[petsc-users] problem with nested logging
    Randall Mackie
    rlmackie862 at gmail.com
    Tue Apr 29 10:21:09 CDT 2025
ah okay, I missed that this was found using openmpi.
then it’s probably not the same issue we had.
I can’t remember in which version it was fixed (I’m away from my work computer)….I do know in our case openmpi and the latest Intel One API work fine.
Randy
> On Apr 29, 2025, at 8:58 AM, Klaij, Christiaan <C.Klaij at marin.nl> wrote:
> Well, the error below only shows-up thanks to openmpi and gnu compilers.
> With the intel mpi and compilers it just hangs (tried oneapi 2023.1.0). In which version was that bug fixed?
> Chris
> <image374583.png>
> dr. ir. 	Christiaan	 Klaij
>  | 	senior researcher	 | 	Research & Development	 | 	CFD Development
> T +31 317 49 33 44 <tel:+31%20317%2049%2033%2044>	 | 	 C.Klaij at marin.nl <mailto:C.Klaij at marin.nl> 	| https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!bW2X4VgowGOLrAASgbFOR_Mh6HW4HtWqrdtpsvpnpiFrIwki34JOGyih-h-1bvgb-Bh4EdWRUoVqQW7s6CzTuZcF2A$  <https://urldefense.us/v3/__https://www.marin.nl/__;!!G_uCfscf7eWS!bW2X4VgowGOLrAASgbFOR_Mh6HW4HtWqrdtpsvpnpiFrIwki34JOGyih-h-1bvgb-Bh4EdWRUoVqQW7s6Cx-ci9iNg$ >
> <image322757.png> <https://urldefense.us/v3/__https://www.facebook.com/marin.wageningen__;!!G_uCfscf7eWS!bW2X4VgowGOLrAASgbFOR_Mh6HW4HtWqrdtpsvpnpiFrIwki34JOGyih-h-1bvgb-Bh4EdWRUoVqQW7s6Cxl-rBbfA$ >
> <image512282.png> <https://urldefense.us/v3/__https://www.linkedin.com/company/marin__;!!G_uCfscf7eWS!bW2X4VgowGOLrAASgbFOR_Mh6HW4HtWqrdtpsvpnpiFrIwki34JOGyih-h-1bvgb-Bh4EdWRUoVqQW7s6Cw7FNelIQ$ >
> <image090879.png> <https://urldefense.us/v3/__https://www.youtube.com/marinmultimedia__;!!G_uCfscf7eWS!bW2X4VgowGOLrAASgbFOR_Mh6HW4HtWqrdtpsvpnpiFrIwki34JOGyih-h-1bvgb-Bh4EdWRUoVqQW7s6CwmfHQRog$ >
> From: Randall Mackie <rlmackie862 at gmail.com>
> Sent: Tuesday, April 29, 2025 3:33 PM
> To: Klaij, Christiaan
> Cc: Matthew Knepley; petsc-users at mcs.anl.gov; Isaac, Toby
> Subject: Re: [petsc-users] problem with nested logging
> You don't often get email from rlmackie862 at gmail.com. Learn why this is important<https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!bW2X4VgowGOLrAASgbFOR_Mh6HW4HtWqrdtpsvpnpiFrIwki34JOGyih-h-1bvgb-Bh4EdWRUoVqQW7s6CwgJDUS5w$ >
> We had a similar issue last year that we eventually tracked down to a bug in Intel MPI AllReduce, which was around the same version you are using.
> Can you try a different MPI or the latest Intel One API and see if your error clears?
> Randy
> On Tue, Apr 29, 2025 at 8:17 AM Klaij, Christiaan via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
> I don't think so, we have tracing in place to detect mismatches. But as soon as I switch the tracing on, the error disappears... Same if I add a counter or print statements before and after EventBegin/End. Looks like a memory corruption problem, maybe nothing to do with petsc despite the error message.
> Chris
> From: Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>>
> Sent: Tuesday, April 29, 2025 1:50 PM
> Cc: Junchao Zhang; petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>; Isaac, Toby
> On Tue, Apr 29, 2025 at 6:50 AM Klaij, Christiaan <C.Klaij at marin.nl<mailto:C.Klaij at marin.nl><mailto:C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>>> wrote:
> Here's a slightly better error message, obtained --with-debugging=1
> Is it possible that you have a mismatched EventBegin()/EventEnd() in your code? That could be why we cannot reproduce it here.
