[petsc-users] VecSet and VecAssemblyBegin
    Barry Smith
    bsmith at petsc.dev
    Sat Apr 26 12:46:36 CDT 2025
  The guards are supposed to be universal, not one-offs that are put into specific locations. How come no errors with debug mode are detected in this situation?
  Barry
> On Apr 26, 2025, at 1:09 PM, Matthew Knepley <knepley at gmail.com> wrote:
> Junchao, should we put guards in VecSet() and LocalToGlobal() for the array lock?
>   Thanks,
>      Matt
> On Sat, Apr 26, 2025 at 11:50 AM Junchao Zhang <junchao.zhang at gmail.com <mailto:junchao.zhang at gmail.com>> wrote:
>> Yes, that is correct.
>> --Junchao Zhang
>> On Sat, Apr 26, 2025 at 10:35 AM Derek Teaney <derek.teaney at stonybrook.edu <mailto:derek.teaney at stonybrook.edu>> wrote:
>>> Ok -- got it -- thanks so just do the RestoreArray before the final step, e.g.
>>> Loop over cases
>>>       VecSet(dn_local, 0.)
>>>       GetArray(dn_local, &dn)  // RIGHT
>>>       Fill up dn
>>>       Restore Array
>>>       LocalToGlobal
>>> On Sat, Apr 26, 2025 at 9:50 AM Junchao Zhang <junchao.zhang at gmail.com <mailto:junchao.zhang at gmail.com>> wrote:
>>>> On Sat, Apr 26, 2025 at 8:27 AM Derek Teaney via petsc-users <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
>>>>> Thanks Barry -- this solved the issue.
>>>>> "probably will be fine" was fine with 3.17 and maybe 3.19,  but definitely not fine with 3.20.
>>>>> For others the faulty logic is:
>>>>> GetArray(dn_local, &dn)   //WRONG
>>>>> Loop over cases
>>>>>       Fill up dn
>>>>>       LocalToGlobal
>>>>> RestoreArray
>>>>> Where as one should do:
>>>>> Loop over cases
>>>>>       Fill up dn
>>>>>       LocalToGlobal
>>>>>       RestoreArray
>>>> The above two pieces of code are both wrong, in my view.
>>>>> So, while nothing is copied, if I think of dn as a copy (and not a view) the logic will always be correct.
>>>>> Now I have a related question about  "Technically you should not be calling VecSet() with any outstanding arrays but it will probably be fine."
>>>>> What about  GlobalToLocal?  should I always GetArray for the local array after the GlobalToLocal
>>>>> So,  is this  also bad logic:
>>>>> GetArray(n_local, &n)
>>>>> Loop over cases:
>>>>>      GlobalToLocal(n_global, &n_local)
>>>>>      do stuff with n
>>>>>      LocalToGlobal(n_local, n_global)
>>>>>  RestoreArray
>>>>> as opposed to
>>>>> Loop over cases:
>>>>>      do stuff with n
>>>>>      RestoreArray
>>>> This is also wrong.
>>>> I think the rule here is: GetArray() puts the vector in an interim state. One shall not call any vector routines (ex. LocalToGlobal/GlobalToLocal) before RestoreArray().  You can only operate on the array instead.
>>>>> Thanks again for all your help,
>>>>> Derek
>>>>> On Fri, Apr 25, 2025 at 5:30 PM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>>>>>     Even though GetArray() does not copy the array values; both GetArray/RestoreArray and Set track the current "state" of the vector and that count might get confused if they are used improperly.
>>>>>>> On Apr 25, 2025, at 4:42 PM, Derek Teaney <derek.teaney at stonybrook.edu <mailto:derek.teaney at stonybrook.edu>> wrote:
>>>>>>> Thanks,   I am working on providing a standalone code. A related question is -  if I did have a view of a local vector provided by:
>>>>>>> data_node ***dn_array;
>>>>>>> DMDAVecGetArray(domain, dn_local, &dn_array);
>>>>>>> Can I assume through multiple calls to VecSet that the view  dn_array is valid, or should this be restored, between calls.
>>>>>>> Thanks,
>>>>>>> Derek
>>>>>>> On Fri, Apr 25, 2025 at 1:26 PM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>>>>>>>    You absolutely should not need to do an assembly after a VecSet. Please post a full reproducer that demonstrates the problem.
>>>>>>>>   Barry
>>>>>>>>> On Apr 25, 2025, at 1:23 PM, Derek Teaney via petsc-users <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
>>>>>>>>> Hi,
>>>>>>>>> I was under the (mistaken) impression that one does not need to due a VecAssemblyBegin etc following a VecSet, e.g.
>>>>>>>>>       VecSet(dn_local, 0.);
>>>>>>>>>       VecAssemblyBegin(dn_local) ;
>>>>>>>>>       VecAssemblyEnd(dn_local) ;
>>>>>>>>> Seems to give different results without the Assembly.
>>>>>>>>> Thanks for clarifying,
>>>>>>>>> Derek
>>>>>>>>> Derek Teaney
>>>>>>>>> Professor and Graduate Program Director
>>>>>>>>> Dept. of Physics & Astronomy
>>>>>>>>> Stony Brook University
>>>>>>>>> Stony Brook, NY 11794-3800
>>>>>>>>> Tel: (631) 632-4489
>>>>>>>>> Fax: (631) 632-9718
>>>>>>>>> e-mail: Derek.Teaney at stonybrook.edu <mailto:Derek.Teaney at stonybrook.edu>
>>>>>>> Derek Teaney
>>>>>>> Tel: (631) 632-4489
>>>>>>> Fax: (631) 632-9718
>>>>> Derek Teaney
>>>>> Tel: (631) 632-4489
>>>>> Fax: (631) 632-9718
>>> Derek Teaney
>>> Tel: (631) 632-4489
>>> Fax: (631) 632-9718
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fE14MPtF_3o08eM3ty1elbmmVfVpJTt3JiSuxrBbKBXPwXIHLTC4l7wwrUT21_bE5_FN9mM0rKi3SAGYKstfsrg$  <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!aIL-dQ6HGo2zkrc1_qEB3XbGFGhwsiPuJRK68V4emqBz31A_jzsgI-sJS8ki4Sx6hcqI_Ya3tzpzdl8ciLTN$>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250426/f675093f/attachment-0001.html>
