[petsc-users] Ghost particles for DMSWARM (or similar)
MIGUEL MOLINOS PEREZ
mmolinos at us.es
Thu Sep 26 10:20:11 CDT 2024
Thank you Matt.
Okey, let me have a careful look to the DMSwarmMigrate_Push_Basic implementation to see if there is some workaround.
The idea of adding new particles is interesting. However, in that case, we need to initialize the new (ghost) particles using the fields of the “real” particle, right? This can be done using something like:
VecGhostUpdateBegin<https://urldefense.us/v3/__https://petsc.org/release/manualpages/Vec/VecGhostUpdateBegin/__;!!G_uCfscf7eWS!fP7OWxTbYKTmKcfmVZotGtqEWwn7qb1U_unUjri1y_h3eMgj6qvPCAKa4jvQNLIS8llUk_EbKNwPj4v5Sni8cA$ >(Vec<https://urldefense.us/v3/__https://petsc.org/release/manualpages/Vec/Vec/__;!!G_uCfscf7eWS!fP7OWxTbYKTmKcfmVZotGtqEWwn7qb1U_unUjri1y_h3eMgj6qvPCAKa4jvQNLIS8llUk_EbKNwPj4ua8Nq_HA$ > globalout,InsertMode<https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/InsertMode/__;!!G_uCfscf7eWS!fP7OWxTbYKTmKcfmVZotGtqEWwn7qb1U_unUjri1y_h3eMgj6qvPCAKa4jvQNLIS8llUk_EbKNwPj4uuJ79GsA$ > ADD_VALUES<https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/ADD_VALUES/__;!!G_uCfscf7eWS!fP7OWxTbYKTmKcfmVZotGtqEWwn7qb1U_unUjri1y_h3eMgj6qvPCAKa4jvQNLIS8llUk_EbKNwPj4tq2xM6DA$ >, ScatterMode<https://urldefense.us/v3/__https://petsc.org/release/manualpages/Vec/ScatterMode/__;!!G_uCfscf7eWS!fP7OWxTbYKTmKcfmVZotGtqEWwn7qb1U_unUjri1y_h3eMgj6qvPCAKa4jvQNLIS8llUk_EbKNwPj4uWVuvpMQ$ > SCATTER_REVERSE<https://urldefense.us/v3/__https://petsc.org/release/manualpages/Vec/SCATTER_REVERSE/__;!!G_uCfscf7eWS!fP7OWxTbYKTmKcfmVZotGtqEWwn7qb1U_unUjri1y_h3eMgj6qvPCAKa4jvQNLIS8llUk_EbKNwPj4uwmCVNpA$ >);
VecGhostUpdateEnd<https://urldefense.us/v3/__https://petsc.org/release/manualpages/Vec/VecGhostUpdateEnd/__;!!G_uCfscf7eWS!fP7OWxTbYKTmKcfmVZotGtqEWwn7qb1U_unUjri1y_h3eMgj6qvPCAKa4jvQNLIS8llUk_EbKNwPj4sXG2qpEg$ >(Vec<https://urldefense.us/v3/__https://petsc.org/release/manualpages/Vec/Vec/__;!!G_uCfscf7eWS!fP7OWxTbYKTmKcfmVZotGtqEWwn7qb1U_unUjri1y_h3eMgj6qvPCAKa4jvQNLIS8llUk_EbKNwPj4ua8Nq_HA$ > globalout,InsertMode<https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/InsertMode/__;!!G_uCfscf7eWS!fP7OWxTbYKTmKcfmVZotGtqEWwn7qb1U_unUjri1y_h3eMgj6qvPCAKa4jvQNLIS8llUk_EbKNwPj4uuJ79GsA$ > ADD_VALUES<https://urldefense.us/v3/__https://petsc.org/release/manualpages/Sys/ADD_VALUES/__;!!G_uCfscf7eWS!fP7OWxTbYKTmKcfmVZotGtqEWwn7qb1U_unUjri1y_h3eMgj6qvPCAKa4jvQNLIS8llUk_EbKNwPj4tq2xM6DA$ >, ScatterMode<https://urldefense.us/v3/__https://petsc.org/release/manualpages/Vec/ScatterMode/__;!!G_uCfscf7eWS!fP7OWxTbYKTmKcfmVZotGtqEWwn7qb1U_unUjri1y_h3eMgj6qvPCAKa4jvQNLIS8llUk_EbKNwPj4uWVuvpMQ$ > SCATTER_REVERSE<https://urldefense.us/v3/__https://petsc.org/release/manualpages/Vec/SCATTER_REVERSE/__;!!G_uCfscf7eWS!fP7OWxTbYKTmKcfmVZotGtqEWwn7qb1U_unUjri1y_h3eMgj6qvPCAKa4jvQNLIS8llUk_EbKNwPj4uwmCVNpA$ >);
for the particle fields (?).
