[petsc-users] MatCopy question
Junchao Zhang
junchao.zhang at gmail.com
Thu Sep 26 13:36:27 CDT 2024
No, Setting a bigger matrix size won't have a negative impact. Only the
actual number of nonzeros matters.
--Junchao Zhang
On Thu, Sep 26, 2024 at 1:33 PM Frank Bramkamp <bramkamp at nsc.liu.se> wrote:
> Thanks for the reply,
> when setting the size larger than needed, would that have any negative
> impact somewhere else ?!
> We typically pre-determine how many non-zero elements are present, when
> using MatCreate.
> Then, the smaller size needs the same memory as the larger matrix ?!
> Thanks, Frank
> On 26 Sep 2024, at 20:27, Junchao Zhang <junchao.zhang at gmail.com> wrote:
> Is it possible to set the size of the COMPACT matrix as large as the WIDE
> matrix, then do MatAYPX(WIDE, 0, COMPACT, SUBSET_NONZERO_PATTERN), i.e,
> WIDE = 0*WIDE + COMPACT? You need to build WIDE upfront once, but if you
> repeat, the other MatAYPX will be fast.
> --Junchao Zhang
> On Thu, Sep 26, 2024 at 1:13 PM Barry Smith <bsmith at petsc.dev> wrote:
>> Frank,
>> Sorry for the confusion. MatCopy() and MatAXPY() only work for
>> identically sized matrices.
>> Even if the two matrices are the same size but one, say A, has a
>> subset of nonzeros than the other, say B, what you want to do is
>> non-trivial. This is because to do a copy you must MatAssembly the matrix
>> first and this squeezes out the zero locations that you would like to fill
>> in B.
>> A simple solution is in the code that computes the subset of entries,
>> call MatSetValues() twice, once for A and once for B. Not entirely
>> satisfying but it will work and be reasonably efficient.
>> Barry
>> > On Sep 26, 2024, at 1:50 PM, Frank Bramkamp <bramkamp at nsc.liu.se>
>> wrote:
>> > Dear PETSc team,
>> > I would like to create two matrices. The first matrix is based on a
>> compact stencil (COMPACT), and the second one has an extended stencil (WIDE)
>> > So the non-zero elements of the COMPACT matrix is contained in the
>> WIDE matrix as well. But the WIDE matrix shall contain some additional
>> elements.
>> > I try to create the COMPACT matrix first, then copy it to the WIDE
>> matrix and then add some more terms to the WIDE matrix.
>> > We want to create a matrix that is based on a lower order approximation
>> of our scheme which serves as basis matrix for preconditioning,
>> > where we want to have a more accurate jacobian which has a larger
>> stencil, that is based on the lower approximation plus some additional
>> non-zero elements.
>> > We want to avoid that we have to call the same routines twice to setup
>> the more accurate matrix, but copy the elements from the lower order
>> (compact) matrix.
>> > I try to use MatCopy to copy the COMPACT matrix into the WIDE matrix.
>> Somehow I cannot figure out to do this,
>> > since there is always a problem wirh non conforming sizes
>> > [0]PETSC ERROR: Nonconforming object sizes
>> > [0]PETSC ERROR: Mat A,Mat B: global dim (4,8) (4,8)
>> > Here is a basic example that I try.
>> > Adding additional elements to the WIDE matrix is disabled right now,
>> since MatCopy already gives a problem.
>> > I thought that in MatCopy(COMPACT, WIDE, DIFFERENT_NONZERO_PATTERN,
>> ierr)
>> > the option DIFFERENT_NONZERO_PATTERN should enable to copy different
>> matrix sizes into each other.
>> > Or is that not possible to do ?!
>> > Here the COMPACT matrix is a 4x4 matrix and the WIDE matrix 8x8, for a
>> basic test.