> Thanks,
> Matt
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR: Petsc has generated inconsistent data
> [0]PETSC ERROR: MPIU_Allreduce() called in different locations (code lines) on different processors
> [0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjggvQAzPU$ for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.22.4, Mar 01, 2025
> [0]PETSC ERROR: ./refresco with 2 MPI process(es) and PETSC_ARCH on marclus3login2 by cklaij Tue Apr 29 12:43:54 2025
> [0]PETSC ERROR: Configure options: --prefix=/home/cklaij/ReFRESCO/trunk/install/extLibs --with-mpi-dir=/cm/shared/apps/openmpi/gcc/4.0.2 --with-x=0 --with-mpe=0 --with-debugging=1 --download-superlu_dist=https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/superlu_dist-8.1.2.tar.gz__;!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjgVgVAJPM$ --with-blaslapack-dir=/cm/shared/apps/intel/oneapi/mkl/2021.4.0 --download-parmetis=https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/parmetis-4.0.3-p9.tar.gz__;!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjgo2JWTO4$ --download-metis=https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/metis-5.1.0-p11.tar.gz__;!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjgX9ZMYJA$ --with-packages-build-dir=/home/cklaij/ReFRESCO/trunk/build-libs/superbuild --with-ssl=0 --with-shared-libraries=1
> [0]PETSC ERROR: #1 PetscLogNestedTreePrintLine() at /home/cklaij/ReFRESCO/trunk/build-libs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:289
> [0]PETSC ERROR: #2 PetscLogNestedTreePrint() at /home/cklaij/ReFRESCO/trunk/build-libs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:379
> [0]PETSC ERROR: #3 PetscLogNestedTreePrint() at /home/cklaij/ReFRESCO/trunk/build-libs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:384
> [0]PETSC ERROR: #4 PetscLogNestedTreePrint() at /home/cklaij/ReFRESCO/trunk/build-libs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:384
> [0]PETSC ERROR: #5 PetscLogNestedTreePrintTop() at /home/cklaij/ReFRESCO/trunk/build-libs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:420
> [0]PETSC ERROR: #6 PetscLogHandlerView_Nested_XML() at /home/cklaij/ReFRESCO/trunk/build-libs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:443
> [0]PETSC ERROR: #7 PetscLogHandlerView_Nested() at /home/cklaij/ReFRESCO/trunk/build-libs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/lognested.c:405
> [0]PETSC ERROR: #8 PetscLogHandlerView() at /home/cklaij/ReFRESCO/trunk/build-libs/superbuild/petsc/src/src/sys/logging/handler/interface/loghandler.c:342
> [0]PETSC ERROR: #9 PetscLogView() at /home/cklaij/ReFRESCO/trunk/build-libs/superbuild/petsc/src/src/sys/logging/plog.c:2040
> [0]PETSC ERROR: #10 /home/cklaij/ReFRESCO/trunk/Code/src/petsc_include_impl.F90:130
> [cid:ii_19681617e7812ff9cfc1]
> T +31 317 49 33 44<tel:+31%20317%2049%2033%2044> | C.Klaij at marin.nl<mailto:C.Klaij at marin.nl><mailto:C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>> | https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjgJooxJhg$ <https://urldefense.us/v3/__https://www.marin.nl/__;!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjgpOXjQSM$ >
> [Facebook]<https://urldefense.us/v3/__https://www.facebook.com/marin.wageningen__;!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjg_3Zt0Pw$ >
> [LinkedIn]<https://urldefense.us/v3/__https://www.linkedin.com/company/marin__;!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjgcpgQdSE$ >
> [YouTube]<https://urldefense.us/v3/__https://www.youtube.com/marinmultimedia__;!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjgn8qP6_I$ >
> From: Klaij, Christiaan <C.Klaij at marin.nl<mailto:C.Klaij at marin.nl><mailto:C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>>>
> Sent: Monday, April 28, 2025 3:53 PM
> To: Matthew Knepley
> Cc: Junchao Zhang; petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov><mailto:petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>; Isaac, Toby
> Bisecting would be quite hard, it's not just the petsc version that changed, also other libs, compilers, even os components.