Miguel
On Sep 26, 2024, at 3:53 PM, Matthew Knepley <knepley at gmail.com> wrote:
On Thu, Sep 26, 2024 at 6:31 AM MIGUEL MOLINOS PEREZ <mmolinos at us.es<mailto:mmolinos at us.es>> wrote:
Hi Matt et al,
I’ve been working on the scheme that you proposed to create ghost particles (atoms in my case), and it works! With a couple of caveats:
-1º In general the overlap particles will be migrate from their own rank to more than one neighbor rank, this is specially relevant for those located close to the corners. Therefore, you'll need to call DMSwarmMigrate several times (27 times for 3D cells), during the migration process.
That is terrible. Let's just fix DMSwarmMigrate to have a mode that sends the particle to all overlapping neighbors at once. It can't be that hard.
-2º You need to set DMSWARM_MIGRATE_BASIC. Otherwise the proposed algorithm will not work at all!
Oh, I should have thought of that. Sorry.
I can help code up that extension. Can you take a quick look at the BASIC code? Right now, we just use the rank attached to the particle
to send it. We could have an arrays of ranks, but that seems crazy, and would blow up particle storage. How about just adding new particles
with the other ranks right before migration?
Matt
Hope this helps to other folks!
I have a follow-up question about periodic bcc on this context, should I open a new thread of keep posting here?
Miguel
On Aug 7, 2024, at 4:22 AM, MIGUEL MOLINOS PEREZ <mmolinos at us.es<mailto:mmolinos at us.es>> wrote:
Thanks Matt, I think I'll start by making a small program as a proof of concept. Then, if it works I'll implement it in my code and I'll be happy to share it too :-)
Miguel
On Aug 4, 2024, at 3:30 AM, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Fri, Aug 2, 2024 at 7:15 PM MIGUEL MOLINOS PEREZ <mmolinos at us.es<mailto:mmolinos at us.es>> wrote:
Thanks again Matt, that makes a lot more sense !!
Just to check that we are on the same page. You are saying:
1. create a field define a field called "owner rank" for each particle.
2. Identify the phantom particles and modify the internal variable defined by the DMSwarmField_rank variable.
3. Call DMSwarmMigrate(*,PETSC_FALSE), do the calculations using the new local vector including the ghost particles.
4. Then, once the calculations are done, rename the DMSwarmField_rank variable using the "owner rank" variable and call DMSwarmMigrate(*,PETSC_FALSE) once again.
I don't think we need this last step. We can just remove those ghost particles for the next step I think.
Matt
Thank you,
Miguel
On Aug 2, 2024, at 5:33 PM, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Fri, Aug 2, 2024 at 11:15 AM MIGUEL MOLINOS PEREZ <mmolinos at us.es<mailto:mmolinos at us.es>> wrote:
Thank you Matt for your time,
What you describe seems to me the ideal approach.
