[petsc-users] petsc-users Digest, Vol 200, Issue 3
Barry Smith
bsmith at petsc.dev
Mon Aug 4 19:41:21 CDT 2025
"I have tried the options ex5f, but getting the same error."
So you did
cd src/snes/tutorials/
make ex5f
and got some errors? Please cut and paste all the output from make ex5f and sent it here.
> On Aug 4, 2025, at 11:15 AM, kiran hegde <kiranhegde75 at gmail.com> wrote:
> Hi Satish,
> The code was running without any issues long back and I was using petsc ver 3.9 using gcc 12.X.X.
> My makefile flags are :
> FFLAGS = -march=native -O3 -pipe -ffree-form -cpp -ffree-line-length-none \
> -Wall -Wextra -Wtabs -Wintrinsics-std -Wsurprising -Waliasing \
> -Wno-unused-parameter -Wno-unused-dummy-argument \
> -D$(MODEL) \
> -DVERSION=\"$(GIT_VERSION)\" \
> -I$(PETSC_DIR)/include
> FPPFLAGS = -cpp -E -dM -C -P -D$(MODEL)
> LDFLAGS = -lpetsc -L$(PETSC_DIR)/lib
> LDFLAGS += -Wl,-rpath=$(PETSC_DIR)/lib
> Have i missed anything?
> Regards,
> Kiran
> On Sun, Aug 3, 2025 at 9:56 PM Satish Balay <balay.anl at fastmail.org <mailto:balay.anl at fastmail.org>> wrote:
>> On Sun, 3 Aug 2025, kiran hegde wrote:
>> > Hi,
>> > Please find the attached configure.log file.
>> > PETSC installation successfully completes with make check, without any
>> > error.
>> > But, when compiling fortan codes with petsc library+include in the
>> > makefile i get this error.
>> Then likely your compile command is missing some options. you can:
>> - compile a petsc example - say:
>> make ex5f
>> - now compile your application
>> - And compare the compile commands and see if there are any differences (missing options, wrong order of include files etc..)
>> Satish
> Regards,
> Kiran Hegde
> Mobile:+91 9972600235
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250804/b1b2b88c/attachment-0001.html>
