[petsc-users] problem with nested logging
    Klaij, Christiaan
    C.Klaij at marin.nl
    Tue Apr 29 08:17:18 CDT 2025
I don't think so, we have tracing in place to detect mismatches. But as soon as I switch the tracing on, the error disappears... Same if I add a counter or print statements before and after EventBegin/End. Looks like a memory corruption problem, maybe nothing to do with petsc despite the error message.
Chris
Sent: Tuesday, April 29, 2025 1:50 PM
To: Klaij, Christiaan
Cc: Junchao Zhang; petsc-users at mcs.anl.gov; Isaac, Toby
Subject: Re: [petsc-users] problem with nested logging
On Tue, Apr 29, 2025 at 6:50 AM Klaij, Christiaan <C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>> wrote:
Here's a slightly better error message, obtained --with-debugging=1
Is it possible that you have a mismatched EventBegin()/EventEnd() in your code? That could be why we cannot reproduce it here.
      Matt
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: Petsc has generated inconsistent data
[0]PETSC ERROR: MPIU_Allreduce() called in different locations (code lines) on different processors
[0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjggvQAzPU$  for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.22.4, Mar 01, 2025
[0]PETSC ERROR: ./refresco with 2 MPI process(es) and PETSC_ARCH on marclus3login2 by cklaij Tue Apr 29 12:43:54 2025
[0]PETSC ERROR: Configure options: --prefix=/home/cklaij/ReFRESCO/trunk/install/extLibs --with-mpi-dir=/cm/shared/apps/openmpi/gcc/4.0.2 --with-x=0 --with-mpe=0 --with-debugging=1 --download-superlu_dist=https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/superlu_dist-8.1.2.tar.gz__;!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjgVgVAJPM$  --with-blaslapack-dir=/cm/shared/apps/intel/oneapi/mkl/2021.4.0 --download-parmetis=https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/parmetis-4.0.3-p9.tar.gz__;!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjgo2JWTO4$  --download-metis=https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/metis-5.1.0-p11.tar.gz__;!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjgX9ZMYJA$  --with-packages-build-dir=/home/cklaij/ReFRESCO/trunk/build-libs/superbuild --with-ssl=0 --with-shared-libraries=1
[0]PETSC ERROR: #1 PetscLogNestedTreePrintLine() at /home/cklaij/ReFRESCO/trunk/build-libs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:289
[0]PETSC ERROR: #2 PetscLogNestedTreePrint() at /home/cklaij/ReFRESCO/trunk/build-libs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:379
[0]PETSC ERROR: #3 PetscLogNestedTreePrint() at /home/cklaij/ReFRESCO/trunk/build-libs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:384
[0]PETSC ERROR: #4 PetscLogNestedTreePrint() at /home/cklaij/ReFRESCO/trunk/build-libs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:384
[0]PETSC ERROR: #5 PetscLogNestedTreePrintTop() at /home/cklaij/ReFRESCO/trunk/build-libs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:420
[0]PETSC ERROR: #6 PetscLogHandlerView_Nested_XML() at /home/cklaij/ReFRESCO/trunk/build-libs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:443
[0]PETSC ERROR: #7 PetscLogHandlerView_Nested() at /home/cklaij/ReFRESCO/trunk/build-libs/superbuild/petsc/src/src/sys/logging/handler/impls/nested/lognested.c:405
[0]PETSC ERROR: #8 PetscLogHandlerView() at /home/cklaij/ReFRESCO/trunk/build-libs/superbuild/petsc/src/src/sys/logging/handler/interface/loghandler.c:342
[0]PETSC ERROR: #9 PetscLogView() at /home/cklaij/ReFRESCO/trunk/build-libs/superbuild/petsc/src/src/sys/logging/plog.c:2040
[0]PETSC ERROR: #10 /home/cklaij/ReFRESCO/trunk/Code/src/petsc_include_impl.F90:130
[cid:ii_19681617e7812ff9cfc1]
dr. ir.         Christiaan       Klaij
 |      senior researcher        |      Research & Development   |      CFD Development
T +31 317 49 33 44<tel:+31%20317%2049%2033%2044>         |       C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>      | https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjgJooxJhg$ <https://urldefense.us/v3/__https://www.marin.nl/__;!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjgpOXjQSM$ >
[Facebook]<https://urldefense.us/v3/__https://www.facebook.com/marin.wageningen__;!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjg_3Zt0Pw$ >
[LinkedIn]<https://urldefense.us/v3/__https://www.linkedin.com/company/marin__;!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjgcpgQdSE$ >
[YouTube]<https://urldefense.us/v3/__https://www.youtube.com/marinmultimedia__;!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjgn8qP6_I$ >
From: Klaij, Christiaan <C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>>
Sent: Monday, April 28, 2025 3:53 PM
To: Matthew Knepley
Cc: Junchao Zhang; petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>; Isaac, Toby
Bisecting would be quite hard, it's not just the petsc version that changed, also other libs, compilers, even os components.
