[petsc-users] Info; build petsc-3.20.2 with llvm check fails
Satish Balay balay.anl at fastmail.org
Fri Feb 21 09:38:57 CST 2025
I'm glad you now have a working build!
BTW: Since you have flang installed - a build with it - i.e. with clang/clang++/flang might also work [instead of clang/clang++/gfortran]
However flang usage is still nascent (likely some fortran examples fail with it) -  if you are using PETSc from fortran - a build with gfortran is the preferred option
Satish
On Fri, 21 Feb 2025, Michael Schaferkotter wrote:
> Satish;
> Thank you for the masterful demonstration.
> One of the alternatives caught my eye:   —with-cxx=0 (I remember I had to do that ages ago on my macOS Darwin machine.
> I cleared *FLAGS and successfully completed make && make check as suggested;
> It may be moot now. Here is the requested OS, compiler information:
> cat /etc/os-release
> NAME="Red Hat Enterprise Linux"
> VERSION="8.8 (Ootpa)"
> ID="rhel"
> ID_LIKE="fedora"
> VERSION_ID="8.8"
> PLATFORM_ID="platform:el8"
> PRETTY_NAME="Red Hat Enterprise Linux 8.8 (Ootpa)"
> ANSI_COLOR="0;31"
> CPE_NAME="cpe:/o:redhat:enterprise_linux:8::baseos"
> HOME_URL="https://urldefense.us/v3/__https://www.redhat.com/__;!!G_uCfscf7eWS!Z9OsinaKusqhhdPuDCNknHJq6f6UGZt17SofPYc-BvWQvrlqpeDbEEucEHNxioN04anLOPsjW0v_aCHG5RpV-0tjnQ$ "
> DOCUMENTATION_URL="https://urldefense.us/v3/__https://access.redhat.com/documentation/en-us/red_hat_enterprise_linux/8__;!!G_uCfscf7eWS!Z9OsinaKusqhhdPuDCNknHJq6f6UGZt17SofPYc-BvWQvrlqpeDbEEucEHNxioN04anLOPsjW0v_aCHG5Roh1jkm1w$ "
> BUG_REPORT_URL="https://urldefense.us/v3/__https://bugzilla.redhat.com/__;!!G_uCfscf7eWS!Z9OsinaKusqhhdPuDCNknHJq6f6UGZt17SofPYc-BvWQvrlqpeDbEEucEHNxioN04anLOPsjW0v_aCHG5RpG5qdUaQ$ "
> REDHAT_BUGZILLA_PRODUCT="Red Hat Enterprise Linux 8"
> REDHAT_BUGZILLA_PRODUCT_VERSION=8.8
> REDHAT_SUPPORT_PRODUCT="Red Hat Enterprise Linux"
> REDHAT_SUPPORT_PRODUCT_VERSION="8.8"
> clang version 20.0.0git (https://urldefense.us/v3/__https://github.com/llvm/llvm-project.git__;!!G_uCfscf7eWS!Z9OsinaKusqhhdPuDCNknHJq6f6UGZt17SofPYc-BvWQvrlqpeDbEEucEHNxioN04anLOPsjW0v_aCHG5RoxqM2a5g$  48d0ef1a07993139e1acf65910704255443103a5)
> Target: x86_64-unknown-linux-gnu
> Thread model: posix
> InstalledDir: /tmp/build_release/bin
> Clang version: 20.0.0git
> LLVM version: LLVM version 20.0.0git (48d0ef1a07993139e1acf65910704255443103a5<unknown encoding>
> C++ standard:
> Host target: x86_64-unknown-linux-gnu
> Supported targets:
>   Registered Targets:
>     x86    - 32-bit X86: Pentium-Pro and above
>     x86-64 - 64-bit X86: EM64T and AMD64
> flang version 20.0.0git (https://urldefense.us/v3/__https://github.com/llvm/llvm-project.git__;!!G_uCfscf7eWS!Z9OsinaKusqhhdPuDCNknHJq6f6UGZt17SofPYc-BvWQvrlqpeDbEEucEHNxioN04anLOPsjW0v_aCHG5RoxqM2a5g$  48d0ef1a07993139e1acf65910704255443103a5)
> Thread model: posix
> Flang version: 20.0.0git
> Fortran compiler: GNU Fortran (GCC) 8.5.0 20210514 (Red Hat 8.5.0-4)
> Compiler path: /usr/bin/gfortran
> Version:
>   -std=<standard>          Assume that the input sources are for <standard>.
> Default flags: No default flags information available
> Target: x86_64-redhat-linux
> Thank you again.