> Chris
> From: Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com><mailto:knepley at gmail.com<mailto:knepley at gmail.com>>>
> Sent: Monday, April 28, 2025 3:06 PM
> You don't often get email from knepley at gmail.com<mailto:knepley at gmail.com><mailto:knepley at gmail.com<mailto:knepley at gmail.com>>. Learn why this is important<https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjgcKEJXRA$ >
> On Mon, Apr 28, 2025 at 8:45 AM Klaij, Christiaan via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov><mailto:petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>><mailto:petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov><mailto:petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>>> wrote:
> I've tried adding a nested log viewer to src/snes/tutorials/ex70.c,
> but it does not replicate the problem and works fine.
> Perhaps it is related to fortran, since the manualpage of
> PetscLogNestedBegin says "No fortran support" (why? we've been
> using it in fortran ever since).
> Therefore I've tried adding it to src/snes/ex5f90.F90 and that
> also works fine. It seems I cannot replicate the problem in a
> small example, unfortunately.
> We cannot replicate it here. Is there a chance you could bisect to see what change is responsible?
> Thanks,
> Matt
> Chris
> From: Junchao Zhang <junchao.zhang at gmail.com<mailto:junchao.zhang at gmail.com><mailto:junchao.zhang at gmail.com<mailto:junchao.zhang at gmail.com>><mailto:junchao.zhang at gmail.com<mailto:junchao.zhang at gmail.com><mailto:junchao.zhang at gmail.com<mailto:junchao.zhang at gmail.com>>>>
> Sent: Saturday, April 26, 2025 3:51 PM
> Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov><mailto:petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>><mailto:petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov><mailto:petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>>; Isaac, Toby
> You don't often get email from junchao.zhang at gmail.com<mailto:junchao.zhang at gmail.com><mailto:junchao.zhang at gmail.com<mailto:junchao.zhang at gmail.com>><mailto:junchao.zhang at gmail.com<mailto:junchao.zhang at gmail.com><mailto:junchao.zhang at gmail.com<mailto:junchao.zhang at gmail.com>>>. Learn why this is important<https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!cmLENZvO_Uydoa8ciUmsyX-F-QiJt9a2ZfQRUvQnRibGm7VE6PED7S_BDsUgjOzvPZIJyiIoJ8bLJk6gVgt1dmE$ >
> Toby (Cc'ed) might know it. Or could you provide an example?
> --Junchao Zhang
> On Fri, Apr 25, 2025 at 3:31 AM Klaij, Christiaan via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov><mailto:petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>><mailto:petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov><mailto:petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>><mailto:petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov><mailto:petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>><mailto:petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov><mailto:petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>>>> wrote:
> We recently upgraded from 3.19.4 to 3.22.4 but face the problem below with the nested logging. Any ideas?
> Chris
> [1]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [1]PETSC ERROR: General MPI error
> [1]PETSC ERROR: MPI error 1 MPI_ERR_BUFFER: invalid buffer pointer
> [1]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!cmLENZvO_Uydoa8ciUmsyX-F-QiJt9a2ZfQRUvQnRibGm7VE6PED7S_BDsUgjOzvPZIJyiIoJ8bLJk6gIT68pbk$ <https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGM3UaqHzc$> for trouble shooting.
