[petsc-users] ASCII viewer formats
    Mark Adams
    mfadams at lbl.gov
    Thu Apr 10 03:49:46 CDT 2025
Hi Peder,
You can run with '-help -vec_view' (or whatever your view option is) and
that prints all options that are queried for.
This is very noisy so grep on 'vec_view'  and you will see the option
information: what it was, what it is after the query, and what options it
accepts.
I don't know of one that does what you want.
You could write it to a file and use sed or awk, etc.
On Thu, Apr 10, 2025 at 4:25 AM Peder Jørgensgaard Olesen via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> I would like to output the contents of a Vec to an ASCII file in which the
> entries are all on one line, as "x[0]  x[1]  x[2]  ...  x[N-1]". This can
> be done in a slightly roundabout way by putting the values in a 1xN dense
> Mat, assembling the matrix, and then use MatView with a suitable format,
> but one would think that skipping the matrix step and use a VecView
> directly would be more efficient (the procedure is to be repeated many
> times). However, none of the viewer formats seems to support the desired
> output formatting for Vec.
> Is there any way to customize viewer formats for a specific layout - or is
> there perhaps a more clever way to do the thing I want?
> Also, somewhat relatedly, is there a more detailed specification of
> available viewer formats? The documentation for PetscViewerFormat (
> https://urldefense.us/v3/__https://petsc.org/release/manualpages/Viewer/PetscViewerFormat/*petscviewerformat__;Iw!!G_uCfscf7eWS!bBFDjNvT7RMZgpeDh0FUlbrbeUxPtb93k6PYYqfx5ls9UeUdQ8aiIMM2e7qCFxUOUxQW2MqPjMj9BccmOMloaJI$
> <https://urldefense.us/v3/__https://petsc.org/release/manualpages/Viewer/PetscViewerFormat/*petscviewerformat__;Iw!!G_uCfscf7eWS!fmgo_gSUThwXeUVpPBhwFVgTXRhk3tS8gDcRbkXu6TQu9lj3Emm5wwGKPUktzKcWMN-isoQKklivtNv-eU4$>)
> briefly describes a number of them, and notes that "A variety of
> specialized formats also exist", although this isn't elaborated.
> Thanks!
> Best,
> Peder
> *Peder Jørgensgaard Olesen*
> Postdoc
> DTU Construct
> Institut for Byggeri og Mekanisk Teknologi
> pjool at dtu.dk
> Koppels Allé
> Building 403
> 2800 Kgs. Lyngby
> https://urldefense.us/v3/__http://www.dtu.dk/english__;!!G_uCfscf7eWS!bBFDjNvT7RMZgpeDh0FUlbrbeUxPtb93k6PYYqfx5ls9UeUdQ8aiIMM2e7qCFxUOUxQW2MqPjMj9BccmR8pz5l4$
> <https://urldefense.us/v3/__https://www.dtu.dk/english__;!!G_uCfscf7eWS!fmgo_gSUThwXeUVpPBhwFVgTXRhk3tS8gDcRbkXu6TQu9lj3Emm5wwGKPUktzKcWMN-isoQKklivEFUBK2I$>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250410/f6c82315/attachment-0001.html>
