[petsc-users] Update DMDA attached to DMSWARM
Matthew Knepley
knepley at gmail.com
Wed Jan 15 09:48:52 CST 2025
On Wed, Jan 15, 2025 at 10:41 AM MIGUEL MOLINOS PEREZ <mmolinos at us.es>
wrote:
> Thank you Matt.
> Yes, I am getting the "CellDM" from the DMSwarm.
> 1. I have recently overhauled this functionality because it was not
> flexible enough for the plasma simulation we do. Thus main and release work
> differently.
> Nice to hear that. Should I move to main?
The changes allow you to have several cell DMs. I want to bin particles in
space, but also in velocity, and then in the tensor product of space and
velocity. Moreover, sometimes I want to use different Swarm fields as the
DM field for the solver. You can do all that with main now. If you just
need a single DM with the same DM fields, release is fine.
> 2. I assume you are using release
> You are correct.
> 3. In both main and release, if you change the coordinates of your CellDM
> mesh, you need to rebin the particles. The easiest way to do this is to
> call DMSwarmMigrate(sw, PETSC_FALSE).
> What do you mean by rebin?
When you provide the cell DM, Swrm makes a "sort context" that bins the
particles into DM cells. If you change the coordinates, this binning will
change, so you need it to "rebin" or recreate the sort context.
Matt
> Miguel
> Thanks,
> Matt
>> Best,
>> Miguel
> experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!cs7VQs2Vvv3qqKf-bK_QjlnDN84TOjBUPDxytpXpB_UrrHMrPPxBGKpOPYbAimaxa64C4W_zvOSRIFCoE9Uo$
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!cs7VQs2Vvv3qqKf-bK_QjlnDN84TOjBUPDxytpXpB_UrrHMrPPxBGKpOPYbAimaxa64C4W_zvOSRIKc86v-Q$ >
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!cs7VQs2Vvv3qqKf-bK_QjlnDN84TOjBUPDxytpXpB_UrrHMrPPxBGKpOPYbAimaxa64C4W_zvOSRIFCoE9Uo$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!cs7VQs2Vvv3qqKf-bK_QjlnDN84TOjBUPDxytpXpB_UrrHMrPPxBGKpOPYbAimaxa64C4W_zvOSRIKc86v-Q$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250115/55bb1314/attachment-0001.html>
