[petsc-users] petsc-users Digest, Vol 200, Issue 3
kiran hegde
kiranhegde75 at gmail.com
Sat Aug 2 22:56:07 CDT 2025
Please find the attached configure.log file.
PETSC installation successfully completes with make check, without any
error.
But, when compiling fortan codes with petsc library+include in the
makefile i get this error.
Kiran
On Sat, Aug 2, 2025 at 9:42 PM <petsc-users-request at mcs.anl.gov> wrote:
> Send petsc-users mailing list submissions to
> petsc-users at mcs.anl.gov
> To subscribe or unsubscribe via the World Wide Web, visit
> https://lists.mcs.anl.gov/mailman/listinfo/petsc-users
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> petsc-users-owner at mcs.anl.gov
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of petsc-users digest..."
> Today's Topics:
> 1. missing binary operator before token (kiran hegde)
> 2. Re: missing binary operator before token (Satish Balay)
> 3. Re: Error compiling with cuda (Satish Balay)
> Message: 1
> Date: Sat, 2 Aug 2025 20:51:59 +0530
> From: kiran hegde <kiranhegde75 at gmail.com>
> To: petsc-users at mcs.anl.gov
> Subject: [petsc-users] missing binary operator before token
> Message-ID:
> <CANSMj-4Pwx4sGJ1He8Smzs8qy5B9DbKzFuZAN=
> 1jYciyLHRc_A at mail.gmail.com>
> Content-Type: text/plain; charset="utf-8"
> Hi ,
> I am compiling fortran code using petsc include & lib, but getting
> below error:
> 298 | #if PetscHasAttribute(format) &&
> !defined(PETSC_SKIP_ATTRIBUTE_FORMAT)
> Error: missing binary operator before token '('
> /home/kiranhegde/MyLinuxApplications/Installations/petsc/include/petscmacros.h:330:0:
> 330 | #if PetscHasAttribute(__cold__)
> /home/kiranhegde/MyLinuxApplications/Installations/petsc/include/petscmacros.h:332:0:
> 332 | #elif PetscHasAttribute(cold) /* some implementations (old gcc) use
> no underscores */
> /home/kiranhegde/MyLinuxApplications/Installations/petsc/include/petscmacros.h:355:0:
> no underscores */
> Same errors repeat for many lines and header files
> I am using PETSC at 3.23.4 version with gcc at 15.1.0
> Regards,
> Kiran Hegde
> Mobile:+91 9972600235
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL: <
> http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250802/21975a36/attachment-0001.html
> Message: 2
> Date: Sat, 2 Aug 2025 11:04:17 -0500 (CDT)
> From: Satish Balay <balay.anl at fastmail.org>
> To: kiran hegde <kiranhegde75 at gmail.com>
> Cc: petsc-users at mcs.anl.gov
> Subject: Re: [petsc-users] missing binary operator before token
> Message-ID: <b54479d9-1ffb-2a20-f3c1-f8ca6c3c7071 at fastmail.org>
> Content-Type: text/plain; charset=US-ASCII
> Do you get these errors with 'make check' on a petsc install - or when
> compiling a petsc fortran example (with the corresponding makefile)?
> Satish
> On Sat, 2 Aug 2025, kiran hegde wrote:
> > Hi ,
> > below error:
> use
> > no underscores */
> use
> > no underscores */
> Message: 3
> Date: Sat, 2 Aug 2025 11:11:48 -0500 (CDT)
> To: Renato E Poli <rpoli at utexas.edu>
> Cc: petsc-users <petsc-users at mcs.anl.gov>
> Subject: Re: [petsc-users] Error compiling with cuda
> Message-ID: <e56d2656-8977-b14c-5e70-e7a270ffb046 at fastmail.org>
> Please send configure.log
> presumably you are using a pre-installed mpi from hpc-sdk - that uses NV
> compilers. [and PETSc configure is defaulting to mpicc/mpif90 in PATH]
> If you do not have MPI with gcc/gfortran - you can do something like:
> ./configure --with-cuda=1 --with-cc=gcc --with-cxx=g++ --with-fc=gfortran
> --download-mpich [other options]
> When no options are specified - configure guesses - and picks up what it
> can find - and sometimes that might not be what you intend to use..