Chris
From: Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>>
Sent: Monday, April 28, 2025 3:06 PM
You don't often get email from knepley at gmail.com<mailto:knepley at gmail.com>. Learn why this is important<https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjgcKEJXRA$ >
On Mon, Apr 28, 2025 at 8:45 AM Klaij, Christiaan via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov><mailto:petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>> wrote:
I've tried adding a nested log viewer to src/snes/tutorials/ex70.c,
but it does not replicate the problem and works fine.
Perhaps it is related to fortran, since the manualpage of
PetscLogNestedBegin says "No fortran support" (why? we've been
using it in fortran ever since).
Therefore I've tried adding it to src/snes/ex5f90.F90 and that
also works fine. It seems I cannot replicate the problem in a
small example, unfortunately.
We cannot replicate it here. Is there a chance you could bisect to see what change is responsible?
Matt
Chris
From: Junchao Zhang <junchao.zhang at gmail.com<mailto:junchao.zhang at gmail.com><mailto:junchao.zhang at gmail.com<mailto:junchao.zhang at gmail.com>>>
Sent: Saturday, April 26, 2025 3:51 PM
Cc: petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov><mailto:petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>; Isaac, Toby
You don't often get email from junchao.zhang at gmail.com<mailto:junchao.zhang at gmail.com><mailto:junchao.zhang at gmail.com<mailto:junchao.zhang at gmail.com>>. Learn why this is important<https://urldefense.us/v3/__https://aka.ms/LearnAboutSenderIdentification__;!!G_uCfscf7eWS!cmLENZvO_Uydoa8ciUmsyX-F-QiJt9a2ZfQRUvQnRibGm7VE6PED7S_BDsUgjOzvPZIJyiIoJ8bLJk6gVgt1dmE$ >
Toby (Cc'ed) might know it. Or could you provide an example?
--Junchao Zhang
On Fri, Apr 25, 2025 at 3:31 AM Klaij, Christiaan via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov><mailto:petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>><mailto:petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov><mailto:petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>>>> wrote:
We recently upgraded from 3.19.4 to 3.22.4 but face the problem below with the nested logging. Any ideas?
Chris
[1]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[1]PETSC ERROR: General MPI error
[1]PETSC ERROR: MPI error 1 MPI_ERR_BUFFER: invalid buffer pointer
[1]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!cmLENZvO_Uydoa8ciUmsyX-F-QiJt9a2ZfQRUvQnRibGm7VE6PED7S_BDsUgjOzvPZIJyiIoJ8bLJk6gIT68pbk$ <https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGM3UaqHzc$> for trouble shooting.
[1]PETSC ERROR: Petsc Release Version 3.22.4, Mar 01, 2025
[1]PETSC ERROR: refresco with 2 MPI process(es) and PETSC_ARCH on marclus3login2 by jwindt Fri Apr 25 08:52:30 2025
[1]PETSC ERROR: Configure options: --prefix=/home/jwindt/cmake_builds/refresco/install-libs-gnu --with-mpi-dir=/cm/shared/apps/openmpi/gcc/4.0.2 --with-x=0 --with-mpe=0 --with-debugging=0 --download-superlu_dist=https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/superlu_dist-8.1.2.tar.gz__;!!G_uCfscf7eWS!cmLENZvO_Uydoa8ciUmsyX-F-QiJt9a2ZfQRUvQnRibGm7VE6PED7S_BDsUgjOzvPZIJyiIoJ8bLJk6grH5BbeU$ <https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/superlu_dist-8.1.2.tar.gz__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGM21-2D-o$> --with-blaslapack-dir=/cm/shared/apps/intel/oneapi/mkl/2021.4.0 --download-parmetis=https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/parmetis-4.0.3-p9.tar.gz__;!!G_uCfscf7eWS!cmLENZvO_Uydoa8ciUmsyX-F-QiJt9a2ZfQRUvQnRibGm7VE6PED7S_BDsUgjOzvPZIJyiIoJ8bLJk6gw4-tEtY$ <https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/parmetis-4.0.3-p9.tar.gz__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGMW0lYHko$> --download-metis=https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/metis-5.1.0-p11.tar.gz__;!!G_uCfscf7eWS!cmLENZvO_Uydoa8ciUmsyX-F-QiJt9a2ZfQRUvQnRibGm7VE6PED7S_BDsUgjOzvPZIJyiIoJ8bLJk6gHq4uYiY$ <https://urldefense.us/v3/__https://updates.marin.nl/refresco/libs/metis-5.1.0-p11.tar.gz__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGMbSrIiUg$> --with-packages-build-dir=/home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild --with-ssl=0 --with-shared-libraries=1 CFLAGS="-std=gnu11 -Wall -funroll-all-loops -O3 -DNDEBUG" CXXFLAGS="-std=gnu++14 -Wall -funroll-all-loops -O3 -DNDEBUG " COPTFLAGS="-std=gnu11 -Wall -funroll-all-loops -O3 -DNDEBUG" CXXOPTFLAGS="-std=gnu++14 -Wall -funroll-all-loops -O3 -DNDEBUG " FCFLAGS="-Wall -funroll-all-loops -ffree-line-length-0 -Wno-maybe-uninitialized -Wno-target-lifetime -Wno-unused-function -O3 -DNDEBUG" F90FLAGS="-Wall -funroll-all-loops -ffree-line-length-0 -Wno-maybe-uninitialized -Wno-target-lifetime -Wno-unused-function -O3 -DNDEBUG" FOPTFLAGS="-Wall -funroll-all-loops -ffree-line-length-0 -Wno-maybe-uninitialized -Wno-target-lifetime -Wno-unused-function -O3 -DNDEBUG"
[1]PETSC ERROR: #1 PetscLogNestedTreePrint() at /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:330
[1]PETSC ERROR: #2 PetscLogNestedTreePrint() at /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:384
[1]PETSC ERROR: #3 PetscLogNestedTreePrint() at /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:384
[1]PETSC ERROR: #4 PetscLogNestedTreePrintTop() at /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:420
[1]PETSC ERROR: #5 PetscLogHandlerView_Nested_XML() at /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/impls/nested/xmlviewer.c:443
[1]PETSC ERROR: #6 PetscLogHandlerView_Nested() at /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/impls/nested/lognested.c:405
[1]PETSC ERROR: #7 PetscLogHandlerView() at /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/handler/interface/loghandler.c:342
[1]PETSC ERROR: #8 PetscLogView() at /home/jwindt/cmake_builds/refresco/build-libs-gnu/superbuild/petsc/src/src/sys/logging/plog.c:2040
MPI_ABORT was invoked on rank 1 in communicator MPI_COMM_WORLD
with errorcode 98.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[cid:ii_196725d1e2a809852191]
T +31 317 49 33 44<tel:+31%20317%2049%2033%2044> | C.Klaij at marin.nl<mailto:C.Klaij at marin.nl><mailto:C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>><mailto:C.Klaij at marin.nl<mailto:C.Klaij at marin.nl><mailto:C.Klaij at marin.nl<mailto:C.Klaij at marin.nl>>> | https://urldefense.us/v3/__http://www.marin.nl__;!!G_uCfscf7eWS!cmLENZvO_Uydoa8ciUmsyX-F-QiJt9a2ZfQRUvQnRibGm7VE6PED7S_BDsUgjOzvPZIJyiIoJ8bLJk6g8TwMMcw$ <https://urldefense.us/v3/__https://www.marin.nl/__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGM8tSNH1g$>
[Facebook]<https://urldefense.us/v3/__https://www.facebook.com/marin.wageningen__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGMcVCZ9hk$>
[LinkedIn]<https://urldefense.us/v3/__https://www.linkedin.com/company/marin__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGMIDBZW7k$>
[YouTube]<https://urldefense.us/v3/__https://www.youtube.com/marinmultimedia__;!!G_uCfscf7eWS!biVlk6PKXoJvq5oVlmWdVJfW9tXv-JlwuWr3zg3jI5u1_jo8rvtZpEYnHO5RjdBqQEoqpqlJ3nusrFGMVKWos24$>
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjg539kFLg$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fFq1daAFFpKhBA_NWU3sd2QJe_S44rklqeRi0TB57XI0nQsh9jgy8iw3JNGpBbd21zqvO3QlGTLa7kjgMsu6hhA$ >
-- Norbert Wiener
Type: image/png
Desc: image341996.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250429/32c5b2d6/attachment-0004.png>
Type: image/png
Desc: image278410.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250429/32c5b2d6/attachment-0005.png>
Type: image/png
Desc: image182311.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250429/32c5b2d6/attachment-0006.png>
Type: image/png
Desc: image231002.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250429/32c5b2d6/attachment-0007.png>
