[petsc-users] petsc-users Digest, Vol 200, Issue 3
kiran hegde
kiranhegde75 at gmail.com
Sun Aug 10 03:12:53 CDT 2025
The error highlighted is gone, the path to the include file was wrong.
The code was developed during petsc-3.9 and it looks like i have to fix
many of the petsc call functions.
There are big changes in post petsc-3.9.
Currently, the error shifted to another location in the code:
for the below line i am getting error:
call VecCreateSeqWithArray(PETSC_COMM_WORLD, nvar, nvar*g%nvl, &
s%res(1,1), p%v_res, ierr); CHKERRQ(ierr)
Error: There is no specific subroutine for the generic
'veccreateseqwitharray' at (1)
Kiran
On Fri, Aug 8, 2025 at 6:39 AM Barry Smith <bsmith at petsc.dev> wrote:
> Please send (cut and paste) all the output of
> make ex5f (should succeed)
> and
> make "your code"
> we need to see the exact calls for both codes and the exact error message.
> On Aug 5, 2025, at 12:44 AM, kiran hegde <kiranhegde75 at gmail.com> wrote:
> Hi,
> Sorry, the tutorial case run succeeded. No errors reported. When i used
> the makefile file flags in my code, my code is still reported error.
> Regards,
> Kiran Hegde
> Mobile:+91 9972600235
> On Tue, Aug 5, 2025, 6:11 AM Barry Smith <bsmith at petsc.dev> wrote:
>> "I have tried the options ex5f, but getting the same error."
>> So you did
>> cd src/snes/tutorials/
>> make ex5f
>> and got some errors? Please cut and paste all the output from make
>> ex5f and sent it here.
>> On Aug 4, 2025, at 11:15 AM, kiran hegde <kiranhegde75 at gmail.com> wrote:
>> Hi Satish,
>> The code was running without any issues long back and I was using petsc
>> ver 3.9 using gcc 12.X.X.
>> My makefile flags are :
>> FFLAGS = -march=native -O3 -pipe -ffree-form -cpp -ffree-line-length-none
>> -Wall -Wextra -Wtabs -Wintrinsics-std
>> -Wsurprising -Waliasing \
>> -Wno-unused-parameter -Wno-unused-dummy-argument \
>> -D$(MODEL) \
>> -DVERSION=\"$(GIT_VERSION)\" \
>> -I$(PETSC_DIR)/include
>> FPPFLAGS = -cpp -E -dM -C -P -D$(MODEL)
>> LDFLAGS = -lpetsc -L$(PETSC_DIR)/lib
>> LDFLAGS += -Wl,-rpath=$(PETSC_DIR)/lib
>> Have i missed anything?
>> Regards,
>> Kiran
>> On Sun, Aug 3, 2025 at 9:56 PM Satish Balay <balay.anl at fastmail.org>
>> wrote:
>>> On Sun, 3 Aug 2025, kiran hegde wrote:
>>> > Hi,
>>> > Please find the attached configure.log file.
>>> > PETSC installation successfully completes with make check, without any
>>> > error.
>>> > But, when compiling fortan codes with petsc library+include in the
>>> > makefile i get this error.
>>> Then likely your compile command is missing some options. you can:
>>> - compile a petsc example - say:
>>> make ex5f
>>> - now compile your application
>>> - And compare the compile commands and see if there are any differences
>>> (missing options, wrong order of include files etc..)
>>> Satish
>> Regards,
>> Kiran Hegde
Kiran Hegde
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250810/66735f8c/attachment-0001.html>
