[petsc-users] Info; build petsc-3.20.2 with llvm check fails
Michael Schaferkotter schaferk at bellsouth.net
Thu Feb 20 12:22:24 CST 2025
build petsc-3.20.3 with llvm, clang, clang++, gfortran
CFLAGS='-std=c++11'
CXXFLAGS='-std=c++11 -D_GLIBCXX_USE_CXX11_ABI=1'
LDLIBS += -lstdc++
$PETSC_ARCH     arch-linux-c-opt
MPIF90  = ./models/src/v2021.03-2.0.3-llvm/bin/mpif90
MPICC   = ./models/src/v2021.03-2.0.3-llvm/bin/mpicc
CLANG   = clang
FC   = gfortran
Petsc libraries are built;
/models/src/v2021.03-2.0.3-llvm/lib/libpetsc.so@
/models/src/v2021.03-2.0.3-llvm/lib/libpetsc.so.3.020@
/models/src/v2021.03-2.0.3-llvm/lib/libpetsc.so.3.020.3*
The configure is this:
        cd $(PETSC_SRC) && unset CXX CC FC F77 && $(PYTHON2) ./configure --prefix=$(PREFIX) \
  --with-cc=clang \
  --with-cxx=clang++ \
  --with-fc=gfortran \
  --download-mpich="$(DIR_SRC)/mpich-$(MPICH_VERSION).tar.gz" \
  --download-fblaslapack="$(DIR_SRC)/fblaslapack-$(FBLASLAPACK_VERSION).tar.gz" \
  --download-sowing \
  --with-debugging=$(PETSC_DBG) \
  --with-shared-libraries=1 \
 CFLAGS='-std=c11' \
  CXXFLAGS='-std=c++11 -D_GLIBCXX_USE_CXX11_ABI=1' \
  CPPFLAGS='-D_GLIBCXX_USE_CXX11_ABI=1' \
  LDFLAGS='-L$(LLVM_LIB)' \
  LIBS='-lstdc++’ \
  --COPTFLAGS=$(COPTFLAGS) --CXXOPTFLAGS=$(CXXOPTFLAGS) --FOPTFLAGS=$(FOPTFLAGS)
Here is the make:
        $(MAKE) -C $(PETSC_SRC) PETSC_DIR=$(PETSC_SRC) PETSC_ARCH=$(PETSC_ARCH) all
Check-petsc is:
        $(MAKE) -C $(PETSC_SRC) PETSC_DIR=$(PETSC_SRC) PETSC_ARCH=$(PETSC_ARCH) test
Here is the log file for test:
make[1]: Entering directory '/models/src/v2021.03-2.0.3-llvm/build/petsc/petsc-3.20.3'
/usr/bin/python3 /models/src/v2021.03-2.0.3-llvm/build/petsc/petsc-3.20.3/config/gmakegentest.py --petsc-dir=/models/src/v2021.03-2.0.3-llvm/build/petsc/petsc-3.20.3 --petsc-arch=arch-linux-c-opt --testdir=./arch-linux-c-opt/tests --srcdir /models/src/v2021.03-2.0.3-llvm/build/petsc/petsc-3.20.3/src --pkg-pkgs "sys vec mat dm ksp snes ts tao"
Using MAKEFLAGS: iw -- PETSC_ARCH=arch-linux-c-opt PETSC_DIR=/models/src/v2021.03-2.0.3-llvm/build/petsc/petsc-3.20.3
         CC arch-linux-c-opt/tests/sys/classes/draw/tests/ex1.o
    CLINKER arch-linux-c-opt/tests/sys/classes/draw/tests/ex1
/opt/rh/gcc-toolset-12/root/usr/lib/gcc/x86_64-redhat-linux/12/../../../../bin/ld: arch-linux-c-opt/lib/libpetsc.so: undefined reference to `std::__cxx11::basic_ostringstream<char, std::char_traits<char>, std::allocator<char> >::basic_ostringstream()'
/opt/rh/gcc-toolset-12/root/usr/lib/gcc/x86_64-redhat-linux/12/../../../../bin/ld: arch-linux-c-opt/lib/libpetsc.so: undefined reference to `std::__throw_bad_array_new_length()'
clang: error: linker command failed with exit code 1 (use -v to see invocation)
make[1]: [gmakefile.test:273: arch-linux-c-opt/tests/sys/classes/draw/tests/ex1] Error 1 (ignored)
There are many errors of the ilk:
[lib]$ nm -A libpetsc.so | grep basic_ostringstream
libpetsc.so:                 U _ZNKSt7__cxx1119basic_ostringstreamIcSt11char_traitsIcESaIcEE3strEv at GLIBCXX_3.4.21
libpetsc.so:                 U _ZNSt7__cxx1119basic_ostringstreamIcSt11char_traitsIcESaIcEEC1Ev
libpetsc.so:                 U _ZNSt7__cxx1119basic_ostringstreamIcSt11char_traitsIcESaIcEED1Ev at GLIBCXX_3.4.21
I/m new to llvm and this is the first time to compile petsc.3.20.3 with llvm compilers.
Clearly something is amiss.
Any ideas appreciated.
Michael
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250220/a68c6459/attachment.html>
