[petsc-users] MatCreateSubMatricesMPI strange behavior
Alexis SALZMAN alexis.salzman at ec-nantes.fr
Wed Aug 27 04:14:54 CDT 2025
Hello Pierre,
After applying your patch to my local version of PETSc, all of the cases
that previously caused the provided test to fail are now running
smoothly. In a more complex context (with more processes and colors in
my application), no errors are found and the sub-matrices look OK.
Thank you very much for your time. This debugged function will greatly
simplify the development of my application.
Best regards
A.S.
Le 26/08/2025 à 15:46, Matthew Knepley a écrit :
> On Tue, Aug 26, 2025 at 9:42 AM Pierre Jolivet <pierre at joliv.et> wrote:
>     It’s indeed very suspicious (to me) that we are using rmap to
>     change a column index.
>     Switching to cmap gets your code running, but I’ll need to see if
>     this triggers regressions.
> That looks right to me. I am sure this has only been tested for GASM,
> which would be symmetric.
>   Thanks,
>      Matt
>     Thanks for the report,
>     Pierre
>     diff --git a/src/mat/impls/aij/mpi/mpiov.c
>     b/src/mat/impls/aij/mpi/mpiov.c
>     index d1037d7d817..051981ebe9a 100644
>     --- a/src/mat/impls/aij/mpi/mpiov.c
>     +++ b/src/mat/impls/aij/mpi/mpiov.c
>     @@ -2948,3 +2948,3 @@ PetscErrorCode MatSetSeqMats_MPIAIJ(Mat C,
>     IS rowemb, IS dcolemb, IS ocolemb, Ma
>     -    PetscCall(PetscLayoutGetRange(C->rmap, &rstart, &rend));
>     +    PetscCall(PetscLayoutGetRange(C->cmap, &rstart, &rend));
>          shift      = rend - rstart;
>     $ cat proc_0_output.txt
>     rstart 0 rend 4
>     Mat Object: 3 MPI processes
>       type: mpiaij
>       row 0:   (0, 101.)    (3, 104.)    (6, 107.)  (9, 110.)
>       row 1:   (2, 203.)    (5, 206.)    (8, 209.)  (11, 212.)
>       row 2:   (1, 302.)    (4, 305.)    (7, 308.)  (10, 311.)
>       row 3:   (0, 401.)    (3, 404.)    (6, 407.)  (9, 410.)
>       row 4:   (2, 503.)    (5, 506.)    (8, 509.)  (11, 512.)
>       row 5:   (1, 602.)    (4, 605.)    (7, 608.)  (10, 611.)
>       row 6:   (0, 701.)    (3, 704.)    (6, 707.)  (9, 710.)
>       row 7:   (2, 803.)    (5, 806.)    (8, 809.)  (11, 812.)
>       row 8:   (1, 902.)    (4, 905.)    (7, 908.)  (10, 911.)
>       row 9:   (0, 1001.)    (3, 1004.)    (6, 1007.)  (9, 1010.)
>       row 10:   (2, 1103.)    (5, 1106.)    (8, 1109.)    (11, 1112.)
>       row 11:   (1, 1202.)    (4, 1205.)    (7, 1208.)    (10, 1211.)
>     idxr proc
>     IS Object: 2 MPI processes
>       type: general
>     [0] Number of indices in set 4
>     [0] 0 0
>     [0] 1 1
>     [0] 2 2
>     [0] 3 3
>     [1] Number of indices in set 4
>     [1] 0 4
>     [1] 1 5
>     [1] 2 6
>     [1] 3 7
>     idxc proc
>       type: general
>     [0] Number of indices in set 2
>     [0] 0 0
>     [0] 1 1
>     [1] Number of indices in set 2
>     [1] 0 6
>     [1] 1 7
>     Mat Object: 2 MPI processes
>       type: mpiaij
>       row 0:   (0, 101.)    (2, 107.)
>       row 1:
>       row 2:   (1, 302.)    (3, 308.)
>       row 3:   (0, 401.)    (2, 407.)
>       row 4:
>       row 5:   (1, 602.)    (3, 608.)
>       row 6:   (0, 701.)    (2, 707.)