>> > Thanks, Frank Bramkamp
>> > program petsc_matrix_example
>> > #include <petsc/finclude/petsc.h>
>> > use petsc
>> > implicit none
>> > PetscErrorCode :: ierr
>> > Mat :: COMPACT, WIDE
>> > PetscInt :: m, n, MM, NN, d_nz
>> > PetscInt :: i, j
>> > PetscScalar :: additional_value
>> > ! Initialize PETSc
>> > call PetscInitialize(PETSC_NULL_CHARACTER, ierr)
>> > ! Set dimensions for COMPACT matrix
>> > m = 4 ! Local rows
>> > n = 4 ! Local columns
>> > MM = 4 ! Global rows
>> > NN = 4 ! Global columns
>> > d_nz = 4 ! Estimated non-zeros per row (diagonal) o_nz = 0 ! Estimated
>> non-zeros per row (off-diagonal)
>> > ! Create COMPACT matrix
>> > call MatCreateSeqAIJ(PETSC_COMM_SELF, MM, NN, PETSC_DECIDE,
>> PETSC_NULL_INTEGER, COMPACT, ierr)
>> > ! Set some values in COMPACT matrix (example) do i = 0, M-1
>> > do i = 0, NN-1
>> > !do j = max(0, i-1), min(NN-1, i+1)
>> > do j = 0,NN-1
>> > call MatSetValue(COMPACT, i, j, 1.0_PETSC_REAL_KIND,
>> INSERT_VALUES, ierr)
>> > end do
>> > end do
>> > ! Assemble COMPACT matrix
>> > call MatAssemblyBegin(COMPACT, MAT_FINAL_ASSEMBLY, ierr)
>> > call MatAssemblyEnd(COMPACT, MAT_FINAL_ASSEMBLY, ierr)
>> > ! Set dimensions for WIDE matrix
>> > n = 8 ! Increase local columns
>> > NN = 8 ! Increase global columns
>> > m = 8
>> > MM = 8
>> > d_nz = 8
>> > ! Create WIDE matrix
>> PETSC_NULL_INTEGER, WIDE, ierr)
>> > ! Assemble WIDE matrix: MUST WE ASSMBLE THE MATRIX BEFORE MatCOPY ?!
>> > call MatAssemblyBegin(WIDE, MAT_FINAL_ASSEMBLY, ierr)
>> > call MatAssemblyEnd(WIDE, MAT_FINAL_ASSEMBLY, ierr)
>> > ! Copy elements from COMPACT to WIDE
>> > call MatCopy(COMPACT, WIDE, DIFFERENT_NONZERO_PATTERN, ierr)
>> > !call MatAssemblyBegin(WIDE, MAT_FINAL_ASSEMBLY, ierr)
>> > ! Add additional elements to WIDE matrix
>> > !!$ additional_value = 10.0
>> > !!$ ! original
>> > !!$ !do i = 0, MM-1
>> > !!$ ! do j = NN/2, NN-1
>> > !!$ ! call MatSetValue(WIDE, i, j, additional_value, INSERT_VALUES,
>> ierr)
>> > !!$ ! end do
>> > !!$ !end do
>> > !!$ do i = 0, NN-1
>> > !!$ do j = max(0, i-1), min(NN-1, i+1)
>> > !!$ call MatSetValue(WIDE, i, j, 10.0_PETSC_REAL_KIND, ADD_VALUES,
>> ierr)
>> > !!$ end do
>> > !!$ end do
>> > ! Assemble WIDE matrix again
>> > ! View matrices (optional)
>> > call PetscPrintf(PETSC_COMM_WORLD, "COMPACT matrix:\n", ierr)
>> > call MatView(COMPACT, PETSC_VIEWER_STDOUT_WORLD, ierr)
>> > call PetscPrintf(PETSC_COMM_WORLD, "WIDE matrix:\n", ierr)
>> > call MatView(WIDE, PETSC_VIEWER_STDOUT_WORLD, ierr)
>> > ! Clean up
>> > call MatDestroy(COMPACT, ierr)
>> > call MatDestroy(WIDE, ierr)
>> > ! Finalize PETSc
>> > call PetscFinalize(ierr)
>> > end program petsc_matrix_example
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240926/d4f63153/attachment.html>
