[petsc-users] Bug or unexpected behaviour when running petsc+hypre on CPUs
Wed Aug 6 11:39:46 CDT 2025
On Wed, Aug 6, 2025 at 11:53 AM howen via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Dear Sir,
> I am introducing petsc into our fortran + openacc code,
> https://urldefense.us/v3/__https://gitlab.com/bsc_sod2d/sod2d_gitlab__;!!G_uCfscf7eWS!btmKhbl3NeBl7Rgz-znsnwgTYs0aZfcXn-qxj6ei6jgwTQfNYeQ7Rz8De5GhON1QxIqHrvi9CfpPQuwP4t9a$
> <https://urldefense.us/v3/__https://gitlab.com/bsc_sod2d/sod2d_gitlab__;!!G_uCfscf7eWS!f0Y_9okAiFSBeUBOlNplMe6jOCPtdRHfhX2s_rz3N9kCK4OJGiGWGjFyRd3JOwojw7MeNEA-VJtgdn8wBbCmRmJTqdFC$>
> My final objective is to run AMG (Boomer from hypre) on the GPU.
> For the moment I am performing test on the CPU only.
> I run on Marenostrum-V.
> https://urldefense.us/v3/__https://www.bsc.es/supportkc/docs/MareNostrum5/intro/__;!!G_uCfscf7eWS!btmKhbl3NeBl7Rgz-znsnwgTYs0aZfcXn-qxj6ei6jgwTQfNYeQ7Rz8De5GhON1QxIqHrvi9CfpPQqfAlkhq$
> <https://urldefense.us/v3/__https://www.bsc.es/supportkc/docs/MareNostrum5/intro/__;!!G_uCfscf7eWS!f0Y_9okAiFSBeUBOlNplMe6jOCPtdRHfhX2s_rz3N9kCK4OJGiGWGjFyRd3JOwojw7MeNEA-VJtgdn8wBbCmRraUJcUF$>
> I am compiling my code with NVHPC and the support team from BSC has
> compiled petsc + hypre for me.
> In the configuration they used -with-cuda.
> I have run petsc and it works correctly both in serial and parallel on the
> CPU. In my code I use call MatSetType(amat,MATAIJ,ierr).
> I understand this is teh expected behaviour for Petsc.
> That is, that even if one compiles with petsc cuda support one can run
> only on the GPU depending on what one sets in MatSetType.
> Could you confirm that this is the expected behaviour? Instead it seems
> that when petsc+hypre is used one needs to
> compile specific versions for CPU and GPU.
> When trying to use hypre through petsc if one has compiled petsc using
> -with-cuda the run fails.
> From what I have understood this in not the expected behavior. could you
> confirm this?
> Depending of what options I give, the error is different
> If I use
> -pc_type hypre
> -pc_hypre_type boomeramg
> -pc_hypre_boomeramg_coarsen_type hmis
> -pc_hypre_boomeramg_interp_type ext+i
> -pc_hypre_boomeramg_relax_type_all SOR/Jacobi
> -pc_hypre_boomeramg_relax_type_coarse SOR/Jacobi
> -pc_hypre_boomeramg_grid_sweeps_coarse 1
> -pc_hypre_boomeramg_strong_threshold 0.25
> I get
> [0]PETSC ERROR:
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation,
> probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see https://urldefense.us/v3/__https://petsc.org/release/faq/*valgrind__;Iw!!G_uCfscf7eWS!btmKhbl3NeBl7Rgz-znsnwgTYs0aZfcXn-qxj6ei6jgwTQfNYeQ7Rz8De5GhON1QxIqHrvi9CfpPQlAW-NlE$
> <https://urldefense.us/v3/__https://petsc.org/release/faq/*valgrind__;Iw!!G_uCfscf7eWS!f0Y_9okAiFSBeUBOlNplMe6jOCPtdRHfhX2s_rz3N9kCK4OJGiGWGjFyRd3JOwojw7MeNEA-VJtgdn8wBbCmRt2ImXnV$>
> and https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!btmKhbl3NeBl7Rgz-znsnwgTYs0aZfcXn-qxj6ei6jgwTQfNYeQ7Rz8De5GhON1QxIqHrvi9CfpPQnhULpwg$
> <https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!f0Y_9okAiFSBeUBOlNplMe6jOCPtdRHfhX2s_rz3N9kCK4OJGiGWGjFyRd3JOwojw7MeNEA-VJtgdn8wBbCmRjGOi2o3$>
> [0]PETSC ERROR: or try
> https://urldefense.us/v3/__https://docs.nvidia.com/cuda/cuda-memcheck/index.html__;!!G_uCfscf7eWS!btmKhbl3NeBl7Rgz-znsnwgTYs0aZfcXn-qxj6ei6jgwTQfNYeQ7Rz8De5GhON1QxIqHrvi9CfpPQge-ms2z$
> <https://urldefense.us/v3/__https://docs.nvidia.com/cuda/cuda-memcheck/index.html__;!!G_uCfscf7eWS!f0Y_9okAiFSBeUBOlNplMe6jOCPtdRHfhX2s_rz3N9kCK4OJGiGWGjFyRd3JOwojw7MeNEA-VJtgdn8wBbCmRqNF46dV$>
> on NVIDIA CUDA systems to find memory corruption errors
> [0]PETSC ERROR: ---------------------  Stack Frames
> [0]PETSC ERROR: The line numbers in the error traceback are not always
> exact.