>       row 7:
>     rstart 0 rend 4
>     local row 0: ( 0 , 1.010000e+02) ( 2 , 1.070000e+02)
>     local row 1:
>     local row 2: ( 1 , 3.020000e+02) ( 3 , 3.080000e+02)
>     local row 3: ( 0 , 4.010000e+02) ( 2 , 4.070000e+02)
>>     On 26 Aug 2025, at 3:18 PM, Pierre Jolivet <pierre at joliv.et> wrote:
>>>     On 26 Aug 2025, at 12:50 PM, Alexis SALZMAN
>>>     <alexis.salzman at ec-nantes.fr> wrote:
>>>     Mark, you were right and I was wrong about the dense matrix.
>>>     Adding explicit zeros to the distributed matrix used to extract
>>>     the sub-matrices (making it dense) in my test does not change
>>>     the behaviour: there is still an error.
>>>     I am finding it increasingly difficult to understand the logic
>>>     of the row and column 'IS' creation. I ran many tests to achieve
>>>     the desired result: a rectangular sub-matrix (so a rectangular
>>>     or square sub-matrix appears to be possible). However, many
>>>     others resulted in the same kind of error.
>>     This may be a PETSc bug in MatSetSeqMats_MPIAIJ().
>>     -> 2965   PetscCall(MatSetValues(aij->B, 1, &row, 1, &col, &v,
>>     INSERT_VALUES));
>>     col has a value of 4, which doesn’t make sense since the output
>>     Mat has 4 columns (thus, has the error message suggests, the
>>     value should be lower than or equal to 3).
>>     Thanks,
>>     Pierre
>>>     From what I observed, the test only works if the column
>>>     selection contribution (size_c in the test) has a specific value
>>>     related to the row selection contribution (size_r in the test)
>>>     for proc 0 (rank for both communicator and sub-communicator):
>>>       * if size_r==2 then if size_c<=2 it works.
>>>       * if size_r>=3 and size_r<=5 then size_c==size_r is the only
>>>         working case.
>>>     This occurs "regardless" of what is requested in proc 1 and in
>>>     selr/selc (It can't be a dummy setting, though). In any case,
>>>     it's certainly not an exhaustive analysis.
>>>     Many thanks to anyone who can explain to me the logic behind the
>>>     construction of row and column 'IS'.
>>>     Regards
>>>     A.S.
>>>     Le 25/08/2025 à 20:00, Alexis SALZMAN a écrit :
>>>>     Thanks Mark for your attention.
>>>>     The uncleaned error message, compared to my post in July, is as
>>>>     follows:
>>>>     [0]PETSC ERROR: --------------------- Error Message
>>>>     [0]PETSC ERROR: Argument out of range
>>>>     [0]PETSC ERROR: Column too large: col 4 max 3
>>>>     [0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!eQa_exf2PCgmMQ0L4h9al-nkWsWRJJ1Zwkjm_qHJsqT0zwLzW7eMjKlkRssc6loRju6u04y4yp9L0U39POoDIvyQKcfmQGUDmdo$
>>>>     <https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!dWBkCu100EMuxu8ooVUnqSFN7OhzOBoNHAiwDYEQ5cJ921sU5hdFb-G24ounZFeUQgZkfWqGRX4iIHyQ-xLQElJst5RbKa2pGnk$>
>>>>     for trouble shooting.
>>>>     [0]PETSC ERROR: Petsc Release Version 3.22.2, unknown
>>>>     [0]PETSC ERROR: subnb with 3 MPI process(es) and PETSC_ARCH  on
>>>>     pc-str97.ec-nantes.fr <https://urldefense.us/v3/__http://pc-str97.ec-nantes.fr__;!!G_uCfscf7eWS!eQa_exf2PCgmMQ0L4h9al-nkWsWRJJ1Zwkjm_qHJsqT0zwLzW7eMjKlkRssc6loRju6u04y4yp9L0U39POoDIvyQKcfm9nWwEJg$ > by salzman
>>>>     Mon Aug 25 19:11:37 2025
>>>>     [0]PETSC ERROR: Configure options:
>>>>     PETSC_ARCH=real_fc41_Release_gcc_i4
>>>>     PETSC_DIR=/home/salzman/devel/ExternalLib/build/PETSC/petsc
>>>>     --doCleanup=1 --with-scalar-type=real --known-level1-dcach
>>>>     e-linesize=64 --with-cc=gcc --CFLAGS="-fPIC "
>>>>     --CC_LINKER_FLAGS=-fopenmp --with-cxx=g++
>>>>     --with-cxx-dialect=c++20 --CXXFLAGS="-fPIC "
