[petsc-users] subdomain solver options
Anton Popov popov at uni-mainz.de
Tue Aug 26 11:36:18 CDT 2025
There is an important addition, I use asm and bjacobi as smoothers on
multigrid levels.
So I probably need to set the options with -mg_levels_sub_, or
-mg_levels_3_sub_(if they are different on different levels), instead of
just -sub_.
Correct?
Anton
On 26.08.25 18:20, Anton Popov wrote:
> Hi all,
> I have a strange behavior setting the solver options for asm and
> bjacobi blocks.
> Irrespective of what I set with -sub_ksp_ -sub_pc_ it just selects the
> default preonly and ilu options.
> This behavior does not change no matter how many local blocks per cpu
> I try to use, for example with the default one block/cpu it does not
> work as well.
> Is there anything wrong?
> Best,
> Anton
