[petsc-users] Handling inactive (zero-occupancy) equations in large SNES systems
Tue Dec 16 12:23:45 CST 2025
On Tue, Dec 16, 2025 at 12:39 PM MIGUEL MOLINOS PEREZ <mmolinos at us.es>
wrote:
> Dear all,
> I am working with a large nonlinear system solved with SNES, where a
> significant fraction of the unknowns are temporarily inactive due to a
> physical parameter being zero (e.g. zero occupancy / zero weight).
> For those DOF the corresponding equilibrium equation is physically
> inactive, but the unknown still appears in the global vector and in
> couplings of neighboring particles (Im using dmswarm).
> At the moment, these inactive equations contribute with a zero residual
> (F_i=0), which (I think) leads to poor conditioning and convergence issues
> for large problems.
> My question is about best numerical practice in this situation. For the
> position field, should I do something like F_i = q_i - q_(i,n)? Where q_(i,n)
> is the position of the particle at the previous configuration.
This puts a 1 on the diagonal, which is usually what you want (esp for
particle problems).
However, there could be convergence problems with Newton, with these
directions swamping other descent directions. That is the argument for
eliminating these unknowns. It sounds like it would be worth trying to see
if this is the case.
     Matt
> Best regards,
> Miguel
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!a9ge_7Blw6FP4XR8osFatvOvy7Q2pdIyLX8lVZs3eFcKKQhLJ0TRkrPMAXOBllnlR6EP1Oa_qkH_pcJzgpX-$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!a9ge_7Blw6FP4XR8osFatvOvy7Q2pdIyLX8lVZs3eFcKKQhLJ0TRkrPMAXOBllnlR6EP1Oa_qkH_pf-AU3HW$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251216/0c9b52fc/attachment.html>