>>>>     --CXX_LINKER_FLAGS=-fopenmp --with-fc=gfortran --FFLAGS=
>>>>     "-fPIC " --FC_LINKER_FLAGS=-fopenmp --with-debugging=0
>>>>     --with-fortran-bindings=0 --with-fortran-kernels=1
>>>>     --with-mpi-compilers=0
>>>>     --with-mpi-include=/usr/include/openmpi-x86_64 --with-mpi-li
>>>>     b="[/usr/lib64/openmpi/lib/libmpi.so,/usr/lib64/openmpi/lib/libmpi.so,/usr/lib64/openmpi/lib/libmpi_mpifh.so]"
>>>>     --with-blas-lib="[/opt/intel/oneapi/mkl/latest/lib/libmkl_intel_lp64.so,/opt/i
>>>>     ntel/oneapi/mkl/latest/lib/libmkl_gnu_thread.so,/opt/intel/oneapi/mkl/latest/lib/libmkl_core.so]"
>>>>     --with-lapack-lib="[/opt/intel/oneapi/mkl/latest/lib/libmkl_intel_lp64.so,/opt/intel/oneapi
>>>>     --with-mumps=1
>>>>     --with-mumps-include=/home/salzman/local/i4_gcc/include
>>>>     --with-mumps-lib="[/home/salzma
>>>>     n/local/i4_gcc/lib/libdmumps.so,/home/salzman/local/i4_gcc/lib/libmumps_common.so,/home/salzman/local/i4_gcc/lib/libpord.so]"
>>>>     --with-scalapack-lib="[/opt/intel/oneapi/mkl/latest/lib/libmkl_
>>>>     scalapack_lp64.so,/opt/intel/oneapi/mkl/latest/lib/libmkl_blacs_openmpi_lp64.so]"
>>>>     --with-mkl_pardiso=1
>>>>     --with-mkl_pardiso-include=/opt/intel/oneapi/mkl/latest/include
>>>>     --with-mkl_pardiso-lib
>>>>     ="[/opt/intel/oneapi/mkl/latest/lib/intel64/libmkl_intel_lp64.so]"
>>>>     --with-hdf5=1 --with-hdf5-include=/usr/include/openmpi-x86_64
>>>>     --with-hdf5-lib="[/usr/lib64/openmpi/lib/libhdf5.so]" --with
>>>>     -pastix=0 --download-pastix=no --with-hwloc=1
>>>>     --with-hwloc-dir=/home/salzman/local/i4_gcc --download-hwloc=no
>>>>     --with-ptscotch-include=/home/salzman/local/i4_gcc/include
>>>>     --with-ptscotch-lib=
>>>>     "[/home/salzman/local/i4_gcc/lib/libptscotch.a,/home/salzman/local/i4_gcc/lib/libptscotcherr.a,/home/salzman/local/i4_gcc/lib/libptscotcherrexit.a,/home/salzman/local/i4_gcc/lib/libscotch.a
>>>>     ,/home/salzman/local/i4_gcc/lib/libscotcherr.a,/home/salzman/local/i4_gcc/lib/libscotcherrexit.a]"
>>>>     --with-hypre=1 --download-hypre=yes --with-suitesparse=1
>>>>     --with-suitesparse-include=/home/
>>>>     --with-suitesparse-lib="[/home/salzman/local/i4_gcc/lib/libsuitesparseconfig.so,/home/salzman/local/i4_gcc/lib/libumfpack.so,/home/salzman/local/i4_gcc/lib/libk
>>>>     lu.so,/home/salzman/local/i4_gcc/lib/libcholmod.so,/home/salzman/local/i4_gcc/lib/libspqr.so,/home/salzman/local/i4_gcc/lib/libcolamd.so,/home/salzman/local/i4_gcc/lib/libccolamd.so,/home/s
>>>>     alzman/local/i4_gcc/lib/libcamd.so,/home/salzman/local/i4_gcc/lib/libamd.so,/home/salzman/local/i4_gcc/lib/libmetis.so]"
>>>>     --download-suitesparse=no --with-python-exec=python3.12
>>>>     --have-numpy
>>>>     =1 ---with-petsc4py=1 ---with-petsc4py-test-np=4
>>>>     ---with-mpi4py=1
>>>>     --prefix=/home/salzman/local/i4_gcc/real_arithmetic
>>>>     COPTFLAGS="-O3 -g " CXXOPTFLAGS="-O3 -g " FOPTFLAGS="-O3 -g "
>>>>     [0]PETSC ERROR: #1 MatSetValues_SeqAIJ() at
>>>>     /home/salzman/devel/PETSc/petsc/src/mat/impls/aij/seq/aij.c:426
>>>>     [0]PETSC ERROR: #2 MatSetValues() at
>>>>     /home/salzman/devel/PETSc/petsc/src/mat/interface/matrix.c:1543
>>>>     [0]PETSC ERROR: #3 MatSetSeqMats_MPIAIJ() at
>>>>     /home/salzman/devel/PETSc/petsc/src/mat/impls/aij/mpi/mpiov.c:2965
>>>>     [0]PETSC ERROR: #4 MatCreateSubMatricesMPI_MPIXAIJ() at
>>>>     /home/salzman/devel/PETSc/petsc/src/mat/impls/aij/mpi/mpiov.c:3163
>>>>     [0]PETSC ERROR: #5 MatCreateSubMatricesMPI_MPIAIJ() at
>>>>     /home/salzman/devel/PETSc/petsc/src/mat/impls/aij/mpi/mpiov.c:3196
>>>>     [0]PETSC ERROR: #6 MatCreateSubMatricesMPI() at