> [1]PETSC ERROR: Petsc Release Version 3.22.4, Mar 01, 2025
> [1]PETSC ERROR: refresco with 2 MPI process(es) and PETSC_ARCH on marclus3login2 by jwindt Fri Apr 25 08:52:30 2025
> [1]PETSC ERROR: Configure options: --prefix=/home/jwindt/cmake_builds/refresco/install-libs-gnu --with-mpi-dir=/cm/shared/apps/openmpi/gcc/4.0.2 --with-x=0 --with-mpe=0 --with-debugging=0 --download-superlu_dist=https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/superlu_dist-8.1.2.tar.gz__;!!G_uCfscf7eWS!cmLENZvO_Uydoa8ciUmsyX-F-QiJt9a2ZfQRUvQnRibGm7VE6PED7S_BDsUgjOzvPZIJyiIoJ8bLJk6grH5BbeU$ <https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/superlu_dist-8.1.2.tar.gz__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGM21-2D-o$> --with-blaslapack-dir=/cm/shared/apps/intel/oneapi/mkl/2021.4.0 --download-parmetis=https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/parmetis-4.0.3-p9.tar.gz__;!!G_uCfscf7eWS!cmLENZvO_Uydoa8ciUmsyX-F-QiJt9a2ZfQRUvQnRibGm7VE6PED7S_BDsUgjOzvPZIJyiIoJ8bLJk6gw4-tEtY$ <https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/parmetis-4.0.3-p9.tar.gz__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGMW0lYHko$> --download-metis=https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/metis-5.1.0-p11.tar.gz__;!!G_uCfscf7eWS!cmLENZvO_Uydoa8ciUmsyX-F-QiJt9a2ZfQRUvQnRibGm7VE6PED7S_BDsUgjOzvPZIJyiIoJ8bLJk6gHq4uYiY$ <https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/metis-5.1.0-p11.tar.gz__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGMbSrIiUg$> --with-packages-build-dir=/home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild --with-ssl=0 --with-shared-libraries=1 CFLAGS="-std=gnu11 -Wall -funroll-all-loops -O3 -DNDEBUG" CXXFLAGS="-std=gnu++14 -Wall -funroll-all-loops -O3 -DNDEBUG " COPTFLAGS="-std=gnu11 -Wall -funroll-all-loops -O3 -DNDEBUG" CXXOPTFLAGS="-std=gnu++14 -Wall -funroll-all-loops -O3 -DNDEBUG " FCFLAGS="-Wall -funroll-all-loops -ffree-line-length-0 -Wno-maybe-uninitialized -Wno-target-lifetime -Wno-unused-function -O3 -DNDEBUG" F90FLAGS="-Wall -funroll-all-loops -ffree-line-length-0 -Wno-maybe-uninitialized -Wno-target-lifetime -Wno-unused-function -O3 -DNDEBUG" FOPTFLAGS="-Wall -funroll-all-loops -ffree-line-length-0 -Wno-maybe-uninitialized -Wno-target-lifetime -Wno-unused-function -O3 -DNDEBUG"
> [1]PETSC ERROR: #1 PetscLogNestedTreePrint() at /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:330
> [1]PETSC ERROR: #2 PetscLogNestedTreePrint() at /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:384
> [1]PETSC ERROR: #3 PetscLogNestedTreePrint() at /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:384
> [1]PETSC ERROR: #4 PetscLogNestedTreePrintTop() at /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:420
> [1]PETSC ERROR: #5 PetscLogHandlerView_Nested_XML() at /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:443
> [1]PETSC ERROR: #6 PetscLogHandlerView_Nested() at /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/impls/nested/lognested.c:405
> [1]PETSC ERROR: #7 PetscLogHandlerView() at /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/interface/loghandler.c:342
> [1]PETSC ERROR: #8 PetscLogView() at /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/plog.c:2040
> MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
> with errorcode 98.
> NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
> You may or may not see output from other processes, depending on
> exactly when Open MPI kills them.
> [cid:ii_196725d1e2a809852191]
> T +31 317 49 33 44<tel:+31%20317%2049%2033%2044> | C.Klaij at marin.nl<mailto:C.Klaij at marin.nl><mailto:C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>><mailto:C.Klaij at marin.nl<mailto:C.Klaij at marin.nl><mailto:C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>>><mailto:C.Klaij at marin.nl<mailto:C.Klaij at marin.nl><mailto:C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>><mailto:C.Klaij at marin.nl<mailto:C.Klaij at marin.nl><mailto:C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>>>> | https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!cmLENZvO_Uydoa8ciUmsyX-F-QiJt9a2ZfQRUvQnRibGm7VE6PED7S_BDsUgjOzvPZIJyiIoJ8bLJk6g8TwMMcw$ <https://urldefense.us/v3/__https://www.marin.nl/__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGM8tSNH1g$>
> [Facebook]<https://urldefense.us/v3/__https://www.facebook.com/marin.wageningen__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGMcVCZ9hk$>
> [LinkedIn]<https://urldefense.us/v3/__https://www.linkedin.com/company/marin__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGMIDBZW7k$>
> [YouTube]<https://urldefense.us/v3/__https://www.youtube.com/marinmultimedia__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGMVKWos24$>
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjg539kFLg$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjgMsu6hhA$ >
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250429/719f5e3a/attachment-0001.html>
