[petsc-users] Error: PCHYPRESetPoissonMatrix_HYPRE
Matthew Knepley
knepley at gmail.com
Thu Sep 19 09:20:39 CDT 2024
On Thu, Sep 19, 2024 at 9:33 AM Karthikeyan Chockalingam - STFC UKRI via
petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hello,
> I would like to make the following hypre call
> HYPRE_AMSSetBetaPoissonMatrix(ams, NULL);
> So it does look like ams_beta_is_zero has to be true
> https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/pc/impls/hypre/hypre.c?ref_type=heads*L325__;Iw!!G_uCfscf7eWS!eK8fCGlsadPLSpAOiMsKgfe5Rvn5AFmIy6c98fmu8MdOAd4PzvTw4sthhEHfPWCQCq2wOpwArn1DAETA90wv$
> <https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/pc/impls/hypre/hypre.c?ref_type=heads*L325__;Iw!!G_uCfscf7eWS!bi4rdSrrVzBRHrD32vObvn-LFoZba_XXh9z72ayyPQYw-X-nyeVCVp60RVCQVwTZHjxW-LZch_l-DhhxHn9BXpWjJIqS1m2SRZrJ$>
> So would I end up calling PCHYPRESetPoissonMatrix_HYPRE with isalpha being
> false.
> https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/pc/impls/hypre/hypre.c?ref_type=heads*L1640__;Iw!!G_uCfscf7eWS!eK8fCGlsadPLSpAOiMsKgfe5Rvn5AFmIy6c98fmu8MdOAd4PzvTw4sthhEHfPWCQCq2wOpwArn1DAAWh3H1U$
> <https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/blob/main/src/ksp/pc/impls/hypre/hypre.c?ref_type=heads*L1640__;Iw!!G_uCfscf7eWS!bi4rdSrrVzBRHrD32vObvn-LFoZba_XXh9z72ayyPQYw-X-nyeVCVp60RVCQVwTZHjxW-LZch_l-DhhxHn9BXpWjJIqS1lTIq-Ra$>
> But I get the following error from Libmesh: is it because of version
> incompatibility between PETSc and Hypre?
> vector_fe_ex3.C:141:3: error: 'PCHYPRESetPoissonMatrix_HYPRE' was not
> declared in this scope; did you mean 'PCHYPRESetBetaPoissonMatrix'?
> 141 | PCHYPRESetPoissonMatrix_HYPRE(pc, A, false);
You are misunderstanding the API organization. You are intended to call
PCHYPRESetBetaPoissonMatrix(), which
calls PCHYPRESetPoissonMatrix_HYPRE(..., PETSC_FALSE);
Matt
> I look forward to your response.
> Kind regards,
> Karthik
> *Karthik Chockalingam, Ph.D.*
> Senior Research Software Engineer
> High Performance Systems Engineering Group
> Hartree Centre | Science and Technology Facilities Council
> karthikeyan.chockalingam at stfc.ac.uk
> [image: signature_3970890138]
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!eK8fCGlsadPLSpAOiMsKgfe5Rvn5AFmIy6c98fmu8MdOAd4PzvTw4sthhEHfPWCQCq2wOpwArn1DAB18Lnc5$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!eK8fCGlsadPLSpAOiMsKgfe5Rvn5AFmIy6c98fmu8MdOAd4PzvTw4sthhEHfPWCQCq2wOpwArn1DAPapnkKX$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240919/15b8e78f/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240919/15b8e78f/attachment-0001.png>
