[petsc-users] fieldsplit question
Mark Adams
mfadams at lbl.gov
Fri Apr 4 04:17:04 CDT 2025
Matt, Matt, Matt,
Sanjay, (1) is the only sane option. Here is an example taken from a code
that I work with.
This simply has 3 fields with 12 ("stride", not a great name, should be
"bs") dofs on each vertex in each field (2D Bell + 1D cubic Hermite).
This uses ISCreateBlock, which you might want to use for dof (1,2) in your
case. It lets, with stride = 2, input IS = [1,3] create an IS with
[2,3,6,7] semantically.
int matrix_solve:: setFieldSplitType()
// the global parameters
PetscInt ierr, dofPerEnt,stride,k;
int startDof, endDofPlusOne;
int num_own_ent=m3dc1_mesh::instance()->num_own_ent[0], num_own_dof;
m3dc1_field_getnumowndof(&fieldOrdering, &num_own_dof);
if (num_own_ent) dofPerEnt = num_own_dof/num_own_ent;
stride=dofPerEnt/3; //U 0->11, Omega 12->23, Chi 24->35
m3dc1_field_getowndofid (&fieldOrdering, &startDof, &endDofPlusOne);
startDof=startDof/stride;
// the 3 fields for PCFIELDSPLIT
IS field0, field1, field2;
PetscInt *idx0, *idx1, *idx2;
ierr=PetscMalloc1(num_own_ent, &idx0);
ierr=PetscMalloc1(num_own_ent, &idx1);
ierr=PetscMalloc1(num_own_ent, &idx2);
for (k=0; k<num_own_ent; k++) idx0[k]=k*dofPerEnt/stride + startDof;
ierr=ISCreateBlock(PETSC_COMM_WORLD, stride, num_own_ent, idx0,
PETSC_COPY_VALUES, &field0);
for (k=0; k<num_own_ent; k++) idx1[k]=1+k*dofPerEnt/stride + startDof;
ierr=ISCreateBlock(PETSC_COMM_WORLD, stride, num_own_ent, idx1,
PETSC_COPY_VALUES, &field1);
for (k=0; k<num_own_ent; k++) idx2[k]=2+k*dofPerEnt/stride + startDof;
ierr=ISCreateBlock(PETSC_COMM_WORLD, stride, num_own_ent, idx2,
PETSC_COPY_VALUES, &field2);
PC pc;
ierr= KSPAppendOptionsPrefix(*ksp,"fs_"); // ksp is a global here
ierr=KSPGetPC(*ksp, &pc);
ierr=PCSetType(pc, PCFIELDSPLIT);
ierr=PCFieldSplitSetIS(pc, NULL, field0);
ierr=PCFieldSplitSetIS(pc, NULL, field1);
ierr=PCFieldSplitSetIS(pc, NULL, field2);
ierr=PetscFree(idx0);PetscCall
<https://urldefense.us/v3/__https://petsc.org/main/manualpages/Sys/PetscCall/__;!!G_uCfscf7eWS!c_nKrPbKpTddk11qYmEtY65UqhTbG4LXm7rfRLNAprFTA0x4y_NfBtBIEhOMant3sxPS91A_TgyDkqZ9gefqEq4$ >(ISDestroy
<https://urldefense.us/v3/__https://petsc.org/main/manualpages/IS/ISDestroy/__;!!G_uCfscf7eWS!c_nKrPbKpTddk11qYmEtY65UqhTbG4LXm7rfRLNAprFTA0x4y_NfBtBIEhOMant3sxPS91A_TgyDkqZ9VDKwi_8$ >(&field0));PetscCall
<https://urldefense.us/v3/__https://petsc.org/main/manualpages/IS/ISDestroy/__;!!G_uCfscf7eWS!c_nKrPbKpTddk11qYmEtY65UqhTbG4LXm7rfRLNAprFTA0x4y_NfBtBIEhOMant3sxPS91A_TgyDkqZ9VDKwi_8$ >(&field1));PetscCall
<https://urldefense.us/v3/__https://petsc.org/main/manualpages/IS/ISDestroy/__;!!G_uCfscf7eWS!c_nKrPbKpTddk11qYmEtY65UqhTbG4LXm7rfRLNAprFTA0x4y_NfBtBIEhOMant3sxPS91A_TgyDkqZ9VDKwi_8$ >(&field2));
ierr=PetscFree(idx1);
ierr=PetscFree(idx2);
fsSet=1;
return 0;
On Thu, Apr 3, 2025 at 8:57 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Thu, Apr 3, 2025 at 12:11 AM Sanjay Govindjee via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> We would like to solve an FEA problem (unstructured grid) where the nodes
>> on the elements have different dofs. For example the corner nodes have
>> only dof 0 and then mid-side nodes have dofs 0,1,2 (think 8 node
>> serendipity element). This is a multi-physics problem so we are looking to
>> use the fieldsplit features to pre-condition and solve. Is there a simple
>> example of this type of usage in the src that we can try to mimic?
>> I presume this will take programming as opposed to just setting command
>> line options.
> It will take a little programming, but not much. Here is the idea.
> FieldSplit needs to know what dofs belong to what field. There are a couple
> of ways to do this, at different levels of abstraction.
> 1. Low level
> You can explicitly makes lists of the dofs in each field, as an IS, and
> call https://urldefense.us/v3/__https://petsc.org/main/manualpages/PC/PCFieldSplitSetIS/__;!!G_uCfscf7eWS!c_nKrPbKpTddk11qYmEtY65UqhTbG4LXm7rfRLNAprFTA0x4y_NfBtBIEhOMant3sxPS91A_TgyDkqZ9-jY5Sfg$
> <https://urldefense.us/v3/__https://petsc.org/main/manualpages/PC/PCFieldSplitSetIS/__;!!G_uCfscf7eWS!aMROjbrPD3RYXMpO8mIii7q8eXZX1uN-6F6-g_jcNLLXGCgYPt2JEDkIIQCHs_vNBhhxsiwQJaz57ydxKyWe$>
> for each field. This is not very flexible, but the easiest to understand.
> 2. Intermediate level
> You can make a DMShell, and then make a PetscSection, that gives the
> number of dofs on each vertex and edge. Then call KSPSetDM() or
> SNESSetDM(), and you can do nested fieldsplits from the command line. This
> also retains a connection between the topology and the data layout, but you
> have to deal with that pesky DM object.
> 3. High level
> You can use a DMPlex to represent your grid and a PetscFE to represent the
> discretization, and then layout is done automatically, and nested
> fieldsplits can be done from the command line. I am not 100% sure PetscFE
> can represent what you want, but you can always call DMPlexCreateSection()
> by hand to make the PetscSection.
> Thanks,
> Matt
>> -sanjay
> experiments lead.
> -- Norbert Wiener
> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!c_nKrPbKpTddk11qYmEtY65UqhTbG4LXm7rfRLNAprFTA0x4y_NfBtBIEhOMant3sxPS91A_TgyDkqZ9zTSheMM$
> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!aMROjbrPD3RYXMpO8mIii7q8eXZX1uN-6F6-g_jcNLLXGCgYPt2JEDkIIQCHs_vNBhhxsiwQJaz57-FUThx2$>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250404/d6547ba3/attachment-0001.html>