>>>>     /home/salzman/devel/PETSc/petsc/src/mat/interface/matrix.c:7293
>>>>     [0]PETSC ERROR: #7 main() at subnb.c:181
>>>>     [0]PETSC ERROR: No PETSc Option Table entries
>>>>     [0]PETSC ERROR: ----------------End of Error Message
>>>>     -------send entire error message to
>>>>     petsc-maint at mcs.anl.gov----------
>>>>     This message comes from executing the attached test (I
>>>>     simplified the test by removing the block size from the matrix
>>>>     used for extraction, compared to the July test). In
>>>>     proc_xx_output.txt, you will find the output from the code
>>>>     execution with the -ok option (i.e. irow/idxr and icol/idxc are
>>>>     the same, i.e. a square sub-block for colour 0 distributed
>>>>     across the first two processes).
>>>>     Has expected in this case we obtain the 0,3,6,9 sub-block
>>>>     terms, which are distributed across processes 0 and 1 (two rows
>>>>     per proc).
>>>>     When asking for rectangular sub-block (i.e. with no option) it
>>>>     crash with column to large on process 0: 4 col max 3 ??? I ask
>>>>     for 4 rows and 2 columns in this process ???
>>>>     Otherwise, I mention the dense aspect of the matrix in ex183.c,
>>>>     because, in this case, no matter what selection is requested,
>>>>     all terms are non-null. If there is an issue with the way the
>>>>     selection is coded in the user program, I think it will be
>>>>     masked thanks to the full graph representation. However, this
>>>>     may not be the case — I should test it.
>>>>     I'll take a look at ex23.c.
>>>>     Thanks,
>>>>     A.S.
>>>>     Le 25/08/2025 à 17:55, Mark Adams a écrit :
>>>>>     Ah, OK, never say never.
>>>>>     MatCreateSubMatrices seems to support creating a new matrix
>>>>>     with the communicator of the IS.
>>>>>     It just needs to read from the input matrix and does not use
>>>>>     it for communication, so it can do that.
>>>>>     As far as rectangular matrices, there is no reason not to
>>>>>     support that (the row IS and column IS can be distinct).
>>>>>     Can you send the whole error message?
>>>>>     There may not be a test that does this,
>>>>>     but src/mat/tests/ex23.c looks like it may be a
>>>>>     rectangular matrix output.
>>>>>     And, it should not matter if the input matrix has a 100% full
>>>>>     sparse matrix. It is still MatAIJ.
>>>>>     The semantics and API is the same for sparse or dense matrices.
>>>>>     Thanks,
>>>>>     Mark
>>>>>     On Mon, Aug 25, 2025 at 7:31 AM Alexis SALZMAN
>>>>>         Hi,
>>>>>         Thanks for your answer, Mark. Perhaps
>>>>>         MatCreateSubMatricesMPI is the only PETSc function that
>>>>>         acts on a sub-communicator — I'm not sure — but it's clear
>>>>>         that there's no ambiguity on that point. The first line of
>>>>>         the documentation for that function states that it 'may
>>>>>         live on subcomms'. This is confirmed by the
>>>>>         'src/mat/tests/ex183.c' test case. I used this test case
>>>>>         to understand the function, which helped me with my code
>>>>>         and the example I provided in my initial post.
>>>>>         Unfortunately, in this example, the matrix from which the
>>>>>         sub-matrices are extracted is dense, even though it uses a
>>>>>         sparse structure. This does not clarify how to define
>>>>>         sub-matrices when extracting from a sparse distributed
>>>>>         matrix. Since my initial post, I have discovered that
>>>>>         having more columns than rows can also result in the same
>>>>>         error message.
