[petsc-users] Understanding 'snes' object
Stefano Zampini stefano.zampini at gmail.com
Fri Aug 22 16:41:49 CDT 2025
Il giorno sab 23 ago 2025 alle ore 00:25 Zou, Ling via petsc-users <
petsc-users at mcs.anl.gov> ha scritto:
> Hi all,
> Can someone please help me understand the output of the following two
> outputs using ‘-snes_view’?
> Option 1:
> SNES Object: 1 MPI process
>   type: newtonls
>   maximum iterations=15, maximum function evaluations=10000
>   tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
>   total number of linear solver iterations=5
>   total number of function evaluations=14
>   norm schedule ALWAYS
>   Jacobian is built using finite differences with coloring
> Option 2:
>   type: newtonls
>   maximum iterations=50, maximum function evaluations=10000
>   total number of linear solver iterations=8
>   total number of function evaluations=17
>   Jacobian is applied matrix-free with differencing
>   Preconditioning Jacobian is built using finite differences with coloring
> Does it mean that
>    - Option 1 uses Newton’s method, such that J du = b is solved with J
>    being explicitly constructed?
> yes
>    - Option 2 uses matrix free method, such that J du = b is solved with
>     J v ~ (F(u + dv) – F(u)) / h when needed, e.g., in a Krylov method.
yes, and the preconditioner is constructed using an explicitly constructed
Jacobian matrix
> Thanks,
> -Ling
Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250823/4a210da2/attachment-0001.html>
