[petsc-users] Inquiry about configuring PETSc with AOCL BLAS/LAPACK
Mon Aug 11 11:44:30 CDT 2025
On Mon, Aug 11, 2025 at 12:32 PM Yongzhong Li <yongzhong.li at mail.utoronto.ca>
wrote:
> Dear PETSc’s developer,
> Hi, I am a user of PETSc. I have some questions about how we can configure
> PETSc with AOCL BLAS and LAPACK.
> Previously, we linked PETSc with Intel MKL BLAS. This solution provides us
> with much better multithreading capability for sparse matrix-vector product
> compared with configuring PETSc with OpenBLAS. Now, our compute nodes have
> been upgraded with AMD CPUs, we are considering switching from Intel MKL to
> AMD AOCL.
> My questions are:
>    1. If we configure PETSc in compile time with *—with-blaslapack-dir =
>    $AOCLROOT*, will we be able to use AOCL BLAS as the backend of PETSc
>    MatMult() API?
Do you mean use the AMD sparse matvec? We have a HIP implementation (
https://urldefense.us/v3/__https://petsc.org/main/manualpages/Mat/MATAIJHIPSPARSE/__;!!G_uCfscf7eWS!buskXbl-Io-3aDFucXGpiYbfFRVN3fRcpRosr-WXF1em8NBn5a8PHltFj0SILAhBQspywGsr9f7BuSqHFfDA$ ), but nothing for
AOCL comparable to the AIJMKL class. If you think we need it, we would
certainly help implement it.
>    1.
>    2. What if AOCL BLAS and AOCL LAPACK are installed in two different
>    directories, not under AOCLROOT?
You would use -with-blaslapack-lib=[liblist]
>    1.
>    2. PETSc has MatAIJMKL type for sparse matrix stored in Intel MKL
>    format. Does PETSc also have another type for AMD AOCL?
No, but it would be straightforward to add.
     Matt
> Thanks!
> Yongzhong
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!buskXbl-Io-3aDFucXGpiYbfFRVN3fRcpRosr-WXF1em8NBn5a8PHltFj0SILAhBQspywGsr9f7BuSj6N8eE$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!buskXbl-Io-3aDFucXGpiYbfFRVN3fRcpRosr-WXF1em8NBn5a8PHltFj0SILAhBQspywGsr9f7BuYXAMWM-$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250811/89440b0a/attachment.html>
