[petsc-users] Mixing PETSc Parallelism with Serial MMG3D Workflow
    neil liu
    liufield at gmail.com
    Wed Apr 23 12:27:13 CDT 2025
*MMG only supports serial execution, whereas ParMMG supports parallel mode
(although ParMMG is not as robust or mature as MMG).*
Given this, could you please provide some guidance on how to handle this in
the code?
Here are my current thoughts; please let know whether it could work as
a temporary solution.
We may only need to make minor modifications in the DMAdaptMetric_Mmg_Plex()
subroutine. Specifically:
   Allow all *collective PETSc functions* to run across all ranks as usual.
   Restrict the *MMG-specific logic* to run *only on rank 0*, since MMG is
   serial-only.
   Add a check before MMG is called to ensure that *only rank 0 holds mesh
   cells*, i.e., validate that cEnd - cStart > 0 only on rank 0. If more
   than one rank holds cells, raise a clear warning or error.
On Wed, Apr 23, 2025 at 1:11 PM Stefano Zampini <stefano.zampini at gmail.com>
wrote:
> If mmg does not support parallel communicators, we should handle it
> internally in the code, always use commself, and raise an error if there
> are two or more processes in the comm that have cEnd - cStart > 0
> Il giorno mer 23 apr 2025 alle ore 20:05 neil liu <liufield at gmail.com> ha
> scritto:
>> Thanks a lot. Pierre.
>> Do you have any suggestions to build a real serial DM from this gatherDM?
>> I tried several ways, which don't work.
>> DMClone?
>> Thanks,
>> On Wed, Apr 23, 2025 at 11:39 AM Pierre Jolivet <pierre at joliv.et> wrote:
>>> On 23 Apr 2025, at 5:31 PM, neil liu <liufield at gmail.com> wrote:
>>> Thanks a lot, Stefano.
>>> I tried DMPlexGetGatherDM and DMPlexDistributeField. It can give what we
>>> expected.
>>> The final gatherDM is listed as follows, rank 0 has all information
>>> (which is right) while rank 1 has nothing.
>>> Then I tried to feed this gatherDM  into adaptMMG on rank 0 only (it
>>> seems MMG works better than ParMMG, that is why I want MMG to be tried
>>> first). But it was stuck at collective petsc functions
>>> in DMAdaptMetric_Mmg_Plex(). By the way, the present work can work well
>>> with 1 rank.
>>> Do you have any suggestions ?  Build a real serial DM?
>>> Yes, you need to change the underlying MPI_Comm as well, but I’m not
>>> sure if there is any user-facing API for doing this with a one-liner.
>>> Thanks,
>>> Pierre
>>> Thanks a lot.
>>> Xiaodong
>>> DM Object: Parallel Mesh 2 MPI processes
>>>   type: plex
>>> Parallel Mesh in 3 dimensions:
>>>   Number of 0-cells per rank: 56 0
>>>   Number of 1-cells per rank: 289 0
>>>   Number of 2-cells per rank: 452 0
>>>   Number of 3-cells per rank: 216 0
>>> Labels:
>>>   depth: 4 strata with value/size (0 (56), 1 (289), 2 (452), 3 (216))
>>>   celltype: 4 strata with value/size (0 (56), 1 (289), 3 (452), 6 (216))
>>>   Cell Sets: 2 strata with value/size (29 (152), 30 (64))
>>>   Face Sets: 3 strata with value/size (27 (8), 28 (40), 101 (20))
>>>   Edge Sets: 1 strata with value/size (10 (10))
>>>   Vertex Sets: 5 strata with value/size (27 (2), 28 (6), 29 (2), 101
>>> (4), 106 (4))
>>> Field Field_0:
>>>   adjacency FEM
>>> On Fri, Apr 18, 2025 at 10:09 AM Stefano Zampini <
>>> stefano.zampini at gmail.com> wrote:
>>>> If you have a vector distributed on the original mesh, then you can use
>>>> the SF returned by DMPlexGetGatherDM and use that in a call to
>>>> Il giorno ven 18 apr 2025 alle ore 17:02 neil liu <liufield at gmail.com>
>>>> ha scritto:
>>>>> Dear PETSc developers and users,
>>>>> I am currently exploring the integration of MMG3D with PETSc. Since
>>>>> MMG3D supports only serial execution, I am planning to combine parallel and
>>>>> serial computing in my workflow. Specifically, after solving the linear
>>>>> systems in parallel using PETSc:
>>>>>    1.
>>>>>    I intend to use DMPlexGetGatherDM to collect the entire mesh on
>>>>>    the root process for input to MMG3D.
>>>>>    2.
>>>>>    Additionally, I plan to gather the error field onto the root
>>>>>    process using VecScatter.
>>>>> However, I am concerned that the nth value in the gathered error
>>>>> vector (step 2) may not correspond to the nth element in the gathered mesh
>>>>> (step 1). Is this a valid concern?
>>>>> Do you have any suggestions or recommended practices for ensuring
>>>>> correct correspondence between the solution fields and the mesh when
>>>>> switching from parallel to serial mode?
>>>>> Thanks,
>>>>> Xiaodong
>>>> Stefano
> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250423/4865e0f8/attachment-0001.html>
