[petsc-users] Configuring PETSc to use a relative RPATH with $ORIGIN
Eric Chamberland
Eric.Chamberland at giref.ulaval.ca
Mon Feb 24 10:07:27 CST 2025
Hello,
We would like to make the libraries generated from PETSc compilation and
installation more easily relocatable. Currently, we work around this
limitation by using LD_LIBRARY_PATH in the environment and manually
modifying the RPATH recorded in the libraries to remove it.
Recently, we discovered an interesting approach: during the build
process, we can set a relative RPATH using the $ORIGIN variable, which
corresponds to the directory containing the library. This allows
libpetsc.so dependencies to be referenced relatively instead of
absolutely, making the library "movable" without requiring
LD_LIBRARY_PATH modifications. We can also apply the same approach to
our binaries.
To avoid manually modifying the libraries after their creation, we were
wondering if there is a way to configure PETSc to use a relative RPATH
with $ORIGIN directly?
I looked through PETSc's configuration options and files but couldn't
find anything mentioning $ORIGIN, and very little related to RPATH.
A SPACK newbie question: is this achievable with SPACK?
Thanks in advance for your help!
Eric
Eric Chamberland, ing., M. Ing
Professionnel de recherche
GIREF/Université Laval
(418) 656-2131 poste 41 22 42
