[petsc-users] Reproducibility when restarting generalized-alpha
David Kamensky david at coreform.com
Fri Jan 3 18:46:23 CST 2025
Just to provide an update here, the conclusion of our internal discussion
was to backlog this on our end for now, in favor of more urgent tasks.
Perhaps we can open an issue for this on the PETSc issue tracker (or
comment on an existing issue for BDF, if it exists), and I can check in
there if/when we come back to it.
Thanks, David
On Thu, Jan 2, 2025 at 7:02 PM Barry Smith <bsmith at petsc.dev> wrote:
>   Sure, I was suggesting you might implement it for your one-needed
> TSView_*/TSLoad_*. With a single template done we can easily add the rest.
>   I agree having an API to start with multiple solutions is a good idea
> and would be needed for any TSView_*/TSLoad_*. so that may be the simplest
> way for you to get started.  Or we can look at providing the new API if it
> is out of scope for you.
>   Barry
> On Jan 2, 2025, at 5:47 PM, David Kamensky <david at coreform.com> wrote:
> Are you up to trying this by adding this functionality to
>> TSView_*/TSLoad_*, or should we try to fit in time to add this (needed)
>> support?
> I'll have to consult with the team to decide what direction we want to
> go.  We may want to keep our restart data in a neutral format to support
> other uses of it (e.g., solution postprocessing), or to maintain
> consistency and interoperability with some of our non-PETSc time steppers
> (so that we can, e.g., restart from an intermediate step of a PETSc `TS`
> using a non-PETSc integrator).  If we do stick with our more manual
> re-initialization of the `TS`, it might be preferable for us to implement
> an initialization option that allows us to provide an acceleration.  (This
> would be useful even for purposes other than restarting, if a user has a
> cheaper problem-specific method for computing the initial acceleration,
> e.g., inverting a mass matrix against the initial configuration's force
> vector.)
> In any case, getting consistent view/load behavior across all time
> integrators and testing it thoroughly would be significantly larger in
> scope than what we need.
> Best, David
> On Thu, Jan 2, 2025 at 2:16 PM Barry Smith <bsmith at petsc.dev> wrote:
>>   David,
>>     I think Stefano was saying the TSView/Load approach should be
>> improved to save the additional vector(s) and use them in the restart.
>> support?
>>     Barry
>> On Jan 2, 2025, at 2:34 PM, David Kamensky via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>> How are you currently restarting the simulation?
>> I just reviewed the code, and we're not currently using the `TSView/Load`
>> functions.  We're just manually (de)serializing displacement, velocity, and
>> acceleration data using a neutral format, populating PETSc `Vec`s with this
>> data, and associating them with a new `TS` object via `TS2SetSolution` (and
>> setting other relevant data, like time, time step size, etc.).  However,
>> `TS2SetSolution` only accepts displacement and velocity.
>> I think the correct way to handle this is to support storing/loading
>>> these extra vectors via TSView()/TSLoad().
>> I took a quick look at the implementations of `TSView/Load`, and it looks
>> like the "base class" (to borrow some OOP terminology) implementation in
>> `ts/interface/ts.c` only saves/loads the solution vector, while the
>> subclass-specific logic from `TSView_Alpha` in
>> `ts/impls/implicit/alpha/alpha2.c` only adds some additional output writing
>> the generalized-alpha parameters to ASCII viewers (and similar for BDF).
>> So, following the `TSView/Load` path, I don't see where it would even
>> save/load the velocity vector for 2nd-order-in-time integrators.  Is it the
>> case that this functionality is known to be incomplete, and you're
>> suggesting that the best path forward would be to update it?
>> Thanks, David
>> On Thu, Jan 2, 2025 at 10:41 AM Stefano Zampini <
>> stefano.zampini at gmail.com> wrote:
>>> Note that BDF has the same issue. I think the correct way to handle this
>>> is to support storing/loading these extra vectors via TSView()/TSLoad().
>>> Il giorno gio 2 gen 2025 alle ore 19:25 David Kamensky via petsc-users <
>>> petsc-users at mcs.anl.gov> ha scritto:
>>>> Hi,
>>>> I've recently been helping some co-workers with restarting PETSc time
>>>> integrators from saved solution data.
>>>> It looks like the only supported path for restarting the
>>>> generalized-alpha integrator for 2nd-order-in-time systems (`TSALPHA2`) is
>>>> to follow the same procedure as initialization, in which two
>>>> first-order-accurate half-steps are used to estimate an acceleration from
>>>> the given displacement and velocity.  However, the resulting acceleration
>>>> is not exactly equivalent to the intermediate one that would have been used
>>>> by the integrator if the integration simply proceeded without restarting.
>>>> This prevents exact reproducibility of computations from saved intermediate
>>>> results.  (An analogous issue would also affect `TSALPHA` for
>>>> first-order-in-time problems, where velocity is estimated on
>>>> initialization/restart.)
>>>> Am I misunderstanding this, or missing a better method of restarting
>>>> the 2nd-order generalized-alpha integrator?  If not, would there be
>>>> interest in adding an alternate initialization/restart option to the
>>>> `TSALPHA2` integrator that takes a user-provided `Vec` for the
>>>> initial/intermediate acceleration, and skips over the half-step estimation
>>>> procedure?
>>>> Thanks, David
>>> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250103/657886b9/attachment-0001.html>
