[petsc-users] Hybrid multigrid
Barry Smith bsmith at petsc.dev
Thu Apr 10 14:17:21 CDT 2025
  Sounds correct.
> On Apr 10, 2025, at 2:04 PM, Anton Popov <popov at uni-mainz.de> wrote:
> Hi guys,
> I have a custom multigrid preconditioner that uses Galerkin coarsening for the staggered grid finite difference. Now I want to replace a few top level operators with the matrix-free shell matrices.
> Here is my plan:
> 1. Set PC_MG_GALERKIN_NONE
> 2. Call PCMGSetRestriction and PCMGSetInterpolation on all levels as I do it already
> 3. Use a combination of PCMGGetSmoother and KSPSetOperators to communicate my operators with PCMG
>     a. On the top levels just set the shell matrices minimalistically equipped with MATOP_GET_DIAGONAL and MATOP_MULT.
>     b. On the bottom levels generate the operators by explicitly calling MatMatMatMult (R is not the same as P in my case).
>         Use MAT_INITIAL_MATRIX for the first time
>         Use MAT_REUSE_MATRIX for the subsequent calls
> Is this a proper way to do it, or there is something wrong?
> If I want the restriction/interpolation matrices to be matrix-free on the top levels as well, I would need to set MATOP_MULT_ADD for them. Is this enough, or do I need something else?
> Thanks!
> Anton
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250410/de4315b0/attachment.html>