>>>>>         So, my questions boil down to:
>>>>>         Can MatCreateSubMatricesMPI extract rectangular matrices
>>>>>         from a square distributed sparse matrix?
>>>>>         If not, the fact that only square matrices can be
>>>>>         extracted in this context should perhaps be mentioned in
>>>>>         the documentation.
>>>>>         If so, I would be very grateful for any assistance in
>>>>>         defining an IS pair in this context.
>>>>>         Regards
>>>>>         A.S.
>>>>>         Le 27/07/2025 à 00:15, Mark Adams a écrit :
>>>>>>         First, you can not mix communicators in PETSc calls in
>>>>>>         general (ever?), but this error looks like you might
>>>>>>         be asking for a row from the matrix that does not exist.
>>>>>>         You should start with a PETSc example code. Test it and
>>>>>>         modify it to suit your needs.
>>>>>>         Good luck,
>>>>>>         Mark
>>>>>>         On Fri, Jul 25, 2025 at 9:31 AM Alexis SALZMAN
>>>>>>             Hi,
>>>>>>             As I am relatively new to Petsc, I may have
>>>>>>             misunderstood how to use the
>>>>>>             MatCreateSubMatricesMPI function. The attached code
>>>>>>             is tuned for three
>>>>>>             processes and extracts one matrix for each colour of
>>>>>>             a subcommunicator
>>>>>>             that has been created using the MPI_Comm_split
>>>>>>             function from an  MPIAij
>>>>>>             matrix. The following error message appears when the
>>>>>>             code is set to its
>>>>>>             default configuration (i.e. when a rectangular matrix
>>>>>>             is extracted with
>>>>>>             more rows than columns for colour 0):
>>>>>>             [0]PETSC ERROR: See
>>>>>>             https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!ZqH097BZ0G0O3WI7RWrwIKFNpyk0czSWEqfusAeTlgEygAffwpgBUzsLw1TIoGkjZ3mYG-NRQxxFoxU4y8EyY0ofiz9I43Qwe0w$
>>>>>>             ... petsc git hash 2a89477b25f compiled on a dell i9
>>>>>>             computer with Gcc
>>>>>>             14.3, mkl 2025.2, .....
>>>>>>             ...petsc/src/mat/impls/aij/seq/aij.c:426
>>>>>>             ...petsc/src/mat/interface/matrix.c:1543
>>>>>>             .../petsc/src/mat/impls/aij/mpi/mpiov.c:2965
>>>>>>             .../petsc/src/mat/impls/aij/mpi/mpiov.c:3163
>>>>>>             .../petsc/src/mat/impls/aij/mpi/mpiov.c:3196
>>>>>>             .../petsc/src/mat/interface/matrix.c:7293
>>>>>>             [0]PETSC ERROR: #7 main() at sub.c:169
>>>>>>             When the '-ok' option is selected, the code extracts
>>>>>>             a square matrix for
>>>>>>             colour 0, which runs smoothly in this case. Selecting
>>>>>>             the '-trans'
>>>>>>             option swaps the row and column selection indices,
>>>>>>             providing a
>>>>>>             transposed submatrix smoothly. For colour 1, which
>>>>>>             uses only one process
>>>>>>             and is therefore sequential, rectangular extraction
>>>>>>             is OK regardless of
>>>>>>             the shape.
>>>>>>             Is this dependency on the shape expected? Have I
>>>>>>             missed an important
>>>>>>             tuning step somewhere?
>>>>>>             Thank you in advance for any clarification.
>>>>>>             Regards
>>>>>>             A.S.
>>>>>>             P.S.: I'm sorry, but as I'm leaving my office for the
>>>>>>             following weeks
>>>>>>             this evening, I won't be very responsive during this
>>>>>>             period.
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!eQa_exf2PCgmMQ0L4h9al-nkWsWRJJ1Zwkjm_qHJsqT0zwLzW7eMjKlkRssc6loRju6u04y4yp9L0U39POoDIvyQKcfmxLsZ-Is$
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!eQa_exf2PCgmMQ0L4h9al-nkWsWRJJ1Zwkjm_qHJsqT0zwLzW7eMjKlkRssc6loRju6u04y4yp9L0U39POoDIvyQKcfmEYm5G4Y$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250827/29bbeef2/attachment-0001.html>
