[petsc-users] Understanding 'snes' object
Zou, Ling lzou at anl.gov
Fri Aug 22 16:25:34 CDT 2025
Hi all,
Can someone please help me understand the output of the following two outputs using ‘-snes_view’?
Option 1:
SNES Object: 1 MPI process
  type: newtonls
  maximum iterations=15, maximum function evaluations=10000
  tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
  total number of linear solver iterations=5
  total number of function evaluations=14
  norm schedule ALWAYS
  Jacobian is built using finite differences with coloring
Option 2:
  type: newtonls
  maximum iterations=50, maximum function evaluations=10000
  total number of linear solver iterations=8
  total number of function evaluations=17
  Jacobian is applied matrix-free with differencing
  Preconditioning Jacobian is built using finite differences with coloring
Does it mean that
  *   Option 1 uses Newton’s method, such that J du = b is solved with J being explicitly constructed?
  *   Option 2 uses matrix free method, such that J du = b is solved with  J v ~ (F(u + dv) – F(u)) / h when needed, e.g., in a Krylov method.
-Ling
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250822/dd040c38/attachment.html>
