[petsc-users] TAO PDIPM handling of objective evaluation failures (NaN / PDE non-convergence)
Simon Wiesheier simon.wiesheier at gmail.com
Thu Dec 4 02:03:22 CST 2025
Dear PETSc developers and users,
I am considering using TAO’s Primal-Dual Interior-Point Method (PDIPM) for
a constrained optimization problem in solid mechanics. The objective
involves solving a nonlinear PDE (hyperelasticity) for each parameter
vector, and for some parameter combinations the PDE solver may fail to
converge or produce non-physical states.
With MATLAB’s fmincon, it is possible to signal such failures by returning
NaN/Inf for the objective, and the solver will then backtrack or try a
different step without crashing.
My questions are:
   1.
   How does TAO’s PDIPM handle cases where the user objective or gradient
   callback returns NaN/Inf (e.g., due to PDE solver failure)?
   2.
   Is there a recommended way in TAO/PETSc to gracefully signal an
   evaluation failure (like “bad point in parameter space”) so that the
   algorithm can back off and try a smaller step, instead of aborting?
   3.
   If the recommended pattern is *not* to return NaNs, what is the best
   practice in TAO for such PDE-constrained problems?
Any guidance on how TAO/PDIPM is intended to behave in the presence of
evaluation failures would be greatly appreciated.
Best regards,
Simon
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20251204/6dd18d47/attachment.html>
