[petsc-users] Mixing PETSc Parallelism with Serial MMG3D Workflow
    Pierre Jolivet
    pierre at joliv.et
    Wed Apr 23 10:39:10 CDT 2025
> On 23 Apr 2025, at 5:31 PM, neil liu <liufield at gmail.com> wrote:
> Thanks a lot, Stefano.
> I tried DMPlexGetGatherDM and DMPlexDistributeField. It can give what we expected.
> The final gatherDM is listed as follows, rank 0 has all information (which is right) while rank 1 has nothing.
> Then I tried to feed this gatherDM  into adaptMMG on rank 0 only (it seems MMG works better than ParMMG, that is why I want MMG to be tried first). But it was stuck at collective petsc functions in DMAdaptMetric_Mmg_Plex(). By the way, the present work can work well with 1 rank.
> Do you have any suggestions ?  Build a real serial DM?
Yes, you need to change the underlying MPI_Comm as well, but I’m not sure if there is any user-facing API for doing this with a one-liner.
Pierre
> Thanks a lot.
> Xiaodong
> DM Object: Parallel Mesh 2 MPI processes
>   type: plex
> Parallel Mesh in 3 dimensions:
>   Number of 0-cells per rank: 56 0
>   Number of 1-cells per rank: 289 0
>   Number of 2-cells per rank: 452 0
>   Number of 3-cells per rank: 216 0
> Labels:
>   depth: 4 strata with value/size (0 (56), 1 (289), 2 (452), 3 (216))
>   celltype: 4 strata with value/size (0 (56), 1 (289), 3 (452), 6 (216))
>   Cell Sets: 2 strata with value/size (29 (152), 30 (64))
>   Face Sets: 3 strata with value/size (27 (8), 28 (40), 101 (20))
>   Edge Sets: 1 strata with value/size (10 (10))
>   Vertex Sets: 5 strata with value/size (27 (2), 28 (6), 29 (2), 101 (4), 106 (4))
> Field Field_0:
>   adjacency FEM
> On Fri, Apr 18, 2025 at 10:09 AM Stefano Zampini <stefano.zampini at gmail.com <mailto:stefano.zampini at gmail.com>> wrote:
>> If you have a vector distributed on the original mesh, then you can use the SF returned by DMPlexGetGatherDM and use that in a call to DMPlexDistributeField
>> Il giorno ven 18 apr 2025 alle ore 17:02 neil liu <liufield at gmail.com <mailto:liufield at gmail.com>> ha scritto:
>>> Dear PETSc developers and users,
>>> I am currently exploring the integration of MMG3D with PETSc. Since MMG3D supports only serial execution, I am planning to combine parallel and serial computing in my workflow. Specifically, after solving the linear systems in parallel using PETSc:
>>> I intend to use DMPlexGetGatherDM to collect the entire mesh on the root process for input to MMG3D.
>>> Additionally, I plan to gather the error field onto the root process using VecScatter.
>>> However, I am concerned that the nth value in the gathered error vector (step 2) may not correspond to the nth element in the gathered mesh (step 1). Is this a valid concern?
>>> Do you have any suggestions or recommended practices for ensuring correct correspondence between the solution fields and the mesh when switching from parallel to serial mode?
>>> Thanks,
>>> Xiaodong
>> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250423/c337ccbd/attachment-0001.html>
