[petsc-users] Configuring PETSc to use a relative RPATH with $ORIGIN
Jed Brown jed at jedbrown.org
Mon Feb 24 11:13:48 CST 2025
I think fixing up the build tools would be more reliable. We can't change paths for libraries that are not installed in the same directory as libpetsc.so. What if we just substituted (perhaps only in the Makefile) $ORIGIN for the $PETSC_DIR/$PETSC_ARCH/lib prefix?
Satish Balay <balay.anl at fastmail.org> writes:
> I see you are referring to https://urldefense.us/v3/__https://www.baeldung.com/linux/rpath-change-in-binary__;!!G_uCfscf7eWS!f7FgqvyBSVkObSDsRA2uRpI9SqxQm_45esiwkTgdj0eKkrGQn5C-j-bU-DR-T7stFHid-jUbqwu9_gXjsiU_4KPp7pg$
> I suspect its easier to do this  by "manually modifying the libraries after their creation" than fix up build tools to support it.
> configure accepts 'LIBS' option that can potentially be used - but I suspect the '$ORIGIN' might not survive different layers
> of shell escapes that might occur.
> ./configure LIBS=-Wl,-rpath,'$ORIGIN'/foo1
> Satish
> On Mon, 24 Feb 2025, Eric Chamberland via petsc-users wrote:
>> Hello,
>> We would like to make the libraries generated from PETSc compilation and
>> installation more easily relocatable. Currently, we work around this
>> limitation by using LD_LIBRARY_PATH in the environment and manually modifying
>> the RPATH recorded in the libraries to remove it.
>> Recently, we discovered an interesting approach: during the build process, we
>> can set a relative RPATH using the $ORIGIN variable, which corresponds to the
>> directory containing the library. This allows libpetsc.so dependencies to be
>> referenced relatively instead of absolutely, making the library "movable"
>> without requiring LD_LIBRARY_PATH modifications. We can also apply the same
>> approach to our binaries.
>> To avoid manually modifying the libraries after their creation, we were
>> wondering if there is a way to configure PETSc to use a relative RPATH with
>> $ORIGIN directly?
>> I looked through PETSc's configuration options and files but couldn't find
>> anything mentioning $ORIGIN, and very little related to RPATH.
>> A SPACK newbie question: is this achievable with SPACK?
>> Thanks in advance for your help!
>> Eric
