[petsc-users] Error compiling with cuda
Renato E Poli
rpoli at utexas.edu
Sun Aug 3 07:55:42 CDT 2025
Hi Satish,
I could finally compile PETSc, and it seemed to build.
I can compile and CUDA drivers look ok.
However, configure.log shows many errors or potential errors (attached).
Is that supposed to be?
Thank you,
Renato
On Sat, Aug 2, 2025 at 1:48 PM Satish Balay <balay.anl at fastmail.org> wrote:
> On Sat, 2 Aug 2025, Renato E Poli wrote:
> > If I understand correctly, with gfotran I will be able to link to petsc
> > cuda-c++ , but I wont be able to use the fortran cuda interface directly
> > (so I wont be able to write my own gpu-accelerated fortran). Is that
> > correct?
> I think so, nvfortran (with pgf90?) might be the only compiler that
> supports cuda fortran kernels - but will defer to experts here..
> Satish
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250803/0a71fac0/attachment-0001.html>
Type: application/x-gzip
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250803/0a71fac0/attachment-0001.gz>