> [0]PETSC ERROR: #1 jac->setup()
> [0]PETSC ERROR: #2 PCSetUp_HYPRE() at
> /gpfs/apps/MN5/ACC/PETSC/SRC/petsc-v3.21.0_hypre-debug/src/ksp/pc/impls/hypre/hypre.c:422
> [0]PETSC ERROR: #3 PCSetUp() at
> /gpfs/apps/MN5/ACC/PETSC/SRC/petsc-v3.21.0_hypre-debug/src/ksp/pc/interface/precon.c:1079
> [0]PETSC ERROR: #4 KSPSetUp() at
> /gpfs/apps/MN5/ACC/PETSC/SRC/petsc-v3.21.0_hypre-debug/src/ksp/ksp/interface/itfunc.c:415
> MPI_ABORT was invoked on rank 0 in communicator MPI COMMUNICATOR 3 SPLIT
> FROM 0
> with errorcode 59.
> Which does not help much.
> Instead if I use  only
> -pc_type hypre
> I get
> [0]PETSC ERROR: --------------------- Error Message
> [0]PETSC ERROR: Invalid argument
> [0]PETSC ERROR: HYPRE_MEMORY_DEVICE expects a device vector. You need to
> enable PETSc device support, for example, in some cases, -vec_type cuda
> This helped my realise that hypre was trying to use the GPU despite in my
> code
We try to have a good error message here (If you could give us the code
with the SEGV, we will fix it to give an informative error). This is a
limitation of Hypre, namely that it runs _either_ on the CPU or the GPU,
not both at the same time. Hopefully this will not be the case with a
future release.
     Matt
> Both runs are succesfull when compiling without -with-cuda
> Best,
> Herbert Owen
> Senior Researcher, Dpt. Computer Applications in Science and Engineering
> Barcelona Supercomputing Center (BSC-CNS)
> Tel: +34 93 413 4038
> Skype: herbert.owen
> https://urldefense.us/v3/__https://scholar.google.es/citations?user=qe5O2IYAAAAJ&hl=en__;!!G_uCfscf7eWS!btmKhbl3NeBl7Rgz-znsnwgTYs0aZfcXn-qxj6ei6jgwTQfNYeQ7Rz8De5GhON1QxIqHrvi9CfpPQp3NDHfq$
> <https://urldefense.us/v3/__https://scholar.google.es/citations?user=qe5O2IYAAAAJ&hl=en__;!!G_uCfscf7eWS!f0Y_9okAiFSBeUBOlNplMe6jOCPtdRHfhX2s_rz3N9kCK4OJGiGWGjFyRd3JOwojw7MeNEA-VJtgdn8wBbCmRkKVuPTJ$>
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!btmKhbl3NeBl7Rgz-znsnwgTYs0aZfcXn-qxj6ei6jgwTQfNYeQ7Rz8De5GhON1QxIqHrvi9CfpPQjVmHttn$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!btmKhbl3NeBl7Rgz-znsnwgTYs0aZfcXn-qxj6ei6jgwTQfNYeQ7Rz8De5GhON1QxIqHrvi9CfpPQs5VjyVu$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250806/a30d4d3e/attachment-0001.html>
