[petsc-users] [MPI][GPU]
Barry Smith bsmith at petsc.dev
Sun Aug 31 09:33:38 CDT 2025
  Ahh, that ex10.c is missing a VecSetFromOptions() call before the VecLoad() and friends. In contrast, the matrix has a MatSetFromOptions(). Can you try adding it to ex10.c and see if that resolves the problem with ex10.c (and may be a path forward for your code)?
  Barry
> On Aug 31, 2025, at 4:32 AM, LEDAC Pierre <Pierre.LEDAC at cea.fr> wrote:
> Yes, but was surprised it was not used, so I removed it (same for -vec_type mpicuda)
> mpirun -np 2 ./ex10 2 -f Matrix_3133717_rows_1_cpus.petsc -ksp_view -log_view -ksp_monitor -ksp_type cg -pc_type hypre -pc_hypre_type boomeramg -pc_hypre_boomeramg_strong_threshold 0.7 -mat_type aijcusparse -vec_type cuda
> WARNING! There are options you set that were not used!
> WARNING! could be spelling mistake, etc!
> There is one unused database option. It is:
> Option left: name:-vec_type value: cuda source: command lin
> Pierre LEDAC
> Commissariat à l’énergie atomique et aux énergies alternatives
> Centre de SACLAY
> DES/ISAS/DM2S/SGLS/LCAN
> Bâtiment 451 – point courrier n°41
> F-91191 Gif-sur-Yvette
> +33 1 69 08 04 03
> +33 6 83 42 05 79
> De : Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>>
> Envoyé : samedi 30 août 2025 21:47:07
> À : LEDAC Pierre
> Cc : petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>
> Objet : Re: [petsc-users] [MPI][GPU]
> Did you try the additional option -vec_type cuda with ex10.c ?
>> On Aug 30, 2025, at 1:16 PM, LEDAC Pierre <Pierre.LEDAC at cea.fr <mailto:Pierre.LEDAC at cea.fr>> wrote:
>> Hello,
>> My code is built with PETSc 3.23+OpenMPI 4.1.6 (Cuda support enabled) and profling indicates that MPI communications are done between GPUs in all the code except PETSc part where D2H transfers occur.
>> I reproduced the PETSc issue with the example under src/ksp/ksp/tutorials/ex10 on 2 MPI ranks. See output in ex10.log
>> Also below the Nsys system profiling on ex10 with D2H and H2D copies before/after MPI calls.
>> Thanks for your help,
>> <pastedImage.png>
>> Pierre LEDAC
>> Centre de SACLAY
>> +33 1 69 08 04 03
>> +33 6 83 42 05 79
>> <ex10.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250831/1ebc61ec/attachment.html>
