[petsc-users] Question about Pseudo Time Stepping
Aldo Bonfiglioli aldo.bonfiglioli at unibas.it
Tue Aug 26 03:21:23 CDT 2025
Hi there,
I am using -ts_type pseudo to find steady solutions of the Euler/NS PDEs.
It looks like FormRHSFunction is called twice with the exactly same
value of the dependent variable (u)
before invoking TSRHSJacobianFn and then solving the linear system with
KSP (u is then updated)
> 1 TS dt 0.141197 time 0.141197
> Calling FormRHSFunction; ||u|| =    60.489405479528003
>        463.15635675129079        62.813532026019146
>        5.9789502719351155
>        463.1563567512907962.8135320260191465.9789502719351155
> Calling TSRHSJacobianFn with ||u|| =    60.489405479528003
>        5.9789502719351155
>      Linear solve converged due to CONVERGED_RTOL iterations 9
>    60.489405476878737463.1563567560218662.8135320316169655.9789502710519811
> 2 TS dt 0.155917 time 0.297115
Why is it so? Am I possibly misusing (or missing) some options?
My .petscrc file is attached.
Thank you,
Aldo
Dr. Aldo Bonfiglioli
Associate professor of Fluid Mechanics
Dipartimento di Ingegneria
Universita' della Basilicata
V.le dell'Ateneo Lucano, 10 85100 Potenza ITALY
tel:+39.0971.205203 fax:+39.0971.205215
web:https://urldefense.us/v3/__http://docenti.unibas.it/site/home/docente.html?m=002423__;!!G_uCfscf7eWS!ci_aySHdF2Qx_B-37IOzELFDtcQRthJ2NItK-JNbfXB0M2_21B_z97WIfjxZUyKCVRRhd1mzL6b-rnCed_i8LLA56JvFdz7JBrw$
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250826/d1141c4d/attachment.html>
-dm_plex_dim 2
-dm_plex_filename /home/abonfi/grids/2D/aerofoils/naca0012/euler/gmsh/naca0012.msh
#-dm_plex_filename /home/abonfi/grids/2D/aerofoils/naca0012/euler/gmsh/mesh.h5
-testcase 3
##-dm_view
##-dm_plex_view_labels "marker"
##-dm_plex_view_labels "Face Sets"
-freestream_Mach_number .5
-flow_angles 1.,0.,0.
-dm_mat_type baij
##-Reynolds 1.e39
-colors 4,5,-1,-1,-1,-1
-dm_plex_simplex true
-dm_plex_interpolate
-dm_plex_check_all
-petscpartitioner_view
##-dm_petscsection_view
##-ts_dt 100.
-ts_max_steps 100
-ts_type pseudo
-pc_factor_mat_ordering_type rcm
-pc_factor_reuse_ordering
-ksp_converged_reason
-options_left
##-ksp_view