> > On Feb 20, 2025, at 2:44 PM, Satish Balay <balay.anl at fastmail.org> wrote:
> > A couple of alternates (if mixing compiler versions can't be avoided):
> > - don't need to use petsc from fortran:
> > [balay at frog petsc]$ ./configure --with-cc=clang --with-cxx=clang++ --with-fc=0 --with-mpi=0 --download-f2cblaslapack && make && make check
> > - don't use c++:
> > [balay at frog petsc]$ ./configure --with-cc=clang --with-cxx=0 --with-fc=gfortran --with-mpi=0 && make && make check
> > - add in v14 -lstdc++ location ahead in the search path - so that even when -lgfortran is found in v11,  v14 -lstdc++ gets picked up correctly.
> > [balay at frog petsc]$ ./configure LDFLAGS=-L/opt/rh/gcc-toolset-14/root/usr/lib/gcc/x86_64-redhat-linux/14/ --with-cc=clang --with-cxx=clang++ --with-fc=gfortran --with-mpi=0 && make && make check
> > Satish
> > On Thu, 20 Feb 2025, Satish Balay wrote:
> >> Ok - I see this issue on CentOS [Stream/9].
> >> What I have is:
> >> [balay at frog petsc]$ clang --version
> >> clang version 19.1.7 (CentOS 19.1.7-1.el9)
> >> Target: x86_64-redhat-linux-gnu
> >> Thread model: posix
> >> InstalledDir: /usr/bin
> >> Configuration file: /etc/clang/x86_64-redhat-linux-gnu-clang.cfg
> >> [balay at frog petsc]$ gfortran --version
> >> GNU Fortran (GCC) 11.5.0 20240719 (Red Hat 11.5.0-5)
> >> Copyright (C) 2021 Free Software Foundation, Inc.
> >> This is free software; see the source for copying conditions.  There is NO
> >> warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
> >> Now I build:
> >> [balay at frog petsc]$ ./configure --with-cc=clang --with-cxx=clang++ --with-fc=gfortran --with-mpi=0 && make && make check
> >> <snip>
> >> clang -fPIC -Wall -Wwrite-strings -Wno-unknown-pragmas -Wconversion -Wno-sign-conversion -Wno-float-conversion -Wno-implicit-float-conversion -fstack-protector -Qunused-arguments -fvisibility=hidden -Wall -Wwrite-strings -Wno-unknown-pragmas -Wconversion -Wno-sign-conversion -Wno-float-conversion -Wno-implicit-float-conversion -fstack-protector -Qunused-arguments -fvisibility=hidden -g3 -O0  -I/home/balay/petsc/include -I/home/balay/petsc/arch-linux-c-debug/include     -Wl,-export-dynamic ex19.c  -Wl,-rpath,/home/balay/petsc/arch-linux-c-debug/lib -L/home/balay/petsc/arch-linux-c-debug/lib -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/11 -L/usr/lib/gcc/x86_64-redhat-linux/11 -lpetsc -llapack -lblas -lm -lX11 -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lstdc++ -o ex19
> >> /opt/rh/gcc-toolset-14/root//usr/lib/gcc/x86_64-redhat-linux/14/../../../../bin/ld: /home/balay/petsc/arch-linux-c-debug/lib/libpetsc.so: undefined reference to `std::__cxx11::basic_string<char, std::char_traits<char>, std::allocator<char> >::_M_replace_cold(char*, unsigned long, char const*, unsigned long, unsigned long)'
> >> <snip>
> >> Ok some v11 compiler libraries are getting mixed up (likely from -lgfortran) causing grief.
> >> [root at frog ~]# yum remove gcc-toolset-14-runtime
> >> Dependencies resolved.
> >> Package                          Arch     Version           Repository    Size
> >> Removing:
> >> gcc-toolset-14-runtime           x86_64   14.0-1.el9        @appstream    11 k
> >> Removing dependent packages:
> >> clang                            x86_64   19.1.7-1.el9      @appstream   181 k
> >> clang-tools-extra                x86_64   19.1.7-1.el9      @appstream    69 M
> >> gcc-toolset-14-binutils          x86_64   2.41-3.el9        @appstream    27 M
> >> Removing unused dependencies:
> >> clang-libs                       x86_64   19.1.7-1.el9      @appstream   413 M
> >> clang-resource-filesystem        x86_64   19.1.7-1.el9      @appstream    15 k
> >> compiler-rt                      x86_64   19.1.7-1.el9      @appstream    37 M
> >> gcc-toolset-14-gcc               x86_64   14.2.1-7.1.el9    @appstream   122 M
> >> gcc-toolset-14-gcc-c++           x86_64   14.2.1-7.1.el9    @appstream    39 M
> >> gcc-toolset-14-libstdc++-devel   x86_64   14.2.1-7.1.el9    @appstream    22 M
> >> libomp                           x86_64   19.1.7-1.el9      @appstream   1.9 M
> >> libomp-devel                     x86_64   19.1.7-1.el9      @appstream    31 M
> >> Transaction Summary
> >> Remove  12 Packages
> >> Freed space: 763 M
> >> Is this ok [y/N]:
> >> So this install of clang depends-on/requires gcc-toolset-14-gcc. Also gfortran-14 is missing. Try installing it.
