[petsc-users] configure: Include urlopen exception string in download failure message
Satish Balay balay.anl at fastmail.org
Tue Jan 14 09:51:18 CST 2025
Last I visited this issue - its a python version issue. i.e newer versions [3.8+? 3.10+?] don't suppress this message - so it comes up in configure printed message.
Perhaps you can verify if this true for the issue you are seeing.
Satish
On Tue, 14 Jan 2025, Aagaard, Brad T via petsc-users wrote:
> The current implementation of Retrival.tarballRetrieve() does not capture the error string from an exception raised in a call to urlopen(). This makes it difficult to diagnose download failures. Can you add the error string from the exception to the download failure message (maybe as an optional argument to getDownloadFailureMessage())? This is at lines 205-208 of config/BuildSystem/retrieval.py.
> Thanks,
> Brad
