[petsc-users] Reproducibility when restarting generalized-alpha
Barry Smith bsmith at petsc.dev
Thu Jan 2 16:16:27 CST 2025
  David,
    I think Stefano was saying the TSView/Load approach should be improved to save the additional vector(s) and use them in the restart.
    Are you up to trying this by adding this functionality to TSView_*/TSLoad_*, or should we try to fit in time to add this (needed) support?
    Barry
> On Jan 2, 2025, at 2:34 PM, David Kamensky via petsc-users <petsc-users at mcs.anl.gov> wrote:
>> How are you currently restarting the simulation?
> I just reviewed the code, and we're not currently using the `TSView/Load` functions.  We're just manually (de)serializing displacement, velocity, and acceleration data using a neutral format, populating PETSc `Vec`s with this data, and associating them with a new `TS` object via `TS2SetSolution` (and setting other relevant data, like time, time step size, etc.).  However, `TS2SetSolution` only accepts displacement and velocity.
>> I think the correct way to handle this is to support storing/loading these extra vectors via TSView()/TSLoad().
> I took a quick look at the implementations of `TSView/Load`, and it looks like the "base class" (to borrow some OOP terminology) implementation in `ts/interface/ts.c` only saves/loads the solution vector, while the subclass-specific logic from `TSView_Alpha` in `ts/impls/implicit/alpha/alpha2.c` only adds some additional output writing the generalized-alpha parameters to ASCII viewers (and similar for BDF).  So, following the `TSView/Load` path, I don't see where it would even save/load the velocity vector for 2nd-order-in-time integrators.  Is it the case that this functionality is known to be incomplete, and you're suggesting that the best path forward would be to update it?
> Thanks, David
> On Thu, Jan 2, 2025 at 10:41 AM Stefano Zampini <stefano.zampini at gmail.com <mailto:stefano.zampini at gmail.com>> wrote:
>> Note that BDF has the same issue. I think the correct way to handle this is to support storing/loading these extra vectors via TSView()/TSLoad().
>> Il giorno gio 2 gen 2025 alle ore 19:25 David Kamensky via petsc-users <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> ha scritto:
>>> Hi,
>>> I've recently been helping some co-workers with restarting PETSc time integrators from saved solution data.
>>> It looks like the only supported path for restarting the generalized-alpha integrator for 2nd-order-in-time systems (`TSALPHA2`) is to follow the same procedure as initialization, in which two first-order-accurate half-steps are used to estimate an acceleration from the given displacement and velocity.  However, the resulting acceleration is not exactly equivalent to the intermediate one that would have been used by the integrator if the integration simply proceeded without restarting.  This prevents exact reproducibility of computations from saved intermediate results.  (An analogous issue would also affect `TSALPHA` for first-order-in-time problems, where velocity is estimated on initialization/restart.)
>>> Am I misunderstanding this, or missing a better method of restarting the 2nd-order generalized-alpha integrator?  If not, would there be interest in adding an alternate initialization/restart option to the `TSALPHA2` integrator that takes a user-provided `Vec` for the initial/intermediate acceleration, and skips over the half-step estimation procedure?
>>> Thanks, David
>> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250102/27178fdb/attachment-0001.html>