1) Add a particle field 'ghost' that identifies ghost vs owned particles. I think it needs options OWNED, OVERLAP, and GHOST
This means, locally, I need to allocate Nlocal + ghost particles (duplicated) for my model?
I would do it another way. I would allocate the particles with no overlap and set them up. Then I would identify the halo particles, mark them as OVERLAP, call DMSwarmMigrate(), and mark the migrated particles as GHOST, then unmark the OVERLAP particles. Shoot! That marking will not work since we cannot tell the difference between particles we received and particles we sent. Okay, instead of the `ghost` field we need an `owner rank` field. So then we
1) Setup the non-overlapping particles
2) Identify the halo particles
3) Change the `rank`, but not the `owner rank`
4) Call DMSwarmMigrate()
Now we can identify ghost particles by the `owner rank`
If that so, how to do the communication between the ghost particles living in the rank i and their “real” counterpart in the rank j.
Algo, as an alternative, what about:
1) Use an IS tag which contains, for each rank, a list of the global index of the neighbors particles outside of the rank.
2) Use VecCreateGhost to create a new vector which contains extra local space for the ghost components of the vector.
3) Use VecScatterCreate, VecScatterBegin, and VecScatterEnd to do the transference of data between a vector obtained with DMSwarmCreateGlobalVectorFromField
4) Do necessary computations using the vectors created with VecCreateGhost.
This is essentially what Migrate() does. I was trying to reuse the code.
Matt
Miguel
On Aug 2, 2024, at 8:58 AM, Matthew Knepley <knepley at gmail.com<mailto:knepley at gmail.com>> wrote:
On Thu, Aug 1, 2024 at 4:40 PM MIGUEL MOLINOS PEREZ <mmolinos at us.es<mailto:mmolinos at us.es>> wrote:
This Message Is From an External Sender
This message came from outside your organization.
Dear all,
I am implementing a Molecular Dynamics (MD) code using the DMSWARM interface. In the MD simulations we evaluate on each particle (atoms) some kind of scalar functional using data from the neighbouring atoms. My problem lies in the parallel implementation of the model, because sometimes, some of these neighbours lie on a different processor.
This is usually solved by using ghost particles. A similar approach (with nodes instead) is already implemented for other PETSc mesh structures like DMPlexConstructGhostCells. Unfortunately, I don't see this kind of constructs for DMSWARM. Am I missing something?
I this could be done by applying a buffer region by exploiting the background DMDA mesh that I already use to do domain decomposition. Then using the buffer region of each cell to locate the ghost particles and finally using VecCreateGhost. Is this feasible? Or is there an easier approach using other PETSc functions.
This is feasible, but it would be good to develop a set of best practices, since we have been mainly focused on the case of non-redundant particles. Here is how I think I would do what you want.
2) At some interval identify particles that should be sent to other processes as ghosts. I would call these "overlap particles". The determination
seems application specific, so I would leave this determination to the user right now. We do two things to these particles
a) Mark chosen particles as OVERLAP
b) Change rank to process we are sending to
3) Call DMSwarmMigrate with PETSC_FALSE for the particle deletion flag
4) Mark OVERLAP particles as GHOST when they arrive
There is one problem in the above algorithm. It does not allow sending particles to multiple ranks. We would have to do this
in phases right now, or make a small adjustment to the interface allowing replication of particles when a set of ranks is specified.
THanks,
Matt
Thank you,
Miguel
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fP7OWxTbYKTmKcfmVZotGtqEWwn7qb1U_unUjri1y_h3eMgj6qvPCAKa4jvQNLIS8llUk_EbKNwPj4vDGF_YTQ$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!fP7OWxTbYKTmKcfmVZotGtqEWwn7qb1U_unUjri1y_h3eMgj6qvPCAKa4jvQNLIS8llUk_EbKNwPj4sKOa0lZA$ >
-- Norbert Wiener
-- Norbert Wiener
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240926/25c0208d/attachment-0001.html>
