -fstack-protector-strong -O2 -pipe -isystem /Users/lingzou/miniforge/envs/moose/include -fdebug-prefix-map=/opt/civet0/build_0/_env/conda-bld/moose-mpi_1735973237402/work=/usr/local/src/conda/moose-mpi-base-2024.12.23 -fdebug-prefix-map=/Users/lingzou/miniforge/envs/moose=/usr/local/src/conda-prefix " CXXFLAGS="-ftree-vectorize -fPIC -fstack-protector-strong -O2 -pipe -stdlib=libc++ -fvisibility-inlines-hidden -fmessage-length=0 -isystem /Users/lingzou/miniforge/envs/moose/include -fdebug-prefix-map=/opt/civet0/build_0/_env/conda-bld/moose-mpi_1735973237402/work=/usr/local/src/conda/moose-mpi-base-2024.12.23 -fdebug-prefix-map=/Users/lingzou/miniforge/envs/moose=/usr/local/src/conda-prefix " CPPFLAGS="-D_FORTIFY_SOURCE=2 -isystem /Users/lingzou/miniforge/envs/moose/include -mmacosx-version-min=11.3 " FFLAGS="-march=armv8.3-a -ftree-vectorize -fPIC -fno-stack-protector -O2 -pipe -isystem /Users/lingzou/miniforge/envs/moose/include -fdebug-prefix-map=/opt/civet0/build_0/_env/conda-bld/moose-mpi_1735973237402/work=/usr/local/src/conda/moose-mpi-base-2024.12.23 -fdebug-prefix-map=/Users/lingzou/miniforge/envs/moose=/usr/local/src/conda-prefix " FCFLAGS="-march=armv8.3-a -ftree-vectorize -fPIC -fno-stack-protector -O2 -pipe -isystem /Users/lingzou/miniforge/envs/moose/include -fdebug-prefix-map=/opt/civet0/build_0/_env/conda-bld/moose-mpi_1735973237402/work=/usr/local/src/conda/moose-mpi-base-2024.12.23 -fdebug-prefix-map=/Users/lingzou/miniforge/envs/moose=/usr/local/src/conda-prefix " LDFLAGS="-Wl,-headerpad_max_install_names -Wl,-rpath,/Users/lingzou/miniforge/envs/moose/lib -L/Users/lingzou/miniforge/envs/moose/lib -Wl,-ld_classic -Wl,-commons,use_dylibs" --prefix=/Users/lingzou/miniforge/envs/moose/petsc
[0]PETSC ERROR: #1 VecSetErrorIfLocked() at /opt/civet0/build_0/_env/conda-bld/moose-petsc_1735976555173/work/include/petscvec.h:649
[0]PETSC ERROR: #2 VecGetArray() at /opt/civet0/build_0/_env/conda-bld/moose-petsc_1735976555173/work/src/vec/vec/interface/rvector.c:2020
NL Step = 0, fnorm = 1.10935E+30
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250120/9c4f3bb4/attachment-0001.html>
