[petsc-users] MatCopy question
Barry Smith
bsmith at petsc.dev
Thu Sep 26 13:13:22 CDT 2024
Frank,
Sorry for the confusion. MatCopy() and MatAXPY() only work for identically sized matrices.
Even if the two matrices are the same size but one, say A, has a subset of nonzeros than the other, say B, what you want to do is non-trivial. This is because to do a copy you must MatAssembly the matrix first and this squeezes out the zero locations that you would like to fill in B.
A simple solution is in the code that computes the subset of entries, call MatSetValues() twice, once for A and once for B. Not entirely satisfying but it will work and be reasonably efficient.
Barry
> On Sep 26, 2024, at 1:50 PM, Frank Bramkamp <bramkamp at nsc.liu.se> wrote:
> Dear PETSc team,
> I would like to create two matrices. The first matrix is based on a compact stencil (COMPACT), and the second one has an extended stencil (WIDE)
> So the non-zero elements of the COMPACT matrix is contained in the WIDE matrix as well. But the WIDE matrix shall contain some additional elements.
> I try to create the COMPACT matrix first, then copy it to the WIDE matrix and then add some more terms to the WIDE matrix.
> We want to create a matrix that is based on a lower order approximation of our scheme which serves as basis matrix for preconditioning,
> where we want to have a more accurate jacobian which has a larger stencil, that is based on the lower approximation plus some additional non-zero elements.
> We want to avoid that we have to call the same routines twice to setup the more accurate matrix, but copy the elements from the lower order (compact) matrix.
> I try to use MatCopy to copy the COMPACT matrix into the WIDE matrix. Somehow I cannot figure out to do this,
> since there is always a problem wirh non conforming sizes
> [0]PETSC ERROR: Nonconforming object sizes
> [0]PETSC ERROR: Mat A,Mat B: global dim (4,8) (4,8)
> Here is a basic example that I try.
> Adding additional elements to the WIDE matrix is disabled right now, since MatCopy already gives a problem.
> I thought that in MatCopy(COMPACT, WIDE, DIFFERENT_NONZERO_PATTERN, ierr)
> the option DIFFERENT_NONZERO_PATTERN should enable to copy different matrix sizes into each other.
> Or is that not possible to do ?!
> Here the COMPACT matrix is a 4x4 matrix and the WIDE matrix 8x8, for a basic test.
> Thanks, Frank Bramkamp
> program petsc_matrix_example
> #include <petsc/finclude/petsc.h>
> use petsc
> implicit none
> PetscErrorCode :: ierr
> Mat :: COMPACT, WIDE
> PetscInt :: m, n, MM, NN, d_nz
> PetscInt :: i, j
> PetscScalar :: additional_value
> ! Initialize PETSc
> call PetscInitialize(PETSC_NULL_CHARACTER, ierr)
> ! Set dimensions for COMPACT matrix
> m = 4 ! Local rows
> n = 4 ! Local columns
> MM = 4 ! Global rows
> NN = 4 ! Global columns
> d_nz = 4 ! Estimated non-zeros per row (diagonal) o_nz = 0 ! Estimated non-zeros per row (off-diagonal)
> ! Create COMPACT matrix
> call MatCreateSeqAIJ(PETSC_COMM_SELF, MM, NN, PETSC_DECIDE, PETSC_NULL_INTEGER, COMPACT, ierr)
> ! Set some values in COMPACT matrix (example) do i = 0, M-1
> do i = 0, NN-1
> !do j = max(0, i-1), min(NN-1, i+1)
> do j = 0,NN-1
> call MatSetValue(COMPACT, i, j, 1.0_PETSC_REAL_KIND, INSERT_VALUES, ierr)
> end do
> end do
> ! Assemble COMPACT matrix
> call MatAssemblyBegin(COMPACT, MAT_FINAL_ASSEMBLY, ierr)
> call MatAssemblyEnd(COMPACT, MAT_FINAL_ASSEMBLY, ierr)
> ! Set dimensions for WIDE matrix
> n = 8 ! Increase local columns
> NN = 8 ! Increase global columns
> m = 8
> MM = 8
> d_nz = 8
> ! Create WIDE matrix
> call MatCreateSeqAIJ(PETSC_COMM_SELF, MM, NN, PETSC_DECIDE, PETSC_NULL_INTEGER, WIDE, ierr)
> ! Assemble WIDE matrix: MUST WE ASSMBLE THE MATRIX BEFORE MatCOPY ?!
> call MatAssemblyBegin(WIDE, MAT_FINAL_ASSEMBLY, ierr)
> call MatAssemblyEnd(WIDE, MAT_FINAL_ASSEMBLY, ierr)
> ! Copy elements from COMPACT to WIDE
> call MatCopy(COMPACT, WIDE, DIFFERENT_NONZERO_PATTERN, ierr)
> !call MatAssemblyBegin(WIDE, MAT_FINAL_ASSEMBLY, ierr)
> ! Add additional elements to WIDE matrix
> !!$ additional_value = 10.0
> !!$ ! original
> !!$ !do i = 0, MM-1
> !!$ ! do j = NN/2, NN-1
> !!$ ! call MatSetValue(WIDE, i, j, additional_value, INSERT_VALUES, ierr)
> !!$ ! end do
> !!$ !end do
> !!$ do i = 0, NN-1
> !!$ do j = max(0, i-1), min(NN-1, i+1)
> !!$ call MatSetValue(WIDE, i, j, 10.0_PETSC_REAL_KIND, ADD_VALUES, ierr)
> !!$ end do
> !!$ end do
> ! Assemble WIDE matrix again
> ! View matrices (optional)
> call PetscPrintf(PETSC_COMM_WORLD, "COMPACT matrix:\n", ierr)
> call MatView(COMPACT, PETSC_VIEWER_STDOUT_WORLD, ierr)
> call PetscPrintf(PETSC_COMM_WORLD, "WIDE matrix:\n", ierr)
> call MatView(WIDE, PETSC_VIEWER_STDOUT_WORLD, ierr)
> ! Clean up
> call MatDestroy(COMPACT, ierr)
> call MatDestroy(WIDE, ierr)
> ! Finalize PETSc
> call PetscFinalize(ierr)
> end program petsc_matrix_example