> Satish
> On Sat, 2 Aug 2025, Renato E Poli wrote:
> > It seems that the installer is the one choosing to use nvfortran instead
> of
> > gfortran.
> > I am building a docker container (clean environment).
> > I simply install CUDA SDK from
> https://urldefense.us/v3/__https://developer.download.nvidia.com/hpc-sdk/25.5/nvhpc_2025_255_Linux_x86_64_cuda_12.9.tar.gz__;!!G_uCfscf7eWS!cBTymZpXcpFZ7BHpCGxn0ooq_STD1f9CioiFgRypIYNWg9lpwnmLpddrWk0-J-wQoeTw9Ipu2FPm037mQg_C2w$
> > , set paths and call petsc configure.
> > RUN cd petsc-3.23.5 &&\
> > ./configure --prefix=/usr/local/petsc --with-debugging=0 --with-mpi
> > --download-hdf5 --download-hypre --with-blaslapack --with-cuda && \
> > make all && make install
> > Do you see any reason for using the wrong compiler?
> > Renato
> > On Sat, Aug 2, 2025 at 12:28?AM Satish Balay <balay.anl at fastmail.org>
> wrote:
> > > NVFORTRAN (based on flang-17) does not support some F2008 features that
> > > are required here (flang-19+ should work)
> > > Suggest using gfortran instead.
> > > Satish
> > > On Fri, 1 Aug 2025, Renato E Poli wrote:
> > > > Hi,
> > > > I see the error below when compiling with --with-cuda.
> > > > Any suggestion?
> > > > CC arch-linux-c-opt/obj/src/mat/impls/aij/seq/inode2.o
> > > > CC
> arch-linux-c-opt/obj/src/mat/impls/aij/seq/aijperm/aijperm.o
> > > > CC
> > > arch-linux-c-opt/obj/src/mat/impls/aij/seq/mattransposematmult.o
> > > > CC arch-linux-c-opt/obj/src/mat/impls/aij/seq/matptap.o
> > > > CC arch-linux-c-opt/obj/src/mat/impls/aij/seq/matrart.o
> > > > FC arch-linux-c-opt/obj/src/sys/ftn-mod/petscsysmod.o
> > > > NVFORTRAN-S-0034-Syntax error at or near end of line
> (/opt/src/petsc-3.23.5/arch-linux-c-opt/include/../ftn/sys/petscsys.h: 6)
> > > 18)
> > > 30)
> > > 42)
> > > 54)
> > > 65)
> > > 76)
> > > 88)
> > > 100)
> > > 112)
> > > 124)
> > > 136)
> > > 148)
> > > 160)
> (/opt/src/petsc-3.23.5/arch-linux-c-opt/include/../ftn/sys/petscviewer.h: 6)
> > > > 17)
> (/opt/src/petsc-3.23.5/arch-linux-c-opt/include/../ftn/sys/petscoptions.h:
> > > > 6)
> > > > 18)
> > > > 30)
> (/opt/src/petsc-3.23.5/arch-linux-c-opt/include/../ftn/sys/petsclog.h: 5)
> > > 17)
> > > 29)
> (/opt/src/petsc-3.23.5/arch-linux-c-opt/include/../ftn/sys/petscdevice.h: 6)
> > > > 17)
> > > > 0 inform, 0 warnings, 24 severes, 0 fatal for petscsysdef
> Subject: Digest Footer
> End of petsc-users Digest, Vol 200, Issue 3
Kiran Hegde
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250803/60a0bd5f/attachment-0001.html>
Type: text/x-log
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250803/60a0bd5f/attachment-0001.bin>
