[petsc-users] Question regarding SNES error about locked vectors
David Knezevic
david.knezevic at akselos.com
Thu Dec 18 07:10:14 CST 2025
Thank you very much for this guidance. I switched to use
SNES_DIVERGED_FUNCTION_DOMAIN, and I don't get any errors now.
Thanks!
David
On Wed, Dec 17, 2025 at 3:43 PM Barry Smith <bsmith at petsc.dev> wrote:
> On Dec 17, 2025, at 2:47 PM, David Knezevic <david.knezevic at akselos.com>
> wrote:
> Stefano and Barry: Thank you, this is very helpful.
> I'll give some more info here which may help to clarify further. Normally
> we do just get a negative "converged reason", as you described. But in this
> specific case where I'm having issues the solve is a numerically sensitive
> creep solve, which has exponential terms in the residual and jacobian
> callback that can "blow up" and give NaN values. In this case, the root
> cause is that we hit a NaN value during a callback, and then we throw an
> exception (in libMesh C++ code) which I gather leads to the SNES solve
> exiting with this error code.
> Is there a way to tell the SNES to terminate with a negative "converged
> reason" because we've encountered some issue during the callback?
> In your callback you should call SNESSetFunctionDomainError() and make
> sure the function value has an infinity or NaN in it (you can call
> VecFlag() for this purpose)).
> Now SNESConvergedReason will be a completely
> reasonable SNES_DIVERGED_FUNCTION_DOMAIN
> Barry
> If you are using an ancient version of PETSc (I hope you are using the
> latest since that always has more bug fixes and features) that does not
> have SNESSetFunctionDomainError then just make sure the function vector
> result has an infinity or NaN in it and then SNESConvergedReason will be
> SNES_DIVERGED_FNORM_NAN
> Thanks,
> David
> On Wed, Dec 17, 2025 at 2:25 PM Barry Smith <bsmith at petsc.dev> wrote:
>> On Dec 17, 2025, at 2:08 PM, David Knezevic via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>> Hi,
>> I'm using PETSc via the libMesh framework, so creating a MWE is
>> complicated by that, unfortunately.
>> The situation is that I am not modifying the solution vector in a
>> callback. The SNES solve has terminated, with PetscErrorCode 82, and I then
>> want to update the solution vector (reset it to the "previously converged
>> value") and then try to solve again with a smaller load increment. This is
>> a typical "auto load stepping" strategy in FE.
>> Once a PetscError is generated you CANNOT continue the PETSc program,
>> it is not designed to allow this and trying to continue will lead to
>> further problems.
>> So what you need to do is prevent PETSc from getting to the point
>> where an actual PetscErrorCode of 82 is generated. Normally SNESSolve()
>> returns without generating an error even if the nonlinear solver failed
>> (for example did not converge). One then uses SNESGetConvergedReason to
>> check if it converged or not. Normally when SNESSolve() returns, regardless
>> of whether the converged reason is negative or positive, there will be no
>> locked vectors and one can modify the SNES object and call SNESSolve again.
>> So my guess is that an actual PETSc error is being generated
>> because SNESSetErrorIfNotConverged(snes,PETSC_TRUE) is being called by
>> either your code or libMesh or the option -snes_error_if_not_converged is
>> being used. In your case when you wish the code to work after a
>> non-converged SNESSolve() these options should never be set instead you
>> should check the result of SNESGetConvergedReason() to check if SNESSolve
>> has failed. If SNESSetErrorIfNotConverged() is never being set that may
>> indicate you are using an old version of PETSc or have it a bug inside
>> PETSc's SNES that does not handle errors correctly and we can help fix the
>> problem if you can provide a full debug output version of when the error
>> occurs.
>> Barry
>> I think the key piece of info I'd like to know is, at what point is the
>> solution vector "unlocked" by the SNES object? Should it be unlocked as
>> soon as the SNES solve has terminated with PetscErrorCode 82? Since it
>> seems to me that it hasn't been unlocked yet (maybe just on a subset of the
>> processes). Should I manually "unlock" the solution vector by
>> calling VecLockWriteSet?
>> Thanks,
>> David
>> On Wed, Dec 17, 2025 at 2:02 PM Stefano Zampini <
>> stefano.zampini at gmail.com> wrote:
>>> You are not allowed to call VecGetArray on the solution vector of an
>>> SNES object within a user callback, nor to modify its values in any other
>>> way.
>>> Put in C++ lingo, the solution vector is a "const" argument
>>> It would be great if you could provide an MWE to help us understand your
>>> problem
>>> Il giorno mer 17 dic 2025 alle ore 20:51 David Knezevic via petsc-users <
>>> petsc-users at mcs.anl.gov> ha scritto:
>>>> Hi all,
>>>> I have a question about this error:
>>>>> Vector 'Vec_0x84000005_0' (argument #2) was locked for read-only
>>>>> access in unknown_function() at unknown file:0 (line numbers only accurate
>>>>> to function begin)
>>>> I'm encountering this error in an FE solve where there is an error
>>>> encountered during the residual/jacobian assembly, and what we normally do
>>>> in that situation is shrink the load step and continue, starting from the
>>>> "last converged solution". However, in this case I'm running on 32
>>>> processes, and 5 of the processes report the error above about a "locked
>>>> vector".
>>>> We clear the SNES object (via SNESDestroy) before we reset the solution
>>>> to the "last converged solution", and then we make a new SNES object
>>>> subsequently. But it seems to me that somehow the solution vector is still
>>>> marked as "locked" on 5 of the processes when we modify the solution
>>>> vector, which leads to the error above.
>>>> I was wondering if someone could advise on what the best way to handle
>>>> this would be? I thought one option could be to add an MPI barrier call
>>>> prior to updating the solution vector to "last converged solution", to make
>>>> sure that the SNES object is destroyed on all procs (and hence the locks
>>>> cleared) before editing the solution vector, but I'm unsure if that would
>>>> make a difference. Any help would be most appreciated!
>>>> Thanks,
>>>> David
>>> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251218/80b18508/attachment-0001.html>
