[petsc-users] petsc-users Digest, Vol 200, Issue 3
Sanjay Govindjee s_g at berkeley.edu
Mon Aug 11 11:08:22 CDT 2025
Would a construct like
call VecCreateSeqWithArray(PETSC_COMM_WORLD, nvar, nvar*g%nvl, &
                                [s%res(1,1)] , p%v_res, ierr); CHKERRQ(ierr)
or
                                (/ s%res(1,1) /), p%v_res, ierr);
CHKERRQ(ierr)
be sufficient in this case?
-sanjay
On Mon, Aug 11, 2025 at 7:54 AM Barry Smith <bsmith at petsc.dev> wrote:
>   PETSc now provides Fortran interface definitions in the Fortran modules
> for most PETSc functions. This means the argument types and array
> dimensions of the function must match the expected type and dimension.
>    In this case, the argument s%res(1,1) is likely a scalar while
> VecCreateSeqWithArray is expected to be a one-dimensional array.  You can
> change your code to declare res(1,1) to be a one-dimensional array, or
> possibly use reshape to have the compiler treat it as a one-dimensional
> array when passing it in as an argument.
> On Aug 10, 2025, at 4:12 AM, kiran hegde <kiranhegde75 at gmail.com> wrote:
> Hi,
> The error highlighted is gone, the path to the include file was wrong.
> The code was developed during  petsc-3.9 and it looks like i have to fix
> many of the petsc call functions.
> There are big  changes in  post petsc-3.9.
> Currently, the error shifted to another location in the code:
> for the below line i am getting error:
>                                  s%res(1,1), p%v_res, ierr); CHKERRQ(ierr)
> Error: There is no specific subroutine for the generic
> 'veccreateseqwitharray' at (1)
> Regards,
> Kiran
> On Fri, Aug 8, 2025 at 6:39 AM Barry Smith <bsmith at petsc.dev> wrote:
>>  Please send (cut and paste) all the output of
>>  make ex5f  (should succeed)
>> and
>> make "your code"
>> we need to see the exact calls for both codes and the exact error message.
>> On Aug 5, 2025, at 12:44 AM, kiran hegde <kiranhegde75 at gmail.com> wrote:
>> Hi,
>> Sorry, the tutorial case run succeeded. No errors reported. When i used
>> the makefile file flags in my code, my code is still reported error.
>> Regards,
>> Kiran Hegde
>> Mobile:+91 9972600235
>> On Tue, Aug 5, 2025, 6:11 AM Barry Smith <bsmith at petsc.dev> wrote:
>>>    "I have tried the options ex5f, but getting the same error."
>>>    So you did
>>>     cd src/snes/tutorials/
>>>     make ex5f
>>>     and got some errors? Please cut and paste all the output from make
>>> ex5f and sent it here.
>>> On Aug 4, 2025, at 11:15 AM, kiran hegde <kiranhegde75 at gmail.com> wrote:
>>> Hi Satish,
>>> The code was running without any issues long back and I was using  petsc
>>> ver 3.9 using gcc 12.X.X.
>>> My makefile flags are :
>>> FFLAGS = -march=native -O3 -pipe -ffree-form -cpp
>>> -ffree-line-length-none \
>>>                         -Wall -Wextra -Wtabs -Wintrinsics-std
>>> -Wsurprising -Waliasing \
>>>                         -Wno-unused-parameter -Wno-unused-dummy-argument
>>>                         -D$(MODEL) \
>>>                         -DVERSION=\"$(GIT_VERSION)\" \
>>>                         -I$(PETSC_DIR)/include
>>> FPPFLAGS = -cpp -E -dM -C -P -D$(MODEL)
>>> LDFLAGS = -lpetsc -L$(PETSC_DIR)/lib
>>> LDFLAGS += -Wl,-rpath=$(PETSC_DIR)/lib
>>> Have i missed anything?
>>> Regards,
>>> Kiran
>>> On Sun, Aug 3, 2025 at 9:56 PM Satish Balay <balay.anl at fastmail.org>
>>> wrote:
>>>> On Sun, 3 Aug 2025, kiran hegde wrote:
>>>> > Hi,
>>>> > Please find the attached configure.log file.
>>>> > PETSC installation successfully completes with make check, without any
>>>> > error.
>>>> > But, when compiling fortan codes with   petsc  library+include in the
>>>> > makefile i get this error.
>>>> Then likely your compile command is missing some options. you can:
>>>> - compile a petsc example - say:
>>>> make ex5f
>>>> - now compile your application
>>>> - And compare the compile commands and see if there are any differences
>>>> (missing options, wrong order of include files etc..)
>>>> Satish
>>> Regards,
>>> Kiran Hegde
> Regards,
> Kiran Hegde
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250811/f2e9a9b7/attachment-0001.html>