> >> [root at frog ~]# yum install gcc-toolset-14-gcc-gfortran
> >> Now retry build:
> >> <snip>
> >> Running PETSc check examples to verify correct installation
> >> Using PETSC_DIR=/home/balay/petsc and PETSC_ARCH=arch-linux-c-debug
> >> C/C++ example src/snes/tutorials/ex19 run successfully with 1 MPI process
> >> Fortran example src/snes/tutorials/ex5f run successfully with 1 MPI process
> >> Completed PETSc check examples
> >> Hm - Using gfortran-11 here [with gfortran-14 installed] somehow worked! But perhaps its better to use gfortran-14 [as this install of clang requires g++-14]
> >> [balay at frog petsc]$ export PATH=/opt/rh/gcc-toolset-14/root/usr/bin:$PATH
> >> GNU Fortran (GCC) 14.2.1 20250110 (Red Hat 14.2.1-7)
> >> Copyright (C) 2024 Free Software Foundation, Inc.
> >> <snip>
> >>    CLINKER arch-linux-c-debug/lib/libpetsc.so.3.22.3
> >> Now to check if the libraries are working do:
> >> make PETSC_DIR=/home/balay/petsc PETSC_ARCH=arch-linux-c-debug check
> >> So that worked!
> >> Satish
> >>> Actually, simpler:
> >>> ./configure --with-cc=clang --with-cxx=clang++ --with-fc=gfortran  --with-mpi=0 --download-fblaslapack="$(DIR_SRC)/fblaslapack-$(FBLASLAPACK_VERSION).tar.gz" && make && make check
> >>>> /opt/rh/gcc-toolset-12/root/usr/lib/gcc/x86_64-redhat-linux/12/../../../../bin/ld
> >>> Hm - there was in issue with some (clang versions?) incompatibilities with gcc-12 - I think using gcc-11 (system default in that use case) worked. I'm not sure if you are seeing the same issue here.
> >>> Satish
> >>>> Any particular reason to use these flags? What clang version? OS?
> >>>> Best if you can send build logs [perhaps to petsc-maint]
> >>>> Can you try a simpler build and see if it works:
> >>>> ./configure --with-mpi-dir=/PATH_TO/models/src/v2021.03-2.0.3-llvm --download-fblaslapack="$(DIR_SRC)/fblaslapack-$(FBLASLAPACK_VERSION).tar.gz" && make && make check
> >>>> or:
> >>>> ./configure --with-cc=clang --with-cxx=clang++ --with-fc=gfortran --download-mpich="$(DIR_SRC)/mpich-$(MPICH_VERSION).tar.gz" --download-fblaslapack="$(DIR_SRC)/fblaslapack-$(FBLASLAPACK_VERSION).tar.gz" && make && make check
> >>>> Satish
> >>>> On Thu, 20 Feb 2025, Michael Schaferkotter wrote:
> >>>>> build petsc-3.20.3 with llvm, clang, clang++, gfortran
> >>>>> CFLAGS='-std=c++11'
> >>>>> CXXFLAGS='-std=c++11 -D_GLIBCXX_USE_CXX11_ABI=1'
> >>>>> LDLIBS += -lstdc++
> >>>>> $PETSC_ARCH     arch-linux-c-opt
> >>>>> MPIF90  = ./models/src/v2021.03-2.0.3-llvm/bin/mpif90
> >>>>> MPICC   = ./models/src/v2021.03-2.0.3-llvm/bin/mpicc
> >>>>> CLANG   = clang
> >>>>> FC   = gfortran
> >>>>> Petsc libraries are built;
> >>>>> /models/src/v2021.03-2.0.3-llvm/lib/libpetsc.so@
> >>>>> /models/src/v2021.03-2.0.3-llvm/lib/libpetsc.so.3.020@
> >>>>> /models/src/v2021.03-2.0.3-llvm/lib/libpetsc.so.3.020.3*
> >>>>> The configure is this:
> >>>>>        cd $(PETSC_SRC) && unset CXX CC FC F77 && $(PYTHON2) ./configure --prefix=$(PREFIX) \
