[petsc-users] Incoherent data entries in array from a dense sub matrix
Jose E. Roman jroman at dsic.upv.es
Fri Feb 7 05:15:33 CST 2025
This is expected. For dense matrices, MatDenseGetSubMatrix() does not duplicate the memory. You should interpret the array as a two-dimensional column-major array: buffer[i+j*lda] where i,j are row and column indices, and lda can be obtained with MatDenseGetLDA().
Jose
> El 7 feb 2025, a las 11:49, medane.tchakorom at univ-fcomte.fr escribió:
> Re:
> Please find below the output from the previous code, running on only one processor.
> Mat Object: 1 MPI process
>  type: seqdense
> 7.2003197397953400e-01 3.9777780919128602e-01 9.8405227390177075e-01 1.4405427480322786e-01
> 6.1793966542126100e-02 7.3036588248200474e-02 7.3851607000756303e-01 9.9650445216117589e-01
> 1.0022337819588500e-02 1.0386628927366459e-01 4.0114727059134836e-01 1.0677308875937896e-01
> 1.4463931936456476e-01 2.5078039364333193e-01 5.2764865382548720e-01 9.8905332488367748e-01
> buffer[0] = 7.200320e-01
> buffer[1] = 6.179397e-02
> buffer[2] = 1.002234e-02
> buffer[3] = 1.446393e-01
> buffer[4] = 0.000000e+00
> buffer[5] = 0.000000e+00
> buffer[6] = 0.000000e+00
> buffer[7] = 0.000000e+00
> buffer[8] = 3.977778e-01
> buffer[9] = 7.303659e-02
> buffer[10] = 1.038663e-01
> buffer[11] = 2.507804e-01
> buffer[12] = 0.000000e+00
> buffer[13] = 0.000000e+00
> buffer[14] = 0.000000e+00
> buffer[15] = 0.000000e+00
>  type: seqdense
> 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00 0.0000000000000000e+00
> I was expecting to get in “buffer”, only the data entries from R_part. Please, let me know if this is the excepted behavior and I’am missing something.
> Thanks,
> Medane
>> On 7 Feb 2025, at 11:34, Pierre Jolivet <pierre at joliv.et> wrote:
>>> On 7 Feb 2025, at 11:05 AM, medane.tchakorom at univ-fcomte.fr wrote:
>>> Dear all,
>>> I have been experiencing incoherent data entries from this code below, when printing the array. Maybe I’am doing something wrong.
>> What is incoherent?
>> Everything looks OK to me.
>> Thanks,
>> Pierre
>>>   PetscInt nlines = 8; // lines
>>>  PetscInt ncols = 4;  // columns
>>>  PetscMPIInt rank;
>>>  PetscMPIInt size;
>>>  // Initialize PETSc
>>>  PetscCall(PetscInitialize(&argc, &args, NULL, NULL));
>>>  PetscCallMPI(MPI_Comm_rank(MPI_COMM_WORLD, &rank));
>>>  PetscCallMPI(MPI_Comm_size(MPI_COMM_WORLD, &size));
>>>  Mat R_full;
>>>  Mat R_part;
>>>  PetscInt idx_first_row = 0;
>>>  PetscInt idx_one_plus_last_row = nlines / 2;
>>>  PetscCall(MatCreateDense(PETSC_COMM_WORLD, PETSC_DECIDE, PETSC_DECIDE, nlines, ncols, NULL, &R_full));
>>>  // Get sub matrix
>>>  PetscCall(MatDenseGetSubMatrix(R_full, idx_first_row, idx_one_plus_last_row, PETSC_DECIDE, PETSC_DECIDE, &R_part));
>>>  // Add entries to sub matrix
>>>  MatSetRandom(R_part, NULL);
>>>  //View sub matrix
>>>  PetscCall(MatView(R_part, PETSC_VIEWER_STDOUT_WORLD));
>>>  // Get array from sub matrix and print entries
>>>  PetscScalar *buffer;
>>>  PetscCall(MatDenseGetArray(R_part, &buffer));
>>>  PetscInt idx_end = (nlines/2) * ncols;
>>>  for (int i = 0; i < idx_end; i++)
>>>      PetscPrintf(PETSC_COMM_SELF, "buffer[%d] = %e \n", i, buffer[i]);
>>>  //Restore array to sub matrix
>>>  PetscCall(MatDenseRestoreArray(R_part, &buffer));
>>>  // Restore sub matrix
>>>  PetscCall(MatDenseRestoreSubMatrix(R_full, &R_part));
>>>  // View the initial matrix
>>>  PetscCall(MatView(R_full, PETSC_VIEWER_STDOUT_WORLD));
>>>  PetscCall(MatDestroy(&R_full));
>>>  PetscCall(PetscFinalize());
>>>  return 0;
>>> Thanks
>>> Medane
