[petsc-users] kokkos gpu/cpu copy
    Steven Dargaville
    dargaville.steven at gmail.com
    Thu Apr  3 08:30:29 CDT 2025
Perfect, that seems to have fixed the issue.
Thanks for your help!
Steven
On Thu, 3 Apr 2025 at 04:52, Junchao Zhang <junchao.zhang at gmail.com> wrote:
> Hi, Steven,
>    Thanks for the test, which helped me easily find the petsc bug. I have
> a fix at https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/8272__;!!G_uCfscf7eWS!ZNkvUNeiuBo6kRAR5k_yCtp_mOCmBVppGB_yvYsMwSiohil2UIhWXsli1sEeYZvqM0PkQe6HjVYqR8YxD-S1fT_OHcxzNRK2$ .
>    VecKokkos does not use offloadmask for its gpu/cpu sync state, while
> VecCUDA/VecHIP do.  My expectation is users should not use
> VecGetOffloadMask(), because it is too low level. We have bad API design
> here.
>   Thank you!
> --Junchao Zhang
> On Wed, Apr 2, 2025 at 7:11 PM Steven Dargaville <
> dargaville.steven at gmail.com> wrote:
>> Hi
>> I have some code that does a solve with a PCMAT preconditioner. The mat
>> used is a shell and inside the shell MatMult it calls VecPointwiseDivide
>> with a vector "diag" that is the diagonal of a matrix assigned outside the
>> shell.
>> If I use mat/vec type of cuda, this occurs without any gpu/cpu copies as
>> I would expect. If however I use mat/vec type kokkos, at every iteration of
>> the solve there is a gpu/cpu copy that occurs. It seems this is triggered
>> by the offloadmask in the vector "diag", as it stays as 1 and hence a copy
>> occurs in VecPointwiseDivide.
>> I would have expected the offload mask to be 256 (kokkos) after the first
>> iteration, as the offload mask of "diag" changes to 3 when using cuda after
>> the first iteration.
>> Is this the expected behaviour with Kokkos, or is there something I need
>> to do to trigger that "diag" has its values on the gpu to prevent copies? I
>> have example c++ code that demonstrates this below. You can see the
>> difference when run with petsc 3.23.0 and either "-log_view -mat_type
>> aijcusparse -vec_type cuda" or "-log_view -mat_type aijkokkos -vec_type
>> kokkos".
>> Steven
>> Example c++ code:
>> static char help[] = "Tests Kokkos for SHELL matrices\n\n";
>> #include <iostream>
>> #include <petscksp.h>
>> #include <petsclog.h>
>> typedef struct _n_User *User;
>> struct _n_User {
>>   Mat A;
>>   Vec diag;
>> static PetscErrorCode MatMult_User(Mat A, Vec X, Vec Y)
>>   User user;
>>   PetscFunctionBegin;
>>   PetscCall(MatShellGetContext(A, &user));
>>   // Print the offload mask inside the matmult
>>   PetscOffloadMask offloadmask;
>>   PetscCall(VecGetOffloadMask(X, &offloadmask));
>>   std::cout << "offload inside X " << offloadmask << std::endl;
>>   PetscCall(VecGetOffloadMask(Y, &offloadmask));
>>   std::cout << "offload inside Y " << offloadmask << std::endl;
>>   PetscCall(VecGetOffloadMask(user->diag, &offloadmask));
>>   std::cout << "offload inside diag " << offloadmask << std::endl;
>>   PetscCall(VecPointwiseDivide(Y, X, user->diag));
>>   PetscFunctionReturn(PETSC_SUCCESS);
>> int main(int argc, char **args)
>>   const PetscScalar xvals[] = {11, 13}, yvals[] = {17, 19};
>>   const PetscInt    inds[]  = {0, 1};
>>   PetscScalar       avals[] = {2, 3, 5, 7};
>>   Mat               S1, A;
>>   Vec               X, Y, diag;
>>   KSP               ksp;
>>   PC                pc;
>>   User              user;
>>   PetscLogStage  stage1, gpu_copy;
>>   PetscFunctionBeginUser;
>>   PetscCall(PetscInitialize(&argc, &args, NULL, help));
>>   // Build a matrix and vectors
>>   PetscCall(MatCreateFromOptions(PETSC_COMM_WORLD, NULL, 1, 2, 2, 2, 2,
>> &A));
>>   PetscCall(MatSetUp(A));
>>   PetscCall(MatSetValues(A, 2, inds, 2, inds, avals, INSERT_VALUES));
>>   PetscCall(MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY));
>>   PetscCall(MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY));
>>   PetscCall(MatCreateVecs(A, NULL, &X));
>>   PetscCall(VecCreateFromOptions(PETSC_COMM_WORLD, NULL, 1, 2, 2, &X));
>>   PetscCall(VecSetValues(X, 2, inds, xvals, INSERT_VALUES));
>>   PetscCall(VecDuplicate(X, &Y));
>>   PetscCall(VecDuplicate(X, &diag));
>>   PetscCall(VecSetValues(Y, 2, inds, yvals, INSERT_VALUES));
>>   PetscCall(VecAssemblyBegin(Y));
>>   PetscCall(VecAssemblyEnd(Y));
>>   // Create a shell matrix
>>   PetscCall(MatGetDiagonal(A, diag));
>>   PetscCall(PetscNew(&user));
>>   user->A = A;
>>   user->diag = diag;
>>   PetscCall(MatCreateShell(PETSC_COMM_WORLD, 2, 2, 2, 2, user, &S1));
>>   PetscCall(MatSetUp(S1));
>>   PetscCall(MatShellSetOperation(S1, MATOP_MULT, (void
>> (*)(void))MatMult_User));
>>   PetscCall(MatAssemblyBegin(S1, MAT_FINAL_ASSEMBLY));
>>   PetscCall(MatAssemblyEnd(S1, MAT_FINAL_ASSEMBLY));
>>   // Do a solve
>>   PetscCall(KSPCreate(PETSC_COMM_WORLD,&ksp));
>>   // Give the ksp a pcmat as the preconditioner and the mat is the shell
>>   PetscCall(KSPSetOperators(ksp,A, S1));
>>   PetscCall(KSPSetType(ksp, KSPRICHARDSON));
>>   PetscCall(KSPSetFromOptions(ksp));
>>   PetscCall(KSPGetPC(ksp, &pc));
>>   PetscCall(PCSetType(pc, PCMAT));
>>   PetscCall(KSPSetUp(ksp));
>>   // Print the offload mask before our solve
>>   std::cout << "offload X " << offloadmask << std::endl;
>>   std::cout << "offload Y " << offloadmask << std::endl;
>>   std::cout << "offload diag " << offloadmask << std::endl;
>>   // Trigger any gpu copies in the first solve
>>   PetscCall(PetscLogStageRegister("gpu_copy",&gpu_copy));
>>   PetscCall(PetscLogStagePush(gpu_copy));
>>   PetscCall(KSPSolve(ksp, X, Y));
>>   PetscCall(PetscLogStagePop());
>>   // There should be no copies in this solve
>>   PetscCall(PetscLogStageRegister("no copy",&stage1));
>>   PetscCall(PetscLogStagePush(stage1));
>>   PetscCall(MatDestroy(&S1));
>>   PetscCall(VecDestroy(&X));
>>   PetscCall(VecDestroy(&Y));
>>   PetscCall(PetscFinalize());
>>   return 0;
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20250403/47aacde7/attachment-0001.html>
