[petsc-users] [GPU] Jacobi preconditioner
Junchao Zhang
junchao.zhang at gmail.com
Mon Aug 4 22:27:46 CDT 2025
CUPM is half baked, and only supports Vec and MATDENSE.
--Junchao Zhang
On Mon, Aug 4, 2025 at 7:31 PM Barry Smith <bsmith at petsc.dev> wrote:
> I thought the CUPM code was intended to allow us to have common code
> between NVIDIA and AMD?
> On Jul 31, 2025, at 11:05 AM, Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
> What would embarrass me more is to copy the same code to MatGetDiagonal_
> SeqAIJHIPSPARSE.
> --Junchao Zhang
> On Wed, Jul 30, 2025 at 1:34 PM Barry Smith <bsmith at petsc.dev> wrote:
>> We absolutely should have a MatGetDiagonal_SeqAIJCUSPARSE().
>> It's somewhat embarrassing that we don't provide this.
>> I have found some potential code at
>> https://urldefense.us/v3/__https://stackoverflow.com/questions/60311408/how-to-get-the-diagonal-of-a-sparse-matrix-in-cusparse__;!!G_uCfscf7eWS!azrBQb7GZ-x-aytrnryDJoGQom1TGFZk4Q0BN-DKMOXzaNODwCt5or8ssxWJZb9IxgnQ-uKCTdvZvBX0xN2oESk0qS74$
>> Barry
>> On Jul 28, 2025, at 11:43 AM, Junchao Zhang <junchao.zhang at gmail.com>
>> wrote:
>> Yes, MatGetDiagonal_SeqAIJCUSPARSE hasn't been implemented. petsc/cuda
>> and petsc/kokkos backends are separate code.
>> If petsc/kokkos meet your needs, then just use them. For petsc users, we
>> hope it will be just a difference of extra --download-kokkos
>> --download-kokkos-kernels in configuration.
>> --Junchao Zhang
>> On Mon, Jul 28, 2025 at 2:51 AM LEDAC Pierre <Pierre.LEDAC at cea.fr> wrote:
>>> Hello all,
>>> We are solving with PETSc a linear system updated every time step
>>> (constant stencil but coefficients changing).
>>> The matrix is preallocated once with MatSetPreallocationCOO() then
>>> filled each time step with MatSetValuesCOO() and we use device pointers
>>> for coo_i, coo_j, and coefficients values.
>>> It is working fine with a GMRES Ksp solver and PC Jacobi but we are
>>> surprised to see that every time step, during PCSetUp,
>>> MatGetDiagonal_SeqAIJ is called whereas the matrix is on the device.
>>> Looking at the API, it seems there is no MatGetDiagonal_SeqAIJCUSPARSE()
>>> but a MatGetDiagonal_SeqAIJKOKKOS().
>>> Does it mean we should use Kokkos backend in PETSc to have Jacobi
>>> preconditioner built directly on device ? Or I am doing something wrong ?
>>> NB: Gmres is running well on device.
>>> I could use -ksp_reuse_preconditioner to avoid Jacobi being recreated
>>> each solve on host but it increases significantly the number of iterations.
>>> Thanks,
>>> <pastedImage.png>
>>> Pierre LEDAC
>>> Commissariat à l’énergie atomique et aux énergies alternatives
>>> Centre de SACLAY
>>> DES/ISAS/DM2S/SGLS/LCAN
>>> Bâtiment 451 – point courrier n°41
>>> F-91191 Gif-sur-Yvette
>>> +33 1 69 08 04 03
>>> +33 6 83 42 05 79
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250804/3aacc342/attachment.html>