> >>>>>  --with-cc=clang \
> >>>>>  --with-cxx=clang++ \
> >>>>>  --with-fc=gfortran \
> >>>>>  --download-mpich="$(DIR_SRC)/mpich-$(MPICH_VERSION).tar.gz" \
> >>>>>  --download-fblaslapack="$(DIR_SRC)/fblaslapack-$(FBLASLAPACK_VERSION).tar.gz" \
> >>>>>  --download-sowing \
> >>>>>  --with-debugging=$(PETSC_DBG) \
> >>>>>  --with-shared-libraries=1 \
> >>>>> CFLAGS='-std=c11' \
> >>>>>  CXXFLAGS='-std=c++11 -D_GLIBCXX_USE_CXX11_ABI=1' \
> >>>>>  CPPFLAGS='-D_GLIBCXX_USE_CXX11_ABI=1' \
> >>>>>  LDFLAGS='-L$(LLVM_LIB)' \
> >>>>>  LIBS='-lstdc++’ \
> >>>>>  --COPTFLAGS=$(COPTFLAGS) --CXXOPTFLAGS=$(CXXOPTFLAGS) --FOPTFLAGS=$(FOPTFLAGS)
> >>>>> Here is the make:
> >>>>>        $(MAKE) -C $(PETSC_SRC) PETSC_DIR=$(PETSC_SRC) PETSC_ARCH=$(PETSC_ARCH) all
> >>>>> Check-petsc is:
> >>>>>        $(MAKE) -C $(PETSC_SRC) PETSC_DIR=$(PETSC_SRC) PETSC_ARCH=$(PETSC_ARCH) test
> >>>>> Here is the log file for test:
> >>>>> make[1]: Entering directory '/models/src/v2021.03-2.0.3-llvm/build/petsc/petsc-3.20.3'
> >>>>> /usr/bin/python3 /models/src/v2021.03-2.0.3-llvm/build/petsc/petsc-3.20.3/config/gmakegentest.py --petsc-dir=/models/src/v2021.03-2.0.3-llvm/build/petsc/petsc-3.20.3 --petsc-arch=arch-linux-c-opt --testdir=./arch-linux-c-opt/tests --srcdir /models/src/v2021.03-2.0.3-llvm/build/petsc/petsc-3.20.3/src --pkg-pkgs "sys vec mat dm ksp snes ts tao"
> >>>>> Using MAKEFLAGS: iw -- PETSC_ARCH=arch-linux-c-opt PETSC_DIR=/models/src/v2021.03-2.0.3-llvm/build/petsc/petsc-3.20.3
> >>>>>         CC arch-linux-c-opt/tests/sys/classes/draw/tests/ex1.o
> >>>>>    CLINKER arch-linux-c-opt/tests/sys/classes/draw/tests/ex1
> >>>>> /opt/rh/gcc-toolset-12/root/usr/lib/gcc/x86_64-redhat-linux/12/../../../../bin/ld: arch-linux-c-opt/lib/libpetsc.so: undefined reference to `std::__cxx11::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
> >>>>> /opt/rh/gcc-toolset-12/root/usr/lib/gcc/x86_64-redhat-linux/12/../../../../bin/ld: arch-linux-c-opt/lib/libpetsc.so: undefined reference to `std::__throw_bad_array_new_length()'
> >>>>> clang: error: linker command failed with exit code 1 (use -v to see invocation)
> >>>>> make[1]: [gmakefile.test:273: arch-linux-c-opt/tests/sys/classes/draw/tests/ex1] Error 1 (ignored)
> >>>>> There are many errors of the ilk:
> >>>>> [lib]$ nm -A libpetsc.so | grep basic_ostringstream
> >>>>> libpetsc.so:                 U _ZNKSt7__cxx1119basic_ostringstreamIcSt11char_traitsIcESaIcEE3strEv at GLIBCXX_3.4.21
> >>>>> libpetsc.so:                 U _ZNSt7__cxx1119basic_ostringstreamIcSt11char_traitsIcESaIcEEC1Ev
> >>>>> libpetsc.so:                 U _ZNSt7__cxx1119basic_ostringstreamIcSt11char_traitsIcESaIcEED1Ev at GLIBCXX_3.4.21
> >>>>> I/m new to llvm and this is the first time to compile petsc.3.20.3 with llvm compilers.
> >>>>> Clearly something is amiss.
> >>>>> Any ideas appreciated.
> >>>>> Michael
