[petsc-users] ISView() in PETSc 3.22
Adrian Croucher a.croucher at auckland.ac.nz
Mon Sep 30 21:14:38 CDT 2024
hi, I am testing my (Fortran) code on PETSc 3.22 and have got it to
build. However I am getting some unusual new behaviour when I write an
IS to an HDF5 file using ISView().
The attached minimal example shows the issue. It creates a simple
10-element IS and writes it to HDF5. With previous versions of PETSc
this would give me a 10x1 dataset containing the values 0 - 9, as expected.
When I run it with PETSc 3.22 (in serial), I again get the expected
values written on stdout, so it looks like the IS itself is correct. But
in the HDF5 file I get a 1x3 dataset containing the values (10,1,0).
Has something changed here?
- Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
Waipapa Taumata Rau / University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
Type: text/x-fortran
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20241001/2431970e/attachment-0001.bin>
